Old 02-14-2022, 11:40 AM #16
cl4Rk's Avatar
cl4Rk cl4Rk is offline
cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold
cl4Rk's Avatar
Originally Posted by JZiggy View Post
Anonymous fab shows ARP fasteners as replacements. I was going to look into that and spec some out. 180kpsi strength vs typical 150psi in 10.9 and grade 8 applications.
Any downsides to upgrading the bolts to the ARPs while still running the OEM LBJs? Like, would this create an unintended weak link somewhere else? (And would it matter?)
Here's the link: Toyota ARP Spindle Lower Ball Joint Hardware - Anonymous Fabrication
Thanks!
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
cl4Rk is offline   Reply With QuoteReply With Quote
Old 02-14-2022, 02:11 PM #17
WeakSauz WeakSauz is offline
WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about
Thanks!
No downsides other than how expensive they are. Just added overall strength. I have been running ARP 763-1003 SS HEX M10x1.25, 30mm length in my OEM LBJ for about 2yrs now. Lots of hard wheeling in rocks, impacts, lots of street miles. Anything you can imagine really. Much stronger than the Toyota bolts @ 180k psi. Toyota bolts are just fine also! But you cant really compare the strength of ARP vs Toyota. Different leagues. I think you'd rip the threads right out of the Knuckle before you break an ARP bolt. Which, if that happens, youve probably hit something so hard youre rig is totaled anyway
The purists will want to burn me at the stakes for this and start talking about how the factory bolts are TTY for a reason and have stretch built in, yada yada.
2000 SR5 4x4 | Geared, Locked and Fully restored OEM+ build.
Forged and Cammed 1UZ Single Turbo, Standalone ECU + Built R150 in process. Why, you ask? Because it makes no sense in this platform, and I love it!
WeakSauz is offline   Reply With QuoteReply With Quote
Old 02-14-2022, 02:49 PM #18
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
Nah, the factory bolts aren't TTY. If they were the torque procedure would be something like "30 ft-lb + 60* of rotation".
It looks like ARP's stainless bolts are 170ksi and the black oxide chromoly ones are 180ksi or higher.
JZiggy is offline   Reply With QuoteReply With Quote
Old 02-14-2022, 03:22 PM #19
cl4Rk's Avatar
cl4Rk's Avatar
@JZiggy @WeakSauz
I assume you'd still want to use the FSM torque spec for these stronger bolts since the knuckle threads would now be the weak link?
(Anonymous Fab says the are for 2000-2002 model years, so 59 ft/lbs)
@Y2K_4X4
Old 02-14-2022, 03:25 PM #20
Oh, I 100% agree with you. I just know we'll have someone come in here claiming it haha
Old 02-14-2022, 03:26 PM #21
@JZiggy @WeakSauz
I just went to 60ft/lbs on my ARPs and called it there. (with blue loctite). Basically like factory
Old 02-14-2022, 03:44 PM #22
JZiggy's Avatar
JZiggy's Avatar
@JZiggy @WeakSauz
Personally I would use whatever torque ARP suggests for the fastener. The strength of the bolt matters as does the coating (COF can change what is needed).
The threaded portion can be weaker since there's more area bearing the load. If that wasn't the case we could never torque steel fasteners to their proof load into aluminum housings. In this case it's still forged steel so the threads should be quite strong.
Old 02-17-2022, 09:36 PM #23
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
For the Stainless bolts 763-1003- 180k Psi - the torque is 54 Ft Lbs.
LBJ Uniball?-screenshots_2022-02-17-19-31-28-jpg
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 03-04-2022, 09:45 AM #24
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Given the different materials (SS vs CroMo) and the 663-1003 chromoly bolts being stronger and half the cost, any reason not to buy them instead of SS?
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 03-05-2022, 01:26 AM #25
infamousRNR's Avatar
infamousRNR infamousRNR is offline
infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light
I received my set a couple weeks ago, they look solid. I also got the updated ARP bolts. My wheeling style is crazy and I don't live in the salt belt so we will see how the uni-ball lives in a temperate climate (Bay Area).
For those concerned about the uniball needing service, it can be replaced, which means the initial cost of entry is high, but overall maintenance could be less than replacing OEM LBJ's more frequently.
