Old 02-16-2022, 08:04 PM #1
DenverAirport's Avatar
DenverAirport DenverAirport is offline
DenverAirport will become famous soon enough
Storing the truck in the winter and avoiding salt
Hey everybody.
Due to unforeseen circumstances I'm taking a trip back home (Minnesota) for a few months starting this "spring" at the latest and as soon as in a week or so: winter
Growing up in the midwest my knowledge of auto mechanics / care were pretty limited (I mean, still are) but my method for dealing with winters with a car I really liked was always just spraying everything I could with lanolin (WoolWax). I've read a few threads here about this and similar options. If I need to go there starting next week and bring my truck, I will be sticking with my preference, WoolWax.
Say I travel to Minnesota this spring, there will likely still be salt used a couple times in April. How much rust can develop from driving on salt for a few weeks (daily driving) realistically? Should I just be washing my undercarriage every few weeks and calling it good or should I still consder coating my truck with WoolWax?
I know this entire conversation is overkill but that's why I love this forum, I know lots of you guys are taking insane steps to protect your vehicle from even the slightest bit of rust and I respect it haha
99' SR5 "Highlander Edition" - 301k - 4WD, Factory rear locker, 2.5" Dobinsons IMS lift, SPC UCAs, CJV 9168 TR axles, 199mm TBU, Tom Wood's driveshaft, eimkeith PCK, Aluminum Koyorad, Ultragauge
97' Limited - 250k - Stolen & Found (and Sold) - 4WD, 3" Billstein 5100 lift with OME 881, 890 springs, Diff drop, Camburg UCA's, 231mm TBU, Tom Wood's driveshaft, eimkeith PCK, Champion radiator, Ultraguage
DenverAirport is offline   Reply With QuoteReply With Quote
Old 02-16-2022, 09:33 PM #2
cl4Rk's Avatar
cl4Rk cl4Rk is offline
cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold
cl4Rk's Avatar
I don’t think it’s overkill.
I saw surface rust form in 4 weeks on brand new OEM parts: https://www.toyota-4runner.org/3702492-post51.html
And this was with very little driving, and only one application of road salt/brine.
Put anti seize on as many exposed bolts, nuts, etc as possible. Silicone paste. WD-40. Spent ATF, whatever.
Hopefully others with more experience can give their two cents.
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
cl4Rk is offline   Reply With QuoteReply With Quote
Old 02-16-2022, 09:52 PM #3
raKnizek's Avatar
raKnizek raKnizek is offline
Real Name: Alex
raKnizek will become famous soon enough
raKnizek's Avatar
Real Name: Alex
Good for you for taking some protective measures! I had good results with Fluid Film, for what its worth. Reapplying as needed after a light spray at the DIY car wash. I drove my 2000 through one North East winter.
When you're spraying off the truck don't forget to put the hose/power washer up inside the wheel wells. You want to get all the salt/sand out of the fenders where it likes to collect and sit. You can also put the hose into the open ends of the frame at the rear and flush it from the inside out for a few seconds.
Good luck!
2000 SR5 3.4, Manual, 4x4
Icon 2.5 extended coilovers & 2.0 rear, JBA UCAs
265/75R16 General Grabber X3 on LC80s
Full Skid Plates
raKnizek is offline   Reply With QuoteReply With Quote
Old 02-16-2022, 09:52 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Most of the northern United States in the rust belt. So if Minnesota is like Michagan, Ohio, PA and NY and the northeast and they use salt. You definitely would want to really clean it coat it then clean it when your back out of it.
Its the salt mist that will get you as it goes everywhere. I would clean coat it with woolwax or fluid film. Then really have the underside cleaned again when you get back.
The heavy wash underneath will really help wash of the underside.. Especially wash out the inner frame and coat it if possible. As that dirt salt mixture can lay in the frame and rot it out.. :-)
Old 02-16-2022, 11:51 PM #5
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
I don't use any sort of film under my car yet but I religiously wash the undercarriage depending on the use of salt in my area. If heavy usage, I wash once a week or so. Avoid storing your car inside the garage where its heated because the heat and salt will accelerate the rot under the car. My 4Runner has always been outside and the frame isn't horrible like others i've seen here.
2000 4Runner Limited 4x4 V6
Old 02-17-2022, 12:02 AM #6
Wow I've never considered how heat impacts this situation either. I had a car parked indoors I've seen get wrecked in MN from rust but my last car I had before moving west was parked outdoors for two years and it wasn't bad at all. I used WoolWax on it as I noted here earlier but I mean I just never considered that my parking it outdoors could have been a helping factor.
driving , salt , truck , week , woolwax
Top 3 rebuildable suspensions that can handle winter time salt and whatever else Fried_man7 5th gen T4Rs 8 11-15-2018 07:08 PM
Winter / salt rust prevention JabzSA 4th Gen T4Rs 18 09-12-2017 05:44 PM
Tips/Advice On Storing a Car Over Winter Hepar Off Topic 7 10-29-2013 04:19 PM
Storing 285/70 spare inside truck THES0FAK1NG Engines / Suspension / Wheels / Tires / Audio / Accessories 5 03-11-2011 10:38 AM
Winter Salt Roads Supra725 3rd gen T4Rs 1 01-05-2011 07:04 AM
