Originally Posted by Bad Luck
EVAP system can definitely cause a vehicle to stall depending on the evap fault. How much fuel did you have in your tank when you were off camber? Is your fuel gauge accurate? How did you get out of the situation?
Both times this happened I had just about over a 1/2 tank. Both times this happened I had more fuel in the truck than i usually do. I have NEVER filled the truck the entire time I have owned it, probably about 2 years now. 1/2 the time I put gas in it I poured from a 5 gallon container at my house. I believe that my fuel gauge is accurate.
The first time i was driving off camber and it happened I was able to coast to a point where I was only slightly off camber. truck would not start. Then I walked home. Came back about 20 mins later, started the truck and drove off like nothing happened.
The second time the same thing happened while I was in a bumpy trail with off-camber sections not far from my house again. This time though the truck would start and I was able to drive 50 feet and then it would stall. Same thing, had power and would turn over, would just stall shortly after that. I had to restart about 10 times to make it back to the house. There was definitely the smell of gas around the vehicle when I was walking around trying to figure out what was wrong.
