Old 02-27-2022, 06:41 PM #1
aontkos's Avatar
aontkos aontkos is offline
aontkos will become famous soon enough
aontkos's Avatar
Intermittent RPM Drops and Stalling- TPS?
I have been chasing an intermittent and seemingly random problem with my truck for a few years (2000, 3.4L, automatic transmission). It was infrequent and unpredictable enough that I've mostly ignored it, but it has become a little more predictable and I've stalled in traffic a few times, so it's time to nip it in the bud.
The problem usually occurs when the engine is warm and the air temperature is hot. It pretty much only happens when accelerating from a stop and seems the worst in stop and go traffic. When I accelerate, the RPMs will drop suddenly. It only lasts for about a second, then it returns to normal. Unfortunately, it has also stalled 2-3 times now in stop and go traffic. It will drive normal for months on end and then the problem will come back, usually after returning to stop lights after being on the interstate. It seems to only occur at low speeds and while coasting or accelerating in first gear.
I have never gotten a CEL when this occurs.
In the last few years I've replaced the following and the problem still occurs:
-IAC (OEM)
-Injectors (MotorWest Performance)
-MAF (OEM)
-Fuel Filter
-Vacuum Lines (silicone kit)
-A/F Ratio Sensor (OEM)
-Spark Plugs and Wires
I am currently at a loss, but I am leaning towards replacing the TPS. Any insight before I place an order for one? I almost feel like it's my last option!
aontkos is offline   Reply With QuoteReply With Quote
Old 02-28-2022, 11:41 AM #2
Twisted Sid's Avatar
Twisted Sid Twisted Sid is online now
Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about
I had something similar happen on my '99 (partially why my sister gave the 4runner to me) but it would throw a CEL for the TPS. She had the TPS changed before but with a cheap aftermarket one so i changed that out with a used OEM one and it went away for a few months but came back. Was poking around with it idling and when I moved the TPS harness, the idle would change and drop down to where it should be. Zip tied the harness up in that position and the problem went away. So I went to the junkyard and cut the TPS harness out of another 3.4 and spliced it in and the problem never came back.
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
Twisted Sid is online now   Reply With QuoteReply With Quote
Old 02-28-2022, 01:05 PM #3
spartacus's Avatar
spartacus's Avatar
-IAC (OEM)
-MAF (OEM)
-Fuel Filter
A new pcv valve might be a good low cost part to throw at it and see if it helps.
Old 03-01-2022, 10:43 AM #4
aontkos's Avatar
aontkos's Avatar
Originally Posted by Twisted Sid View Post
I had something similar happen on my '99 but it would throw a CEL for the TPS..
Thanks for the insight! I checked out my harness last night and it seem to be in good shape.
That's cheap enough that I'll throw another one in. I'm pretty sure I replaced it about 45K miles ago, so I'm probably due for it, but I noticed the problem while that initial replacement was relatively new.
Just as an update, I decided to unplug my TPS from the harness last evening to see how it ran without it. Oddly enough, if I revved the engine with the sensor unplugged, it would stumble when it tried to idle again. The RPMS would drop in a way that is similar to what I experience in stop and go traffic. An OEM replacement is on the way. I never got a code for the old one and the resistance seemed to check out with my multimeter, but it's worth a shot...stalling in stop and go traffic on the highway sucks.
Old 05-06-2022, 02:25 PM #5
aontkos's Avatar
aontkos's Avatar
I just wanted to post a follow-up on this thread in case it turns up in someone's search.
I came across this thread and it described my problem perfectly. The OP remedied the issue with a new evap/charcoal canister and a new crank position sensor.
I went ahead and replaced both as well, so hopefully my stalling issue is resolved. It was random enough that it could take a while to find out if the problem is truly fixed, but I am hopeful.
occurs , oem , problem , stop , traffic
Intermittent Stalling at Low Speeds/Braking/Deceleration beefsix 3rd gen T4Rs 10 02-20-2022 11:37 PM
HELP! Intermittent Stalling, tried everything. cbr900boy 3rd gen T4Rs 94 01-14-2022 12:03 PM
85 22re with intermittent starting/stalling issue blackchild Classic T4Rs 25 06-07-2017 03:59 PM
Intermittent stalling nvestor88 3rd gen T4Rs 9 06-21-2015 01:31 AM
3vze intermittent stalling, EGR? ozzyleven Classic T4Rs 3 02-17-2012 09:07 PM