Josh does some great work putting these together and the quality shows when you inspect these - now to put them to the test!!
LBJ Uniball?-img_1541-jpg
1998 Desert Dune Toyota 4runner Limited 4x4 w/ factory e-locker
2000 BLACK Toyota 4runner Limited 4x4 w/ factory e-locker Build Thread
2002 Thundercloud Metalic Toyota 4runner Limited 4x4
Build Thread
infamousRNR is offline   Reply With QuoteReply With Quote
Old 03-05-2022, 09:52 AM #26
Nice Sean
You gonna boot them?
Old 05-18-2022, 11:24 PM #27
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Originally Posted by Dezert4Runner View Post
I have a set that’s pending install.
Uniball LBJ from Anonymous Fabrication | IFS OFFROAD
Out of curiosity are you still using the OEM hubs? I find it extremely odd the top cap interferes, and I'm really struggling to believe one would go through the effort of making these but not confirm it's fitment before selling and advertising them. Something seems funky
Old 05-19-2022, 12:16 AM #28
Dezert4Runner's Avatar
Dezert4Runner Dezert4Runner is offline
Real Name: Evan
Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about
Real Name: Evan
I’m running stock hubs and spindles. Josh was running these and I got to see them in person before ever installing mine. His Tacoma is 2wd and has no CV’s in the equation, and the caps were pretty tight clearance wise. There’s not much room there between the spindle and 3d printed cap. Now add the cv outer dust seal and it gets even tighter. They were essentially being guinea pigged on his rig for a while before he started including them with purchases. I have no idea if other people were getting them before I picked mine up.
I could have made contact when tightening the cv nut and drawing that dust seal across the 3d cap. Who knows. I don’t really care if it’s there or not personally, so it was an easy decision to just leave them off. It’ll be way easier to lube the uniball without them being covered from the top anyways. Josh said he has to use a small paint brush from the bottom to get the uniball lubed, so even if the 3d caps fit, you’re sacrificing access to the uniball and stuff can still get in through the bottom if you’re in mud or water. It would really just be keeping the larger debris from sitting on top.
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
Dezert4Runner is offline   Reply With QuoteReply With Quote
Old 05-19-2022, 07:09 AM #29
I've been running the Anonymous Fabrication LBJs for a while now with srlf-sourced ARP 663-1003 bolts.
Amazon.com: ARP (663-1003) Hex Oxide Bolt, Black : Automotive
These chromoly back oxide bolts are rated at 180,000 psi tensile strength, stainless steel (763-1003) are rated at 170,000 psi tensile strength. Both torque to 54 pounds feet according to ARP.
The caps Josh sent did not fit mine either, the CV dust shields wouldn't let the LBJ LBJ Uniball?. I mic'd the center thickness of the cap at 2.7mm and sanded them down to 1mm thick so far... still a tight fit. I've been in communication with Josh about it and it's reasonable to run without the caps under normal conditions.
I am still pursuing alternative solutions and I suspect Josh is too. The caps are 3D printed, locally sourced and I hope to see a solution soon. While they are a tight fit, they are not watertight, so I would consider them an inspection point after submersion or prolonged extreme conditions, regardless.
Old 05-19-2022, 09:03 AM #30
beersyboy beersyboy is offline
beersyboy is on a distinguished road
if you're in an area where you'll get sand, salt etc in them its just not worth it
beersyboy is offline   Reply With QuoteReply With Quote
appealing , fix , lbj , time , word
WTB: 3RD Gen Uniball UCA's UnderFire Want to Buy/Trade 1 07-06-2018 03:54 AM
WTB: Uniball UCA johnnytoofye Want to Buy/Trade 0 06-13-2016 12:55 PM
all pro uca uniball click curbstomper 3rd gen T4Rs 0 09-27-2014 01:16 PM
WTB: Aftermarket Uniball UCA's redbull9944 For Sale: Suspension/Wheels/Tires 0 08-22-2014 11:13 PM
Wtb: Uniball Uca's for 3rd Gen Slow_T4R Want to Buy/Trade 0 01-25-2014 05:25 AM
