11-16-2022, 01:21 AM
#241
Real Name: C8H18 Mike
Originally Posted by BrianSD_42
Making my way through this. The new truck is looking great.
I am curious what paint brand and color you used for the wheels? I am going to reprint mine sometime in the next 3 months.
Thanks, it's been a fun project and a very capable rig on and off road
I used Dupli-Color HWP102 Graphite High Performance Wheel Paint https://a.co/d/1cB7ClB
Scuffed with 400 grit, cleaned and 3-4 coats per wheel, then, I finished with 2-3 coats of Dupli-Color HWP106 Matte Clearcoat https://a.co/d/4PUWFDJ
I have scraped the paint off in several spots and am about to touch them up probably skipping the clear coat
Another option Jordan used was Krylon Fusion All-In-One Spray Paint, they have a similar color. He's had it listed in his build thread, IIRC
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto -> 2WD 4runner Journal Thread
11-24-2022, 12:14 AM
#242
Finally got through reading this build. So many great builds on this site. I really like why you’ve done with your 4wd 4runner OctaneJunkie. Just a really nice clean build overall. The FMU is just cool. Your build kind of has a lot of things that I have already or want.
It seems like your still netting some really decent mpg numbers still even with your 4.88 axles too.
The rear bumper, how you liking it so far? I look and I look, yet I keep coming back to the 4XI. Would you do it again? The single swing, do you find it to work well, or is it hard to handle? I still want mine to be able to be opened by my wife and the boys if they need to. Wished I could come touch and look at one in person. I keep looking at the victory, 4 x 4 bumper also. The price on the victory is a bit steep too…..
But after watching some of the videos of people operating dual swings, I almost wonder if the single swing wouldn’t be less hassle overall. Since it you don’t have reach in down low in the middle to unlatch which requires bending in, from the looks of it at least. It looks like you can operate the 4XI swing out while standing up and close it while standing upright also.
Dumb question, the combo of 4.88 axles and 33” tires. If you had to do it again, would you go the same way? Or would you go with a different direction as far as ratio or tire sizes?
Thank you for your insight!
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
11-24-2022, 03:08 PM
#243
Thanks for the kind words
@ Romeo1
I'm looking forward to your build thread!
Fuel economy is mostly how I drive, which is generally more spirited, but I try to keep it under 3k RPM which means 69 mph in 5th gear and 35 psi, other than that, I'm happy with the tire/gear combo, it kicks ass on trail. A lot of thought went into the selection.
If I were to do it again, and I still may, I'd consider 4.30 or 4.56 gears to be more freeway friendly and add a crawl box. MC has their Taco Box on sale this weekend with free shipping and it's really tempting... I think I crawl enough that it would be worth it.
I really like the 4xi rear bumper, zero regret installing it; it's beefy af. I considered dual swing for a while, and after seeing my friends who have them, it's literally twice the work to open and close; plus a high lift jack would have to stand upright. That detail seems meaningless, but those jacks are heavy and the rear sees a lot of jerking and lurching; I prefer the jack as it is now, lateral across the rear, and in an orientation to roll with the vehicle' momentum vs let it's mass work against the momentum. I also like the tire being offset to the passenger side, but I may mod the mount to angle the tire for a better departure angle.
The FMU has some neato factor to it but I'm not sold 100% the altimeter is not accurate without constant adjustment, and I'm not typically lost and in need of a compass. The barometer is actually kinda neat to predict changes in the weather and I have yet to hook up the temp sensor - it's not been a priority.
Most of my next efforts are focused around electrical needs: charging, storage and lights - and installing my winch. Oh, and my coilovers, too.
11-28-2022, 09:10 PM
#244
Weekend update 252,455
Lost a set of lower rear shock bushings, bolt and washer last weekend. Replaced all from the dealer except the large outer washer, got a SS thick fender washer at Ace
Land cruiser shock bushings
90385-19003
4runner shock bolt
91619-G1222
Reinstalled both with loctite and 47 # feet of torque, bottomed out bolts.
Installed my 9500# Smittybuilt Gen2 XRC winch, finally. Upgraded from steel cable and roller fairlead to synthetic line and hawse fairlead - which saved about 50#
Had to cut the grille and bumper to fit properly. I didn't want to extend the control cables and the free-spool handle contacted something in every orientation except one, so I had to notch the bumper to allow the handle swing.
Future upgrades include a switched solenoid to power the winch only when needed and a quick disconnect to make bumper removal easier.
WARN 63001 Solenoid / Power Interrupt
https://a.co/d/gSGnaik
2-4 Gauge Battery Quick Connect/Disconnect Wire Harness Plug Connector Recovery Winch Trailer, Pack of 2, Red
https://a.co/d/h7YYXNQ
11-29-2022, 01:00 AM
#246
Real Name: Just call me the Grease Monkey
I lost a shock bolt, bushing and washer too, only a couple km from home. I retraced my steps but couldn't find it. But I did find in the gutter a circular rubber thing that I shaped with a razor blade to fit like a bushing. And I had a rusty bent up old washer I found on the trail. And I had a spare bolt from the wreckers that was longer than the original so even better. That lasted quite a while until I decided to replace them with proper components before my long trip last summer. Shows what you can do with stuff you find on the ground...
