Old 03-17-2022, 08:55 PM #1
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
Whine coming from power steering pump + bubbles in the fluid NOT after fluid change
I went on a road trip this spring break to Glacier National park. I bombed down some pretty rough trails (not in the park obviously) and probably plowed snow with the underside of my car a few times, but I donÂ’t think it was unreasonably hard on the 4runner.
IÂ’m now driving back to my school and at an overnight stop I noticed my power steering pump was behaving strangely. When IÂ’d turn the wheel the power steering pump would whine. This whine is the same one I heard after I flushed the power steering and just like then there were bubbles coming up in the power steering fluid.
The dex III in the pump is still clean, the fluid level does looks to be on the lower side but I donÂ’t think itÂ’s changed since I did it. Are there any common leak points in the power steering system?
Do these symptoms rule out the steering rack?
1998 4runner 2.7 manual
Pyral is offline   Reply With QuoteReply With Quote
Old 03-17-2022, 10:16 PM #2
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
Power steering cooler line? On the 2010 it's in front of the a/c condenser near the bottom. I tore mine off on the trail which left me stranded after the pump seized almost immediately afterwards. Actually couldn't even turn over my engine. Had to walk like three miles to the highest point just to get a good enough signal to call 911 (middle of Arkansas forest nowhere)! Talk about embarrassing! I relocated it higher up.. on each end of the cooler line are rubber hoses that hang down pretty far, it's retarded. I would bet your leak is there.
Jakeepoo3 is offline   Reply With QuoteReply With Quote
Old 03-17-2022, 11:05 PM #3
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
Does the third gen have a cooler line in the same place as a 2010? Wait, this is power steering not AC
Yeah its scary getting stranded. When I got stuck I had nothing to recover myself with, not even a shovel. I had only 32 oz of water. I had the cheapest sleeping bag so when the temperature dropped to 10 I was wearing 3 layers of heavy winter clothing and using kerosene hand warmers just to not feel cold. I walked 4 miles down trail to a road the next day, I’m really glad I packed a paper map sense there was no cell signal.
Old 03-18-2022, 01:13 AM #4
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
3rd gens don’t have a power steering cooler.
Old 03-18-2022, 01:18 AM #5
Real Name: Patrick
Real Name: Patrick
Is your pump or reservoir wet? Do you see any sign of power steering leaks?
Common places to leak are the inner tie rod seals which are covered by the inner tie rod boots so you won’t really see it, the power steering hard lines can corrode and lose fluid but they make a big mess, and the o ring between the power steering pump and the reservoir. You could have bubbles in the fluid because you are that low on fluid, a bad seal in the pump allowing it to suck air in (not likely usually it leaks rather than sucks air), or it could be a bad reservoir o ring (but those usually leak as well).
Old 03-18-2022, 01:39 AM #6
Jakeepoo3's Avatar
Jakeepoo3's Avatar
No cooler line then go with bad luck he's always making sure my information is legit 😘
Hey bad luck look at the stop lamp post I've been trying to help this youngster figure out. Check up on my information see if this guy really needs a new abs actuator module.
Old 03-18-2022, 02:03 AM #7
Jakeepoo3's Avatar
Jakeepoo3's Avatar
Haha I love it! Same here I woke up the next morning nearly frozen to death. I reckon I should have setup camp and started a fire but I figured I would be warm enough. Nope. I continue to go solo anyways👽
Old 03-18-2022, 09:26 AM #8
Real Name: Patrick
Real Name: Patrick
If it’s not a 3rd gen I don’t know much about it lol
Old 03-18-2022, 09:54 AM #9
Jakeepoo3's Avatar
Jakeepoo3's Avatar
Well fine! If you know one you got the jist of em all. I guess working on these newer gens takes some electrical and networking learnin. That's why you always catch me answering 3rd generation questions. That sh1t is easy without all the entanglement
Old 03-18-2022, 11:53 AM #10
heat's Avatar
heat heat is offline
heat will become famous soon enough heat will become famous soon enough
heat's Avatar
Something you've yet to demonstrate.
'02 Limited 4x4 AT - Stock ~181k miles
Thundercloud aka metallic dirt
heat is offline   Reply With QuoteReply With Quote
Old 03-18-2022, 02:11 PM #11
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
You did clean the reservoir filter when you did the PS service right?
2000 4Runner Limited 4x4 V6
Old 03-18-2022, 02:24 PM #12
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
Next time saw or cut the PS belt off if the pump seizes up (or is it a serpentine on those new-fangled things?). Actually I shouldn't even mention your modern oddity here in 3rd Gen land....
Old 03-18-2022, 02:37 PM #13
Jakeepoo3's Avatar
Jakeepoo3's Avatar
Yes sir it's serpentine. Kind of need that. I'm a judgement free zone mention whatever you please! It won't happen again I moved the cooler line further up 🦊🦉
Old 03-19-2022, 06:09 PM #14
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
It got me home yesterday. Before I left I bought dex 3 and tried topping it off, a quick test in the parking lot seems to indicate that it just needed more fluid. I don't think the fluid ever was far above the minimum level.
I did not clean the reservoir filter out when I flushed it. Instead I poured new fluid into the reservoir as someone turned the wheels, I disconnected the return line and had it drain it into a bucket. The old fluid was dirty.
I cant find any sign of it leaking, if it is its not obvious. No puddles under the vehicle. The 4runner is dirty from its trip, so I haven't felt like crawling under it.
Old 03-19-2022, 06:43 PM #15
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
i agree and timmy does a video on it.....get a spare o ring before taking apart
fluid , power , pump , steering , whine
Changed power steering fluid, are bubbles normal? Pyral 3rd gen T4Rs 2 10-09-2021 12:16 AM
Power Steering Fluid Change mwebster22 5th gen T4Rs 5 03-17-2017 07:34 AM
Change Power Steering Fluid ALLEGRO General Discussions 3 05-21-2015 11:16 PM
Power Steering Fluid Change ALLEGRO 4th Gen T4Rs 4 05-15-2015 08:08 PM
Problems with new power steering pump/ new pump with fluid. no power steering? cdcrone123 Classic T4Rs 3 08-27-2013 09:29 PM
