Old 02-19-2022, 02:17 PM #1
Levitan Levitan is offline
Levitan is on a distinguished road
Electrical Issue...key??
2000 Limited, 4x4, auto, 154k.
Battery dead this morning. Figured dome light got left on over night. Hook up battery charger, turn it over, slow turn over, then clicks. Gonna let it charge some more. Turn key off, remove key, key in ignition bell continues to ding. I tried every combo of turning on and off. Finally stops. Removed battery ends, cleaned posts and ends. Put the ends on the battery and there is clicking going on in the engine bay. The key in the ignition bell is dinging. Mind you, the key is in my pocket. Then the engine turns over. Remove the battery cable end and here I am.
Faulty ignition switch?
Your help would be much appreciated.
Levitan is offline   Reply With QuoteReply With Quote
Old 02-19-2022, 02:39 PM #2
repo repo is offline
repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light
Maybe try putting a little lock cylinder lube in there. They sell lube specifically made for locks at hardware or parts store. It sounds like it might be stuck, worth a try.
Are one of those people with 5lbs of crap hanging off their keychain? I've heard of that screwing up the ignition on other brands of vehicle. I think GM had to do a massive recall because it actually killed a few people.
99 SR5 v6 4WD
11 SR5 v6 4WD
repo is offline   Reply With QuoteReply With Quote
Old 02-19-2022, 03:14 PM #3
nissanh nissanh is offline
Engine turnover without the key in ignition?
Have you pressure washed the engine recently? Any moisture inside the fuse box?
If not, then remove the steering column covers and remove the wire switch unit at the end of the ignition key (held by one Phillips screw). Have the key off during this removal. see the condition of the electrical switch unit. You can turn the switch with a screwdriver (engine will start when it is turned to the furthest). Steering wheel will stay locked. If you suspect this unit, replace it. These switches hardly fail. Non of my toy's switches ever failed. If someone pull too much power from this switch into their accessories, then it can melt the wire pins inside the switch, otherwise, these are life time.
Electrical Issue...key??-2-jpg  Electrical Issue...key??-s-l1600-jpg
1990 3L Diesel Hilux LN 106; 1973 Ford Cortina XL
1992 4AFE Toyota Sprinter AE 91 (aka Geo Prizm)
1997 5vzfe 4Runner 4x4 (aka Hilux Surf)
2000 2uzfe 100 Series Land Cruiser
2021 Tacoma TRD Off-Road 4x4 6-speed
Old 02-19-2022, 04:21 PM #4
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
I trashed my ignition like that. Learned a good lesson that day when I had to do some work to the wafers inside the tumbler.
2000 4Runner Limited 4x4 V6
Old 02-19-2022, 04:44 PM #5
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
A little bit of graphite in the lock cylinder will lube that.
I have had the connector on the back of the ignition wear out with no extra accessories. They can especially after 250k miles...
Old 02-19-2022, 06:36 PM #6
Update:
Each step began by disconnecting the negative side of the battery. Performed each step, then connected the negative cable to see if problem persisted.
First I did a little squirt of WD40 I'm the key cylinder. In and out, on and off, every way possible. Did NOT fix the problem.
Second, pulled the lower dash panel, unplugged the electrical connector from the actual ignition switch. Attached negative cable, did not fix problem. This has removed the key and ignition switch from the equation.
Third, went under the hood, to the fuse/relay box on inner fender driver side. Noticed that the cover on the "starter relay" was damaged. Ah ha! That must be the problem. Removed it. Negative cable on the battery. Did NOT solve the problem.
Fourth, I now have to isolate the circuit causing the issue. I talked to my Mr. Goodwrench cousin and he says, start with the relays, then move to the fuses. So, one by one, I remove each relay. When I pull the relay "HEAD", problem stops. Now we know it's in the headlight circuit. I have a spare 4runner, so I pull the relay from that one, poke it in this 4runner, and, viola!, it's fixed.
So, after consulting with my cousin, and I may not have this exactly right, but you'll get the point. That relay is designed to turn one side on and one side off. The side that was to be shut off, was NOT, causing electricity to flow where it shouldn't. Hence, starter when it wasn't suppose to, key dinger, heater, etc. Crazy. Hopefully this is resolved.
Old 02-19-2022, 07:39 PM #7
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Great job. Relay failure. Glad you got it working.
battery , ends , ignition , key , turn
electrical issue help kutch_classic 3rd gen T4Rs 12 10-15-2014 09:40 PM
Electrical Issue? 1985taylor1925 3rd gen T4Rs 42 04-16-2013 07:24 PM
Serious Electrical Issue!!! APS LLC 4th Gen T4Rs 1 05-11-2012 10:49 AM
Electrical issue? Or???? GR8TSCT Classic T4Rs 9 12-20-2010 10:15 PM
