Old 02-24-2022, 06:25 PM #1
Paulmaz's Avatar
Paulmaz Paulmaz is offline
Paulmaz is on a distinguished road
Paulmaz's Avatar
Upper Control Arm ?
Hello-
I was wondering if need to replace the entire UCA, ir can i just replace the bushing?
Reason i ask is. I drive a 2004 F150 (the 4R is my son's) On the F150, you cant replace the OEM UCA bushings only, its connected to the UCA. And i am embarking on that project, as the bushings are bad.
I noticed on the 4R, you can replace just the bushings. All suspension is original (2002, 290K miles) I am replacing coils, shocks, sway bar links.
Is it OK to just do bushings, or replace the entire UCA?
thanks,
2002 4Runner 2WD
292K miles and counting!
Some Pics
Paulmaz is offline   Reply With QuoteReply With Quote
Old 02-24-2022, 07:00 PM #2
Dezert4Runner's Avatar
Dezert4Runner Dezert4Runner is offline
Real Name: Evan
Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about
Real Name: Evan
If the UCA’s aren’t rusted to hell and the upper ball joint is tight, you can just get the Whiteline bushings for the UCA.
Front Control Arm - Upper Bushing Kit | Industry Leaders in Suspension & Chassis Components.
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
Dezert4Runner is offline   Reply With QuoteReply With Quote
Old 02-24-2022, 08:53 PM #3
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
The maintenance sticky at the top of this page has a video made by Tim on how to replace bushings.
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 02-25-2022, 10:13 PM #4
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
If you have a press and a bearing splitter, press out the bushings. If not, maybe invest in the tools. A Harbor Freight Press isn't that expensive and it's helpful for lots of projects like wheel bearings and other bushing work.
Old 02-26-2022, 11:18 PM #5
nissanh nissanh is offline
This is doable. I did it for the first time with the help of Timmy's video. Try to avoid the bottle jack method to press out the bushings. Instead use the bearing spliiter tool. Also use heat to expand so you gentle on the control arm.
Best is to use OEM bushings. Those are not expensive and can buy from Partsouq.com for a fraction of the price here in the US. Use Fedex shipping and you can get it in 4-5 days to your door. Enter the VIN and search the parts diagram.
1990 3L Diesel Hilux LN 106; 1973 Ford Cortina XL
1992 4AFE Toyota Sprinter AE 91 (aka Geo Prizm)
1997 5vzfe 4Runner 4x4 (aka Hilux Surf)
2000 2uzfe 100 Series Land Cruiser
2021 Tacoma TRD Off-Road 4x4 6-speed
Old 02-28-2022, 02:54 PM #6
If you heat the arm around the bushing a bottle jack should be fine, use common sense and don't over stress it. A 4WD bearing press (looks like a heavy duty C clamp) and cup and heat will work too.
bushings , entire , f150 , replace , uca
WTB used SPC upper control arm 3rd gen HiLife Want to Buy/Trade 0 09-21-2020 10:47 PM
Can you ID this Upper Control Arm? Ida4runner 4th Gen T4Rs 4 09-14-2020 11:36 AM
FS: OE Upper Control Arm (Set) - $100 (CT) Greydog For Sale: Suspension/Wheels/Tires 0 09-22-2019 10:41 AM
Upper Control Arm Pop Chilow 5th gen T4Rs 3 11-25-2018 07:19 PM
JBA HD Upper Control Arm Jdavera 5th gen T4Rs 5 11-19-2015 12:21 PM
