Originally Posted by ladrhog
So I haven’t got
The motor totally installed yet. It has sat for two years and I was trying to use the fuel pump to pump out the tank. I have fuel line disconnected just in front of the tank. I have plugged in all the sensors but the starter is not installed yet. I did try with the key in the start position.
How I read the wiring diagram is I have keyed power at C6 which turns off and on with the key. The blue and orange wire had power coming out of C6. It never get to the blue and orange wire on the plug for the fuel pump.
According to the EWD for a 2000 5VZ, the fuel pump relay (called “circuit opening relay”) is only closed when the starter is running and when engine is running. It is controlled by the ecm. The ecm needs to see starter engagement (also ecm controlled) and engine rpm indicating the starter is engaged and rotating the engine. Like I said earlier, the fuel pump only runs while starting or engine is running.
EDIT: This is how the fuel pump operates for all 3rd gen 4Runners with gasoline engines.
2000 SR5 V6 Manual 4WD
https://www.toyota-4runner.org/3rd-g...biography.html
