Old 02-14-2022, 11:18 PM #1
stevew092984 stevew092984 is offline
stevew092984 is on a distinguished road
Cracked valve cover
Cracked my valve cover doing a gasket change. My question is, what do you guys think about using a used valve cover for a replacement? Or should I just buy a brand new one?
stevew092984 is offline   Reply With QuoteReply With Quote
Old 02-14-2022, 11:22 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Should be good with a used one. Just check it for damage before using it. I would probably change the spark plug tube seals too.
Old 02-14-2022, 11:48 PM #3
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
I don't see why not. How severe of a crack are we talking anyways?
Old 02-15-2022, 12:26 AM #4
Cracked around the corner bolt hole next to the oil fill cap.
Old 02-15-2022, 01:47 AM #5
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Pretty common result when you don't equally tighten down the valve cover bolts in several passes bringing them up to the torque spec.
Used is fine.
Old 02-15-2022, 03:42 AM #6
I appreciate the responses. The torque spec seemed a little low to me, so I gave it a little more. I guess that was enough the crack the cover. I was torqing the bolts in a cross cross pattern a little bit at a time as to bring the cover down equally, but I was told I should have brought the four center bolts down first in an x pattern and then the outside bolts in the same pattern. Maybe four or five passes to bring them all down to spec.
Old 02-15-2022, 10:51 AM #7
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Yes, starting in the center in a crossing pattern and then moving outward to the other bolts in a crossing pattern is the correct method. It sounds like to me you had the right idea, but every time I've done this job I've done it even more gradually than 5 passes, more like at least 10. It's a test of patience doing it this slowly, but it's the safest way to go about it. I honestly don't think it's the slight over-tightening you did but rather you didn't tighten it down equally and gradually enough. Since you broke off the front corner, it's my guess the rear bolts were more touch downed the the front bolts. That means the cover needed to actually now bend down to the head, and it's not going to bend, it's going to crack since it's a cast piece. One of the corners cracking is where it always happens. I think you'd have to really over-tighten the bolts a lot to get the cover to crack. I don't think going slightly over the spec would do it, but I could be wrong. The first time I did this job, I didn't use a torque wrench, I just went by feel using my torque elbow.
Old 02-15-2022, 11:25 AM #8
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
The trick with the valve cover gaskets is to circle back to them every 500 miles and retorque the bolts as everything settles in.
The big culprit here are the rubberized washers under the bolts, those collapse with time and heat.
I tightened mine for the first year after changing my valve cover gaskets on my two-wheel drive - it should be good for another 200k miles.
The used valve cover gasket from the junkyard should be fine, I see them all the time, I just never needed one.
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
brand , buy , cover , cracked , valve
Cracked 3rd Brake Light Cover on Spoiler mrzacharyhorne 4th Gen T4Rs 4 03-03-2018 09:00 AM
Cracked valve cover NWFLBowhunter 3rd gen T4Rs 12 03-11-2015 11:13 PM
Cracked Timing Chain Cover UteRunner Classic T4Rs 3 11-29-2014 07:26 PM
WTB 3rd gen V6 valve cover Bigphil001 Want to Buy/Trade 1 07-15-2014 07:31 PM
Cracked valve cover KHoffRunner 3rd gen T4Rs 4 04-10-2012 11:54 AM
