Old 02-10-2022, 08:32 PM #1
Salty4Life Salty4Life is offline
Salty4Life is on a distinguished road
P0171 codes
I have a 98 4Runner. Recently changed o2 sensor, upstream abs downstream. I drove the car about 20 miles today and the check engine light turn on. The codes from the scanner are.
P0171 sysytem to lean bank 1
A/Fs or ho2s contaminated deteriorated or system failed, air leaks after MAF sensors or in EGR or PCV system
Fuel control sensor out of calibration
P0130 o2 circuit bank 1 sensor 1
P0133 o2 sensor circuit slow response bank sensor 1
I’m gonna clean the MAP sensor and see if that helps, but the p0130 code was the one that made me change out o2 sensors and it’s still popping up. Now it says circuit one bank one.
Does anyone have any advice on what else to try?
Salty4Life is offline   Reply With QuoteReply With Quote
Old 02-10-2022, 08:49 PM #2
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
If air intake tubes are original, there is a good chance the closest one to the metal plenum has a crack and is leaking air in, messing up the A/F mixure.
Since it has lots of folds, the cracks hide there. I replaced mine with OEM when i got an 0171, gone since. Now the part number on the pic is for an 01-02, so get the one specific for your model, I'd suggest OEM.
Luck.
P0171 codes-new-air-intake-hose-jpg
Old 02-11-2022, 12:07 AM #3
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
+1 on that air intake hose from maf to intake. I had one Crack.
Old 02-11-2022, 01:35 AM #4
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Clean the MAF sensor with sensor cleaner and make sure your filter element is clean and free of debris.
Like has been said, make sure there are no air leaks between the MAF sensor and the throttle body.
Check all vacuum hoses in and exiting the engine bay, like to the vacuum can in the driver's wheel well.
Silly question, has the truck ever just fallen out of cruise control for no apparent reason?
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 02-11-2022, 02:31 AM #5
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
P0130 and P0133 only show up if you have an issue with the front O2 sensor or the wiring. Inspect the wiring harness from the sensor to the main engine harness and look for damage or melting - it is very close to the exhaust. If it checks out, you might have got a dud of a sensor and try another.
P0171 could be a vacuum leak. Clean the MAF sensor first though.
326WHP 347TQ
Old 02-11-2022, 12:45 PM #6
Cleaned the MAF sensors, and checked all vacuum lines. I disconnected the battery to clear the codes. Drove around today and the lights haven’t come back on. It’s just strange that the MAF sensor can throw that many codes
1998 sr5 3.4 5peed 4x4
Old 02-11-2022, 12:52 PM #7
Cool.
Get a code scanner, they are not super expensive and worth owning when you drive a 20+ year old truck. Plus you can clear the codes easily and not have to disco the battery for 30+ mins (which also resets the entire ECU, fuel tables, clock and radio presets) to clear a code.
Completing a drive cycle will be the real barometer of whether the issue is resolved or not. Here is an easy read on how to do that:
How to Complete a Drive Cycle | YourMechanic Advice
Make sure your fuel tank is at 50% full or so for the EV test to complete, that one takes the longest.
Old 02-18-2022, 11:12 AM #8
Cleaning the MAF sensors and re checking all the vacuum lines fixed it. Thanks yall
bank , circuit , p0171 , sensor , system
Codes P0300 P0328 P0171 Car Pirate 4th Gen T4Rs 3 11-04-2021 09:16 AM
P0171 and P0174 codes RustyAb 5th gen T4Rs 1 11-20-2020 11:20 AM
Quickly Solved: P0171 & P0441 Codes BamaDrewski 3rd gen T4Rs 0 03-10-2018 12:02 AM
Troubleshoting codes P0171, P0130, P0133 please? SgtAbn 3rd gen T4Rs 5 06-16-2012 01:57 AM
Toyota 4runner codes P0171 and P0420 castironman 3rd gen T4Rs 8 02-04-2011 06:39 PM
