You could try some penetrating oil and carefully heating the aluminum to try and get it to expand enough to get the bolt to wiggle loose?
Just don't set yourself or the vehicle on fire?
The other option that is probably a little safer if you can do it is to cut the bolt off as flush to the top of the cylinder head as possible, drill it out and tap it for a new one. Though that could also end in disaster if you're not careful.
