Old 03-19-2022, 01:09 PM #1
Lunarphase's Avatar
Lunarphase Lunarphase is offline
Lunarphase is on a distinguished road
Lunarphase's Avatar
285 R16 Ridge Grapplers with Toytec Ultimate 3" lift???
I'm looking to go the the next size up on tires. I have a Toytec Ultimate 3" lift and running 265 R16's. I also have the 1.25 spider spacers.
Looks like there is space to go to the next size up so I'm looking at the Ridge Grapplers in 285 R16's. Is anyone on here running this setup?
Any opinions appreciated,
Thanks
Yes I did a search but couldn't find a definitive answer, sorry
1999 4Runner SR5 3.4L 4x4 "Highlander"
ToyTec 3" Boss, Tundra Brake Up-Grade
Lunarphase is offline   Reply With QuoteReply With Quote
Old 03-19-2022, 02:18 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Thanks
What wheel you are using is also going to affect fitment. By the way, when you give or look up tires you need all 3 numbers. Tread width/aspect ratioRrim size. So in your case I’m guessing you are going from 265/75R16 to 285/75R16. If that’s the case then your tire is an inch wider and 2 inches taller. Which means an extra 1/2” in tread width on each side and an extra inch taller/further from center of wheel.
Old 03-19-2022, 09:14 PM #3
Lunarphase's Avatar
Lunarphase's Avatar
"So in your case I’m guessing you are going from 265/75R16 to 285/75R16" Yes
This is the tire I'm looking at (Nitto Ridge Grappler All- Terrain Radial Tire-LT285/75R16)
Original 99 wheels 16's
Thanks for the info. I'll get under and have a better look
lift , r16s , running , size , ultimate
FS Used ToyTec Ultimate 3" Lift Kit 5th Gen - $450 - Chesapeake, VA Cmpugh7 For Sale: Suspension/Wheels/Tires 5 01-09-2017 07:28 PM
About to purchase Toytec Ultimate 3" Lift, For or Against? EHNWI 4th Gen T4Rs 12 11-02-2013 12:55 AM
Toytec Ultimate 3" Lift w/ 265/75-R17 Tires glock56534 4th Gen T4Rs 9 11-30-2009 05:01 AM
Toytec Ultimate 3" lift + Mud = ;-) amt006 4th Gen T4Rs 4 07-14-2009 09:06 PM
