Originally Posted by giguchan
Thanks Peeps!!
One thing though.. if i leave it plugged in as an constant monitoring device will i have to unplug it from the OBD when the truck in in the driveway? I can't imagine it drawing much.
Thanks again..
Have been running a Scangauge 2 for past few years. It’s designed to remain plugged in at all times and will not draw down your battery when the truck is not in use and parked.
Easy to install and use. You can pick up a mounting bracket from Spiker Engineering (forum member) which places the Scangauge out of the way but perfectly visible for monitoring.
It’s a great product for monitoring engine vitals and also picking up codes.
