Old 03-17-2022, 12:19 PM #1
maxthebird maxthebird is offline
maxthebird is on a distinguished road
Rear brake hose replacement
Been doing some refreshing of my 1998 4runner Limited and planning to replace the front and rear brake hoses. The fronts are readily accessible but the rear hose is up above the rear end and hard to see. Looking for some guidance on replacing it. Found one video on youtube that addresses it but it's not very clear and says that it's very difficult and requires special tools. Has anybody else had the need to do this and is it that difficult? It's not leaking, but is 24 year old rubber and I don't want it to suddenly let go.
Thanks in advance.
maxthebird is offline   Reply With QuoteReply With Quote
Old 03-17-2022, 12:52 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
I replaced front and rear soft lines with braided steel lines on my Limited. Only took a couple flare nut wrenches of the correct size for the fittings and a screwdriver and hammer for the line retaining clip. Make sure your rear brake bleeders work before replacing the line.
Old 03-17-2022, 12:55 PM #3
The '96-'00 4Runners are just a single line. Nothing special if you have the tools to replace any other brake line - flare nut wrenches, etc.
Remove the spare tire, roll the rear up on ramps and you'll have plenty of room/access.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 03-17-2022, 01:24 PM #4
Spiker Engineering's Avatar
Spiker Engineering Spiker Engineering is offline
official vendor
Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of
official vendor
Here are some photos of the single line ('96-00), old and new. Just two connections, one on top one on bottom. Hope these help.
High Lift Hood Struts | Ultragauge/Scangauge Mounts | Phone Mounts
Custom 3rd Gen 4Runner products | 100% designed, fabricated, and assembled in the USA
https://spikerengineering.com
Spiker Engineering is offline   Reply With QuoteReply With Quote
Old 03-18-2022, 12:16 PM #5
Thanks for the pics and all the responses. Exactly what I was looking for. Looks very doable.
Old 01-02-2025, 04:17 PM #6
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
Im replacing my my soft lines, can I completely drain the fluid so I dont make a mess when I remove the line.
I saw a video where the guy uses vice grips on the old hose to hold back the fluid, but I dont have vice grips.
1998 4runner 2.7 manual
Pyral is offline   Reply With QuoteReply With Quote
Old 01-02-2025, 04:32 PM #7
Reinout's Avatar
Reinout Reinout is offline
Real Name: Reinout
Reinout will become famous soon enough Reinout will become famous soon enough
Reinout's Avatar
Real Name: Reinout
Hey, You CAN completely drain the fluid, but there's a bigger chance of trapping air making bleeding a little more difficult and could potentially put air into your master cylinder. You could use a plug of some sort to do the job as well and keep the brake fluid from running out to some degree.
Any sort of clamp could function as well.
Good luck!
1997 4Runner SR5- ~376k Miles and counting
2007 4Runner Limited V6- 175k Miles
2011 VW JSW TDI- 150k Miles
2006 Scamp trailer 16'
Reinout is offline   Reply With QuoteReply With Quote
Old 01-02-2025, 07:00 PM #8
2TH4IST's Avatar
2TH4IST 2TH4IST is offline
2TH4IST is a name known to all 2TH4IST is a name known to all 2TH4IST is a name known to all 2TH4IST is a name known to all 2TH4IST is a name known to all 2TH4IST is a name known to all
2TH4IST's Avatar
Do not completely drain the system! Bleeding a early abs system is a royal PITA. Do no pinch off any lines. They can cause a tear inside the hose. You can't clamp a hard line.
Use a vacuum plug to cap off the hard brake line.
Start by taking off the vehicle side of the hard line first, cap the line, then replace the soft hose. Then uncap the line and tighten it to the soft hose. It's messy no matter what you do. But water cleans up brake fluid nicely.
Then bleed the brakes normally.
There's danger lurking around every corner, that's why I propose we make all of our buildings round.
I don't remember the time I was human that's why I don't understand anybody.
2TH4IST is offline   Reply With QuoteReply With Quote
brake , clear , difficult , hose , rear
Front Brake Hose Replacement Sithlord 3rd gen T4Rs 11 02-07-2022 08:43 PM
Rear Flex Brake Hose garn79 3rd gen T4Rs 7 06-08-2020 01:35 PM
Rear brake hose torque spec? Spktyr 3rd gen T4Rs 9 11-12-2018 07:46 PM
V8 Radiator Hose - Silicone hose replacement? t-rex grrr 4th Gen T4Rs 3 10-16-2015 12:14 AM
Rear brake pad replacement jambo 5th gen T4Rs 4 05-09-2015 07:10 PM
