Old 02-04-2022, 10:30 PM #16
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Originally Posted by 303Crew View Post
Thanks for the advice! I do have have the tools for fuel lines, but from what you've said it sounds more like a hassle than what is worth especially with 169K on it. Gotcha on the transmission cooler, do you have a recommendation on whether to do one or the other?
A new radiator is best. They are known to crack not just at the plate that separates coolant from the transmission fluid but also crack on the plastic top cover.
326WHP 347TQ
Old 02-05-2022, 12:37 AM #17
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice
Romeo1's Avatar
Why not replace the fuel filter though? Pretty cheap in the grand scheme of things. It’s the only thing that ensures clean fuel goes to the injection system. Debris and condensation all live on a fuel tank. Filters aren’t a lifetime part. A set of metric and SAE flare nut wrenches is mandatory for a tool box. It’s the only way not to damage fasteners in many situations.
Far as the MAF, like Phattyduck said, they’re a delicate piece. This video goes into the why, but it is super technical and geared toward trained auto techs fyi. It even shows how they get damaged with just use and time.
Wells TechConnect Ep. 19--Does cleaning a mass air flow (MAF) sensor really work? - YouTube
K&N filters are what they are. See, here’s the thing, filtration is a function of restriction. To flow more air, you have to have a larger area, or filter less. There isn’t any magic sauce in filtration. It really is that simple.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
Romeo1 is offline   Reply With QuoteReply With Quote
Old 02-05-2022, 02:21 AM #18
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
Replacing the radiator is a no brainer. These radiators are inexpensive, and inexpensively made.
Remember that the cause of the pink milkshake is corrosion-induced failure of the heat exchanger located in the bottom tank. The corrosion results from the anti-corrosion chemicals in the coolant being exhausted. If you use old fashioned green coolant, that means you need to change the coolant once a year, maybe let it go 2 years max. If using the Toyota red coolant, that can be stretched to 3 or 4 years.
There is no substitute for replacing the coolant on time.
Also, if you reroute the trans cooling to only an external cooler, you lose the benefit of the radiator warming up the coolant on very cold days.
pluton is offline   Reply With QuoteReply With Quote
Old 02-05-2022, 04:44 PM #19
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
@ OP, in conjunction with. Do both. You will thank yourself later. Trust me. My original started leaking when I was 3.5 hours away from home. Just do both. Any brand I’m sure is better than none. I used B&M, but have heard equally good things about Hayden
filter , fluid , flush , oil , replace
Maintenance Questions Runnin4MO 5th gen T4Rs 3 08-18-2020 11:11 PM
Thank you & maintenance questions anormalflame 3rd gen T4Rs 7 04-29-2015 08:26 PM
Maintenance Questions voiddweller Classic T4Rs 7 02-28-2015 03:33 PM
A few maintenance questions..... JohnnyT 4th Gen T4Rs 5 02-18-2012 06:44 PM
