Originally Posted by nissanh
This is doable. I did it for the first time with the help of Timmy's video. Try to avoid the bottle jack method to press out the bushings. Instead use the bearing spliiter tool. Also use heat to expand so you gentle on the control arm.
Best is to use OEM bushings. Those are not expensive and can buy from Partsouq.com for a fraction of the price here in the US. Use Fedex shipping and you can get it in 4-5 days to your door. Enter the VIN and search the parts diagram.
If you heat the arm around the bushing a bottle jack should be fine, use common sense and don't over stress it. A 4WD bearing press (looks like a heavy duty C clamp) and cup and heat will work too.
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Sport 4WD, V6 5-Speed e-Locker->
4WD 4runner Journal Thread
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->
2WD 4runner Journal Thread
