11-28-2024, 12:03 PM
#16
Real Name: Skip
Real Name: Skip
Originally Posted by Swap Guy
Yea I plan to make a youtube video after thanksgiving. I just finished the front end work this weekend and can finally say I have a fully functional 4wd converted 3rd gen 4runner!
I'm really happy with the way the swap turned out as you cant even tell that it was a 2wd drive truck in the first place. I got the trim piece measurements right the first time lol.
If anyone has any specific questions about this swap let me know I'd be happy to answer them or add them into my video
I as well as others are excited to see your video on this....BUT keep in mind that on this forum you have to have at least 15 posts to be able to start your on topic, it was done this way to cut down on SPAMMERS, BOTS, etc., here's the rules....
T4R.ORG Forum Rules - MUST READ
"NEW MEMBERS - 15 POST RULE
A 15 post rule as been implemented.
To reduce the amount of bot activity and spam we have implemented a 15 post rule. All users must have a collective number of 15 posts before starting any new thread. This implementation applies to the entire forum except for the New Members section. DO NOT spam threads with irrelevant posts to increase your thread count. Doing so will result in a warning and / or infraction for multiple offences. To increase your post count please take time to introduce yourself in the New Members section and / or by posting in the specified thread found HERE. Once you have 15 posts you will be automatically be enabled to create threads forum wide."
2004 Limited V8
11-29-2024, 01:15 PM
#17
Originally Posted by chadr815
Super excited to see how this pans out. Have been wanting to do this for a while. I know everyone says find a 4WD and save the time but I got mine super low mileage and know everything that's been done to it. That can't be bought! About how long in total did it take you to do all of the work? My 3rd gen is my daily.
See the thread linked in my signature for my version of the 4WD swap. If you find a wrecked parts truck and have some welding skills and space, it is totally doable. It is not easy if you are trying to go OEM style without a parts vehicle nearby. You can also go the solid-axle front route (with manual hubs) and avoid wiring but really bump up the fabrication requirements. Wiring specifics and difficulty change by year.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
11-29-2024, 09:08 PM
#18
I'm actually gonna disagree with that entirely. I didn't do any welding or custom wiring. This swap was completely bolt on for me and I retained the factory crossmember location and 2wd bracket that's used to support the transmission.
I'm curious if you could add some detail on what you wired up? All the electrical connections were plug and play for me (granted I deleted ADD and went with manual locking hubs).
Also to address the time frame that this took, I'd say it can be done in two weekends with no down time on the truck (this was a daily for me as well). There's a lot of details and I will try my best to cover everything and break it down in my youtube video but the basics of it is you will be swapping your transmission or using your current trans, but converting it to mate with the t-case, however either way the trans will have to come out. This can be done in one weekend assuming everything goes to plan lol. Once the trans is swapped (or modified and reinstalled) you can drive it in 2wd indefinitely until you have time to install the front diff and the rest of the front end components and that only took me about a day and a half, but could easily be done in one full day.
I know people who have done this swap in the past have cut their old crossmember out and moved it forward or used a trail gear skid plate to replace the factory mount but I was able to bypass this with some creative use of the crossmember and 2wd bracket. Again, I will show how I was able to pull this off in my youtube video.
I will crawl under there and take some pics to share on here soon.
11-29-2024, 09:12 PM
#19
Also another note, I did not have a donor vehicle and I was able to source all the parts including interior trim pieces through local junkyards, ebay and facebook market place. Aside from the manual hubs you couldn't tell this was ever a 2wd truck in the first place. I think with how many wrecked rigs that are out there now, you really don't need a donor truck to make this happen, although it would make your life a lot easier.
12-02-2024, 10:49 PM
#20
Interesting choice to keep the 2WD crossmember and mount. The 4WD one is a bit beefier, FYI (not the crossmember, the mount). Also, your 2WD crossmember doesn't line up with any off-the-shelf skid plates, so that could be an issue for some. It is still helpful to do some welding for the shifter hole to get all the weld nuts in the right place for the 4WD shifter assembly.
The electrical is 100% due to ADD, though if you want a 4WD indicator on the dash you need to wire that up. The plugs are there under the dash for the ADD Relay, but the engine bay wiring (driver's side fender and engine harness) need the wires added. This is all assuming you are putting in a j-shift case, of course.
There are technically different tunings for the ABS system and the auto trans shift points, so the 4WD parts there can possibly help. I still use my 2WD parts for both of those since I use a '97 as the parts truck for my '99.
12-03-2024, 07:13 PM
#21
That's really good information. For the mount I did use the 4wd mount as the 2wd mount would not bolt up to the transmission. I used the factory bracket from the 2wd as it bridges the gap of where the 4wd crossmember would sit. I am actually moving to a Trail gear skid/ crossmember. I had to shim the 2wd bracket as originally it was rubbing on the frame and causing some vibration. I got it to sit right however it is sitting just high enough that when I load the truck up with weight and the body mounts compress, the trans rubs the frame and causes an ever so slight vibration at idle. Its really hard to notice and I could shim the mount more to alleviate it, but I figure its a good time to upgrade to the big beefy trail gear crossmember.
Its also funny you mention the shifter assembly nuts as I just drilled holes and used self tapping screws along with some high qualify rubber sound deading to insulate the threads and cover the shifter hole (Me and gramps went to town with the grinder lmao). I didn't think to weld the nuts in place before.
