Old 05-23-2022, 05:54 PM #31
Originally Posted by JoeT4R View Post
So 1.) can you still run it without using a tube for oil changes? and 2.) I don't run a front skid, which is what makes me reeeeeally hesitant to try it out. I don't wanna press my luck and potentially run the risk of catastrophic failure God forbid some kind of weird crazy accident happens!
First of all, get a front skid on there. I'd be way more worried about that unprotected plastic radiator than I would be about a piece of brass that is tucked up higher than the bottom of the radiator.
Get the one with the nipple. Even if you don't use it, it won't get in the way.
I leave the hose just barely sticking out of the skid plate 100% of the the time. If it gets ripped off, I'll just replace the hose. The valve itself is way protected up there.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 05-23-2022, 07:56 PM #32
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
Originally Posted by shadow247 View Post
I have a Fumoto on my wife's Subaru. I have changed the oil 4 times now. It's a simple affair now. I literally drain straight to the waste container and don't have to worry about the drain pan or any splashing at all.
If only these 3rd gens had a better Oil filter design. I really need to grab a form-a-funnel, but I never do. I need to get my buddy to 3d print something that will work.
I haven't put a Fumoto on my 3rd gen yet, but I think I will next oil change.
Just do the bag trick I mentioned earlier, you'll need to put the filter in a ziploc anyway when you recycle it.
1998 4runner 2.7 manual
Pyral is offline   Reply With QuoteReply With Quote
Old 05-23-2022, 08:45 PM #33
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
my current rig came without the rear skid.( someone removed and not put back) .so no issue there. Yes the factory front skid helps protect the radiator. Yes I agree the oil filter on these is a pain...but believe me , I have delt with many worse .
Old 05-25-2022, 08:25 AM #34
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
Rear skid and fuel filter skid don't do much both taken off left off, running without front skid a stick could ruin your day.
Been considering Fumoto valve since they gained popularity, I don't like the nipple running up into oil pan keeps
you from getting all the oil/gunk out of pan. Kind of OCD but over the long haul you'd have a buildup.
Like 3bears said there are worse filters out there, I've done it enough times now as long as I didn't tighten filter too tight it a piece a cake. Cardboard under the area and brakeclean is part of oil change.
Old 05-25-2022, 10:33 AM #35
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
The nipple is outside the pan for an optional hose to attach to, not protruding up into the oil pan (if I understand when you are suggesting).
Note to self: take off rear skid plate BEFORE changing the oil.-valve-jpg
Old 05-25-2022, 12:41 PM #36
Real Name: Mark
Real Name: Mark
Threaded nipple is 1/2"-5/8" long subtract thickness of pan and crush washer what's left protrudes into pan,
there's oil and sludge left behind with every oil change.
Old 05-25-2022, 12:49 PM #37
Real Name: Blair
Real Name: Blair
OK - I see what you are saying. i will drain with valve and then pull the valve next time and see what more comes out. If it's measurable, then you may have a point. Sludge isn't coming out on its own, regardless.
Old 05-25-2022, 01:45 PM #38
Methinks you need to look inside the oil pan. There is a welded nut (basically) that protrudes just as far into the pan as the Fumoto valve. You aren't losing any ability to drain the oil or gunk out.
Old 05-25-2022, 02:21 PM #39
Real Name: Mark
Real Name: Mark
I'd be interested in hearing the results won't be much oil left behind but some not knocking throwing out
first thoughts I had using it priority for getting one like the idea.
Sludge not coming out on it's own yep.
Spray tube that comes with can of brakeclean can be heated with Bic bend offset in it
spray inner sides and bottom of pan see what comes out, chit you do after buying
200k mi ride with questionable maint. records, Ha.
Old 05-25-2022, 02:36 PM #40
Real Name: Mark
Real Name: Mark
I'll do that, no further than I've looked was thinking the threaded nut plate was like 1/8"- 3/16" thick or so reason for fine threads on plug. Might get convinced to go with it.
change , oil , plate , skid , top
5th Gen Genuine Toyota OEM front skid plate (not a PRO skid plate) - $50 (North Seatt SI2IS2T4R For Sale: T4R Items 0 05-27-2021 12:14 AM
How are you changing transfer case fluid with RCI skid plate on? boyfester 5th gen T4Rs 3 01-09-2018 07:44 AM
WTB Plate rear bumper and lift skid plate ebrake92 Classifieds - buy & sell (no commercial ads please) 0 03-15-2011 01:24 AM
Deck-plate Mod. Note Jack Abraham 3rd gen T4Rs 2 10-02-2008 07:29 PM
