03-23-2023, 07:09 PM
#391
Real Name: C8H18 Mike
Originally Posted by Unner
I'm impressed you got the tensioner off without removing the AC compressor bracket. I've done my timing belt twice now and both times I tried, with no luck. Sounds like you found the perfect combination of extensions and swivel joints.
I'll post pics of the arsenal I used, but it was pretty basic. I could not get a 3/8 inch swivel between the oil pan and the AC bracket, the wobble socket extension was a godsend
For your next timing belt job, replacing the idlers makes a world of difference in how loud the engine is at idle. When I changed my original ones around 180k I couldn't believe how quiet and smooth it ran compared to before, not that it was loud or had bad bearings, but it did make a noticeable difference.
I had a squealing at cold start that is now gone, I did clean up everything before reinstalling it and might go back in to replace the fan clutch
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto -> 2WD 4runner Journal Thread
03-23-2023, 10:31 PM
#393
Originally Posted by brillo_76
I done 3 timing belts now. I have never taken ac bracket off. It's very possible, just tricky.
It all depends on the combo of extensions, swivels, and sockets your using. I have a pile of various ones from back in my technician days. Took me two or three tries to find the right combo. F pulling the AC pump. Ain't no body got time for that.
Can't remember if I used 1/4 or 3/8 drive long or short to be honest. Way faster, way easier though.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
03-24-2023, 10:13 AM
#394
This guy (internet pic)
Invaluable to get that rear tensioner bolt
03-25-2023, 12:54 AM
#395
Yeah, those kind of extensions are awesome.
06-15-2023, 11:41 AM
#396
Update 256,526 miles
Hearing a knocking noise from the rear when taking faster turns, mostly when turning left, sometimes right.
Passenger rear wheel bearing is going out, confirmed by lifting each wheel off the ground and rocking each wheel at 12 & 6 - rear passenger has about 1/4" of play at the outside of the tire. Seal not leaking yet.
Will monitor and prepare a set of replacement axles with new bearings. It literally never ends lol
06-15-2023, 05:17 PM
#397
Real Name: Jon
Real Name: Jon
1/4 play.. is not going.. it's gone... ;)
06-15-2023, 05:20 PM
#398
Update 256,526 miles.
too true..!
Build Etc...
If it ain't broke, fix it 'til it is.
06-15-2023, 06:13 PM
#399
It's less than 1/4" to be fair, but it's gonna get there soon
06-16-2023, 04:56 PM
#401
Ok. They are moaning or hauling yet?
No
06-16-2023, 11:40 PM
#403
Hmm. Just starting. Mostly they start making noises before ply shows up. Interesting. Especially the wheel bearings.
Almost makes me wonder if for hub is loose. Figure it's worth asking to double check that although I suspect octane would investigate that right away.
'98 SR5 5 Speed
10-02-2023, 06:21 PM
#404
Weekend Update 259,595
Lots of wheeling since my last update
Broke a few things along the way...
Popped a sidewall on a 1-year old Cooper ST MAXX on some road debris. Swapped to my spare and looked at my Tire Rack receipt, they included a 2 YEARS FREE WARRANTY. Long story short, their insurance bought me a new tire. Check your tire purchases, I forgot that value add, but it actually worked and cost me literally nothing. Thank you Tire Rack . com
Broke another CV on the driver side this weekend, I have all the parts on hand to rebuild my Toyota CVs, just need to dedicate the time to this "project" lol
Bushings on my Tundra Billies are cracking and it may be time to swap them out. Rebuilt Icon 2.5 CDCVs standing by along with
@ eimkeith
STR and limit strap mounts - front sway bar going away.
Another pending update will be exhaust, adding a resonator and down turn exit - I will rotate it to 5:00 to direct gas down and away from the undercarriage towards the passenger rear.
[pic pending]
Next will be the rear/cargo area - I need more practical storage for wheeling/camping but I will NOT be building a platform (I will in the 80, however) instead I will be maximizing the use of the rear sides above the wheel wells, molle panels over the rear windows (along with darker tint) and an overhead storage shelf/area. The main goals for the cargo mod:
- Second/rear Battery
- Rear Power Distribution/Charging (100W solar on roof secondary charge)
- On board Air Compressor (dual chamber Napa pump)
- Air Distribution (manifold for tires, tools, etc)
- Off Road Jack (skidded) Mount
- 4runner-specific Parts Storage
The rest of the space will be modular, leveraging crates for tools, camping supplies, cooking supplies, etc. and will be swapped between the 4runner and the 80. The goal is to make it easy to sleep in the 4runner, which I can easily as long as the space is available lol
At the same time as the Cargo Project, the rear seat project will commence, which entails making best use of the mid vehicle space while still allowing the seats backs to separate the passenger compartment from the cargo area, but still allowing the seat backs to fold down, allowing me to sleep in the rig.
Oh, and I got tired of hitting my head on a sold grab handle so this went above the driver door
The never ending project continues, and about to hit 260K, yay!
10-02-2023, 06:49 PM
#405
Real Name: Just call me the Grease Monkey
Great to see this still going. Interesting that you got an 80, I got a 60. I'm putting 80 axles under it though which is a ton of work. So work on the 4runners has had to slow down a bit. I made a rack on one side of the back of the 4runner that goes from the back, forward to about where the seat bottom would start. It won't allow a seat in that side but if need be, a seat could be added on the other side. Most of the time though I keep that seat out so I can sleep in the open side. It works with one person, not 2...
Will you put in an air receiver tank? I'd want one for blowing dust off the car. I was thinking of using a used tank from one of those cheap hot dog compressors that doesn't work anymore; problem is, I can't find one that doesn't work anymore LOL.
My Snow and Sand build thread
Mark_BC's 2000 Limited Salvage Build
Determined to keep them from becoming parts trucks. Yes, even the one I just picked up as a parts truck...