I was planning on wiring the dash light and I'm playing with the idea of installing the center locking diff t-case in the future....just gotta figure out how to wire in the 4x4 control module into the dash.
As far as abs goes, my light is on and im using the hubs/ bearings from a 1st gen tacoma since I went with the manual hubs. Im wondering if its an issue with the sensor since I had a shop press in and assemble my spindles. I saw your right up on this before hand (very informative btw) and swapped in a 96 auto from an SR5 into my 99 Limited and its been running smooth as butter.
12-04-2024, 02:58 PM
#22
The tone rings are probably missing on the hubs in the front...
12-04-2024, 11:23 PM
#23
Originally Posted by Texmax
Why in the world would you convert a 2wd to a 4? Didn't the factory make 4wd from the factory?
Why not just find a 4wd?
Seems like a ton of work for nothing.
This is three old thread, why are we re-hashing stupidity?
My 4Runner was free and my parts truck was $300. How much did you pay for your 4WD?
12-05-2024, 03:53 AM
#24
Real Name: Jon
Real Name: Jon
I Know of a guy that do it then sale the converted rigs off. Mostly the 2wd were really plentiful in the south and rust free clean. So He converts them then sales them off. Lives in the northeast here I believe.
I really cant say its for nothing. If there is a market for it and people are buying them. That would be up to the owners and their choice. Many of people had done 2wd to 4wd conversions because it was a lot cheaper then buying factory 4wd.
This is no different then people converting automatics 4 runners to manuals. As
with only 3% of the factory made manuals from 1996 to 2000 and the rest being automatics. I can see people doing either if they wish.
People need to realize the rust belt is now out of 3rd gens. Unless they were taken care of or brought in from a non rust area. The rust free ones and ones with good frames bring decent money at least around here. There is only a handful around here now in my area. The rest are all gone. With more and more gone every year.
12-05-2024, 02:23 PM
#25
Haha, you're a bucket of sunshine aren't you. It's like others have said it just makes sense. A clean 4x4 3rd gen in 2024 is gonna cost you a pretty penny especially if you live in the mountains, and the 2wd version is everywhere for cheap.
I got mine for with 140k on the clock in mint condition for 3500 and I did the whole swap with half brand new parts and half used parts with only 140k on them for less then 2k. My total cost for this truck is about 5k with a rebuilt front end. You cant find a clean 4x4 3rd gen with that kind of milage in my area for less then 10k and most want 15-20. Plus I liked my rig and didn't want to start over with a new one.
Besides, the amount of work is nothing compared to an SAS, but I assume you would call that pointless too cause why not just buy a jeep right? XD
At the end of the day it makes sense, its not too much work and it can be a fun project if you enjoy working on cars. If you don't like wrenching on cars then you shouldn't buy a 25 year old car in the first place.
12-05-2024, 02:29 PM
#26
Good guess, but I made sure to check that they were installed properly (you can see them through the ABS port on the spindle). I'm thinking its an issue with the ABS sensor itself.
12-07-2024, 06:57 PM
#27
$7500. Right Now probably have $12k in it, but the money is relative. If you've got it then it's not a factor.
Do you know what a socket is? Lmao what you’re saying makes no sense anyways. It’s not all about the money some people enjoy building something and being able to call it their own. If you have ever worked on your truck before or done a project by yourself then you would understand this.
Besides if money is no object why do you even have this truck ? 12k is considered a cheap vehicle today so why don’t you go buy a new TRD 4Runner off the lot. I mean money is relative right?
You see, there’s always a good reason to work on your own car…
12-09-2024, 03:39 PM
#28
I still hold the opinion that converting something that can be bought is a proposition undertaken by a certain type of individual with a certain type of need. Others agree that finding the model they desire is readily available with a little search effort and, that the effort to acquire the model they desire outweighs the effort and headache of a complete conversion.
Anyway, You're opinion is great, thanks for sharing.
Merry Christmas.
I'm not the one you are replying to here... but well, they aren't making anymore 4WD 3rd gen 4Runners. Building one helps keep these vehicles on the road. I was able to take a good condition (rust free) nice- condition 2WD 4Runner and parts from a rolled 4WD 4Runner that was already going to the junkyard (that someone had used the motor from already) and make something that otherwise wouldn't exist.
Oh, and I got to spend a couple weekends with my buddies wrenching on a vehicle, which I find fun and relaxing.
It isn't for everyone though - I only suggest doing it if you have the time, space and tools to do it... and a back up vehicle, and, and, and...
12-09-2024, 06:47 PM
#29
Real Name: Bill
Real Name: Bill
I am looking forward to the write up! Duck has a real good one but hey what’s one more.
Mine is 2wd. It was my Dads so it has sentimental value to me. I would not get rid of for anything.
1998 T4R SR5 V6 2wd Evergreen Pearl OME 880 Toytec 1/4" spacer OME 906w/OME20mm(10mmx2)spacers Bilstein 5100 BFG KO2 31's Satoshi mod 1.5" BL(Fat Pats)
My 4Runner build:
http://www.toyota-4runner.org/3rd-ge...8-sr5-2wd.html
12-12-2024, 01:43 AM
#30
I'm most likely gonna make a youtube video before I make a write up on here as there is a lot of information to cover and a video is just easier. I'm thinking I will make the video within the next week, I'm still tinkering around with things....
Ducks write up is great, but as someone who knew almost nothing about this truck before hand I was pretty confused reading through it and he did a couple of things differently or that I just didn't do at all. I'm hoping to show a different perspective!
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
