Old 03-09-2022, 06:25 PM #1
JD2tall's Avatar
JD2tall JD2tall is offline
JD2tall is on a distinguished road
JD2tall's Avatar
Question Strange Buzzing Noise
I’m hoping I can gain permission to post a thread about this buzzing issue I’m having. Seems like the sound is coming from the EVAP canister apparatus, but I need to get some more information.
The next picture shows a hose which by disconnecting, completely eliminates the noise.
If I let my engine run for a few minutes and shut it off, pressure gets built up again enough for the buzzing to continue.
The buzzing continues even after months of having kept it in storage with the battery disconnected.
I just noticed today that by disconnecting the specific hose, the buzzing goes away.
What do I need to replace?
What are the causes of this?
How much will replacement of appropriate parts cost?
Here’s a brief YT video I made demonstrating the issue
JD2tall is offline   Reply With QuoteReply With Quote
Old 03-09-2022, 06:35 PM #2
Ron Helmuth's Avatar
Ron Helmuth Ron Helmuth is offline
Real Name: Uhhh this is my real name
Ron Helmuth is on a distinguished road
This is not unusual for the vapor canister to release pressure/make noise after engine shutoff. This is fairly well documented amongst the 3rd gen 4Runners.
I would not be overly alarmed, as long as your emissions seem normal, meaning they test within reasonable limits and so on.
The video was helpful, I could not tell that your engine was running, so all seems normal.
If this noise were to be constant -for example with the engine running, then you may have cause for concern.
06 4th gen V8 4WD of course...
08 Honda Ridgeline RT
05 Scion xB-the toaster-daily driver
my Yota Fanatic photos are on Facebook- here is link:
http://www.facebook.com/album.php?ai...5&l=5795132731
Ron Helmuth is offline   Reply With QuoteReply With Quote
Old 03-09-2022, 07:39 PM #3
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
96Red did the same though different sound after 200k mi or so never an issue for 174k mi - wreck totaled - crusher, ha.
Old 03-09-2022, 10:22 PM #4
thundercloud01 thundercloud01 is offline
thundercloud01 is on a distinguished road
buzzing
I have a buzzing while getting driving and intermittently.. read somewhere it's the brake booster.. could this be it?
thundercloud01 is offline   Reply With QuoteReply With Quote
Old 03-10-2022, 09:21 AM #5
Real Name: Mark
Real Name: Mark
No, in 01 it was moved to rear above spare tire. What you have is the stability control buzzer going off, system needs calibration. Read up on it.
Old 03-10-2022, 09:47 AM #6
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
I thought the ABS pumps did a self test once they reached a certain speed each start up. Maybe he is hearing that? Only happens once per trip though.
Old 03-10-2022, 01:31 PM #7
Real Name: Mark
Real Name: Mark
Misinterpreted the post, brain fart.
Yes pump motor running makes a noise.
Old 03-10-2022, 01:55 PM #8
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
01 and 02 are both back near spare tire. I didn't know if it switched in 1999 or 2000.
Old 03-10-2022, 02:37 PM #9
Real Name: Patrick
Real Name: Patrick
Evap canister are under the hood on my 2000's
Old 03-10-2022, 03:01 PM #10
The later model (but pre 01/02) evap canisters had a slightly redesigned section right there to eliminate the buzzing sound. It is/was some sort of resonance in the canister and doesn't affect function. I think there is even a TSB about it if you search.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 03-10-2022, 06:00 PM #11
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
That answers that question. all under hood till 2000 then moved to spare tire 2001 and 2002..:-)
Old 03-11-2022, 02:32 PM #12
More info: 4runner-evapbuzz - bugeyebug
Old 03-12-2022, 03:29 PM #13
hntz4x4 hntz4x4 is offline
hntz4x4 will become famous soon enough
Too bad the the part needed to fix the buzzing is no longer available. My 96 does same thing, kind of annoying.
hntz4x4 is offline   Reply With QuoteReply With Quote
buzzing , disconnecting , hose , i’m , noise
Strange buzzing sound from dash under acceleration..... AlphaQup 4th Gen T4Rs 8 12-28-2020 12:51 AM
Strange buzzing sound from cabin Memphis_Jeff 3rd gen T4Rs 12 07-28-2018 09:11 PM
Won't start strange buzzing noise from behind glovebox mfpcopy 3rd gen T4Rs 1 12-19-2011 02:02 PM
