Old 02-25-2022, 04:13 PM #16
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
Originally Posted by giguchan View Post
Thanks Peeps!!
One thing though.. if i leave it plugged in as an constant monitoring device will i have to unplug it from the OBD when the truck in in the driveway? I can't imagine it drawing much.
Thanks again..
Have been running a Scangauge 2 for past few years. It’s designed to remain plugged in at all times and will not draw down your battery when the truck is not in use and parked.
Easy to install and use. You can pick up a mounting bracket from Spiker Engineering (forum member) which places the Scangauge out of the way but perfectly visible for monitoring.
It’s a great product for monitoring engine vitals and also picking up codes.
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
Old 02-25-2022, 05:13 PM #17
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
Originally Posted by 4x3Lander View Post
I learned the hard way it WILL drain your battery. I left mine in all the time, didn’t drive the truck enough to get dead batteries. Thought OK, same battery as when I bought the truck, probably time to replace it. Replaced it. A month or so later, since I hadn’t been driving it, same thing with a brand new battery.
Thought I was going to have to search around for electrical gremlins. Then I read a similar post and someone asked if an OBD scanner was left plugged in. BINGO. Removed the OBD scanner and no more dead battery.
Mine has a small blue LED light that is on no matter if the truck is on or not. So I wouldn’t leave the OBD scanner plugged in.
That's odd. I've had an Ultragauge plugged in for a year and a half, more or less. Still running the 5 year old Interstate battery the truck came with and no drain on the battery.
From their site:
"UltraGauge wired is very low power while in use and enters an ultra-low power mode when the ignition is switched off. UltraGauge wired may remain connected without concern for potential battery drain."
[IMG][/IMG]
257K - Y2K/E - Clock still works
Old 02-25-2022, 05:20 PM #18
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
The power supplied to the OBD2 port when the car is not running is nominal. I leave my BAFX plugged in all the time, no issue or impact to the battery in years.
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 07-18-2023, 07:54 AM #19
DWilliam DWilliam is offline
DWilliam is on a distinguished road
Bumping this thread to see what app people are using for iPhone for a bt/wifi scanner? I got the Veepak, seems to have great reviews, but the torque pro app has horrible reviews. Is it still the recommended app for 3rd gens or is there another one to check out?
DWilliam is offline   Reply With QuoteReply With Quote
Old 07-18-2023, 10:42 AM #20
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
Are you opposed to running a ScanGauge?
Sent from my SM-S908U using Tapatalk
Old 07-18-2023, 11:06 AM #21
I use DashCommand on my iPhone with a Carista Bluetooth dongle.
Old 07-18-2023, 12:15 PM #22
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
... the torque pro app has horrible reviews...
What exactly is cited as 'horrible' about Torque Pro?
2001 Limited 4WD - 340+K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL - StopTech ANGLED rotors - In series 699 trans cooler, New Yota1 transmission, All new OEM suspension front to rear.
Old 07-18-2023, 01:02 PM #23
Just going off the fact that they have 2.5/5 in the App Store and 99/100 recent reviews say it doesn’t work. That’s why I asked here for first hand recommendations. This will be my first time owning my own scan tool.
Old 07-18-2023, 02:18 PM #24
I have torque pro on my android tablet and it works just fine.
Look at a hand held scanner that’s updatable. I have an Innova scanner that reads live data and freeze frames as well as certain abs systems.
auto , running , time , tired , zone
Long time reader - first time posting wlfmachine New Members 15 04-30-2019 05:57 PM
New code reader Help Ifirefight 3rd gen T4Rs 5 06-15-2018 05:57 PM
Long time reader, First time poster Bandit Runner New Members 3 07-23-2017 08:20 PM
Recommended Code Reader? SaltineAmerican Classic T4Rs 5 08-23-2016 02:17 PM
Code Reader Input on '05 thefatcat 4th Gen T4Rs 3 02-23-2009 07:37 PM
