06-14-2022, 08:53 PM
#106
official vendor
official vendor
Originally Posted by theesotericone
Rad man. I am going to find some way to get that $50 to you even if I have to buy some struts then give them to somebody. lol
Haha, OK, that's some dedication! I'll PM you.
And thank you Mike:
06-20-2022, 10:00 AM
#107
official vendor
official vendor
Parts keep coming in - thanks
@ Jross
06-20-2022, 09:56 PM
#108
Real Name: Devan
Real Name: Devan
Put my top cap in a lathe to sand it down a little... what the hell are these things made of? I had the spindle ripping and was using 80+160 grit papers, yet after a solid 45 minutes I barely shaved it down 1mm. That's some pretty impressive plastic tbh
06-21-2022, 07:00 AM
#109
Real Name: C8H18 Mike
I used a combo belt sander, coarse belt and fine disc. Took me 5-10 mins each mic-ing them every minute or so
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto -> 2WD 4runner Journal Thread
06-22-2022, 01:25 PM
#110
official vendor
official vendor
Almost done with the easy part (still waiting for some 10.9 bolts to arrive):
06-22-2022, 04:18 PM
#111
What are the head markings on each type of Toyota bolt?
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
06-22-2022, 04:35 PM
#112
official vendor
official vendor
Same markings on the red and green flange bolts (4 hashes, 2 dots), and an 11 (or two hashes) on the bolt with washer:
06-22-2022, 06:36 PM
#113
Blammo.
Those are rated the same then, just with two different marking styles.
06-23-2022, 09:36 AM
#114
official vendor
official vendor
Blammo.
Yes, and that's why we plan to test to confirm. That oft-quoted LBJ article claims that there was significantly different stretch between these bolts when using a torque wrench, but the friction coefficients could have been different (though I find that hard to believe for the red and green bolts).
So we'll find out for sure. In addition to the tensile test, I'd like to run some torque vs load tests as well.
06-23-2022, 10:13 PM
#115
Real Name: Andy ಠ_ಠ
Real Name: Andy ಠ_ಠ
will be very interested in what you find. I have been using ARP stuff for a while now. I prefer the 12 point stuff but I'm guessing there is no difference between the 12 pt and 6 point stuff ARP makes. circle K lighter for scale.
07-15-2022, 10:42 PM
#116
official vendor
official vendor
Blammo.
Charlie, any idea of what strength these 11T bolts are? We'll find out in our tensile tests, but I'm wondering what the "rated" strength or grade of these bolts is.
07-16-2022, 08:01 AM
#117
Based on the recommended torque values I always understood the numbers to be in line with metric class rating. So a 10.9 is 1000 MPa. So a Toyota 11T should be 1100 MPa.
But there might be more to it than that…
07-16-2022, 09:57 AM
#118
official vendor
official vendor
Interesting... So that would suggest that the commonly cited practice of replacing the OEM bolts with Grade 10.9 bolts is NOT a good idea, and is actually a step down in strength?
07-16-2022, 12:29 PM
#119
Well we’re about to find out!
07-16-2022, 01:15 PM
#120
My own real world use would say the 10.9 is vastly superior to the OEM bolts. Maybe I've just been very unlucky shearing all the OEM bolts I have and shearing zero of the 10.9s I now use. But I doubt it. lol
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. --Albert Einstein
