Old 02-18-2022, 10:48 AM #1
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Ditch light brackets
Seems there are only a few options for the 3rd gen for hood or cowl mounted ditch lights from my quick research: CBI and Rago?
Both are north of $60.
I read this thread
CBI Ditch Light Brackets - An Honest Review
While it seems pretty basic I'd rather not cut the cowl but I do like a fender mount vs hood mount.
What are you all running and what do you like/dislike about them?
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 02-20-2022, 05:05 AM #2
4x3Lander's Avatar
4x3Lander 4x3Lander is offline
4x3Lander will become famous soon enough 4x3Lander will become famous soon enough
4x3Lander's Avatar
Did the CBI fender mount. I wasn’t keen on cutting the cowl either, however, I didn’t remove it to cut it. I just kept barely trimming until the mount fit. For me, very little was removed and definitely can’t see anything once done.
I’m happy with my mounts!
2002 4Runner Sport Edition - 4WD auto / 3” lift / 33” tires
4x3Lander is offline   Reply With QuoteReply With Quote
Old 02-20-2022, 11:35 AM #3
chen5108 chen5108 is offline
chen5108 is on a distinguished road
You're right, there are not many options out there. I didn't like hood mounted either so I went with the fender mount as well. I ended up cutting up my cowl as well in order to get the mount to fit, I didn't want to fork out a ton of dough either so I just made my own. I just mocked it up with cardboard and went from there.
It is possible for a clean look if you want to DIY a set that can be bolted to the A pillar, of course with some really good sealing.
chen5108 is offline   Reply With QuoteReply With Quote
Old 02-20-2022, 12:39 PM #4
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
Make your own?
https://youtu.be/DKUcAfrzDYg
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 02-21-2022, 12:54 AM #5
blairracd's Avatar
blairracd blairracd is offline
blairracd is on a distinguished road
blairracd's Avatar
I like the CBI mounts. Like the other comments, you don’t have to remove the whole cowl and you don’t have to cut that much. It doesn’t look bad. Using the hood mounts is a hell of a lot better than drilling into your body somewhere else. I’m not sure why anyone would want to do that.
Ditch light brackets-5bb9591f-c95e-4ebc-8c39-a95905499712-jpg
Living and breathing and bleeding Toyota
https://imgur.com/a/KvwQdyO
RIP my ‘96.
blairracd is offline   Reply With QuoteReply With Quote
Old 02-21-2022, 12:36 PM #6
Originally Posted by patkelly4370 View Post
Make your own?
Ditch light brackets-no-time-busy-jpg
Old 02-21-2022, 12:38 PM #7
I got a 10% off coupon from Rago, which paid my tax, so I pulled trigger on those.
Install is pretty straightforward and I'll update my build thread once I install them, and some lights.
Thanks, folks!
Old 02-22-2022, 10:37 AM #8
aontkos's Avatar
aontkos aontkos is offline
aontkos will become famous soon enough
aontkos's Avatar
Aren't these for Jeep people?
aontkos is offline   Reply With QuoteReply With Quote
Old 02-22-2022, 10:52 AM #9
You could say the same about rock crawling...
Old 03-26-2022, 11:57 AM #10
Found another option, True North Fabrication
Ditch light brackets-screenshot_20220326-085538-jpg
DITCHLIGHT BRACKETS | TNF BRACKETS & ACCESSORIES
These mount to the A pillar (drilling required) and can be installed at any height. They are $40 and ship free.
Old 03-26-2022, 12:46 PM #11
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
Attachment 394346
Lucky you don't have tweekers in your area.....ditch lights wouldn't last a week outside around here.
Old 03-28-2022, 12:23 PM #12
I garage park and don't DD but that's a good point...
cowl , cut , ditch , hood , mount
WTB: 3rd Gen CBI Ditch Light Brackets Taylor20 Want to Buy/Trade 1 09-12-2018 02:30 PM
Ditch Light Brackets Mike07SE 4th Gen T4Rs 9 03-20-2018 03:18 PM
FS: CBI ditch light brackets, 3rd Gen, KY $45 Taylor20 For Sale: T4R Items 2 09-20-2015 12:23 PM
WIN a set of CBI Ditch Light Brackets CBI OffRoad Fab www.cbioffroadfab.com 0 03-17-2014 10:39 AM