My Snow and Sand build thread
Mark_BC's 2000 Limited Salvage Build
Determined to keep them from becoming parts trucks. Yes, even the one I just picked up as a parts truck...
11-29-2022, 09:01 AM
#247
I had a bunch of extra hardware that worked/got me going. I now carry a spare pair of bushings. I also like the longer bolt option, not sure why the factory bolt is so short when the entire mount is threaded.
11-29-2022, 09:39 AM
#248
Trail Run : Gold Mountain 3N69
November 20, 2022
Ran it 2 weeks ago with a couple of friends in 3rd Gens. Weather was great, we got lucky considering what happened...
Started with the gatekeeper at the bottom
Ed got stuck, had to winch him out. That's me with the crow bar and gloves after unraveling his winch cable off the spool. I hate metal cables lol
On our way, I'm the lead truck, Daryl photo documented the run.
I didn't realize the first waterfall was an obstacle and drove right up it. The others had to get pics and video
Swapped spots for the next waterfall, Ed went first. There were 2 lines and a bypass, we all decided the harder, left line was the way to go and I followed.
The trick here was to bump it which is easier for an automatic, it was a rite of passage for me, and I made it; Daryl was not so lucky... something went pop and we had to winch him up. That was a good time for lunch!
Steak tacos ala Chef Ed
We watched a few other try, and a brand new FJ roasted his trans. It was comical to watch the group behind us, and the 3 groups behind them, negotiating the obstacles of emotions
After lunch Daryl realized he had no rear drive and we decided to take the last bypass out, but that was not to be; Daryl's passenger CV decided to exit the chat and we had to start wrenching.
His axle nut was so tight we had to hit it with PB Blaster and a torch - a 24" breaker bar alone wouldn't do it.
Once we got the CV axle out we realized why the CV failed, the passenger diff mount was bent, a replacement CV would not work.
He needed an axle stub to keep the wheel bearing together so we separated the birfield joint and bolted it all back up sans center axle shaft. It was dark now.
Daryl had already called in the troops (his brothers) who were on their way with a spare 3rd member, rear axles, etc since he had no drive - so we began to tear down the rear end.
Ed and I left as the cavalry was on their way up, we passed them at the first waterfall. I got home at midnight, Daryl got off the trail at 2:30 AM. We all went to work the next day.
All in all, I had the least damage. I sheared the zerk fitting off my driveshaft at the pinion, and greased the entire rear end of my undercarriage on the way home, and almost scraped off my axle drain plug
Ed trashed his fender flares and reduced his fuel tank volume some more. Daryl won by a long shot, he's replacing both diffs and gears and a CV axle. Nothing a wallet can't fix.
11-29-2022, 12:19 PM
#249
Whoa, you guys really had quite the time out there.
I'm interested in what rear diff armor you plan to invest in now I've been thinking about that myself.
11-29-2022, 08:32 PM
#250
Real Name: Throws like a girl
Originally Posted by octanejunkie
....and add a crawl box. MC has their Taco Box on sale this weekend with free shipping and it's really tempting... I think I crawl enough that it would be worth it.
As another stick driver that does a little bumpity bump....worth it. If you've got a(nother) wad of dough to throw at the truck, whichever of the few kinds that are available, worth it.
'96 4Runner SR5, assorted baubles and doodads. Stuff happened to it. Stuff is still happening to it. Okay, now the stuff is just getting ridiculous.
'99 4Runner SR5 Highlander, manual w/locker. Stuff is starting to happen to this one too...too much stuff! Too much stuff!!
http://www.yotatech.com/f200/habaner...thread-201751/
Originally Posted by PWD4R
I know this is a weird ass question but do you shave your legs or something?
11-29-2022, 09:22 PM
#251
Loctite. Loctite Loctite Loctite.
Yeah, it’s one more thing to do. But man, does it save on lots of headaches. Especially on snowmobiles because they vibrate so bad.
11-29-2022, 10:02 PM
#252
$30 from Opt Off Road
It is sitting in my cart right now, but if I hadn't done 488 gears already it would have been a no-brainer. I think I need to sit it out until I plan on re-earing, again.
Yup. I have a bottle of blue, and a tube of red gel on the truck at all times now.
11-29-2022, 10:55 PM
#253
Gnarly trail for sure! Looks like a great time though.
That’s the trick, push and get the right momentum to get over, but don’t bump so hard to break things. Impressive to bend up a front and rear axle.
I need to go wheeling in California one of these days. Thanks for the pictures!
11-29-2022, 10:58 PM
#254
Red? I like the commitment! Man I hate red…… stuff needs a smoke wrench half the time to remove.
What are you thinking for gears on the next round?
11-30-2022, 12:07 AM
#255
Red is on very few things, uniball LBJ center bolts, hawse fairlead bolts
With a crawl box I'd go 4.30 or 4.56 max to keep it freeway friendly
