Old 03-26-2022, 08:32 PM #1
Boognish_Forever's Avatar
Boognish_Forever Boognish_Forever is offline
Boognish_Forever is on a distinguished road
OEM Bug Deflector Part Number
Can anyone confirm if this OEM Bug deflector part number PT42789011 is this style in the picture? Just want to make sure it wraps around the fender. I have a 99 limited if that matters. (PT42789011 - Toyota Hood Protector | Toyota, Gladstone OR)
Boognish_Forever is offline   Reply With QuoteReply With Quote
Old 03-27-2022, 12:59 PM #2
raty4R's Avatar
raty4R raty4R is offline
raty4R is on a distinguished road
raty4R's Avatar
That is a correct part number. It's either PT427-89011 or PT427-89990. One of these is for the hood scoop and one is for without.
Can't remember which one was for the hood scoop. At the time I bought both and didn't notice any difference between the two.
Here it is on mine
raty4R is offline   Reply With QuoteReply With Quote
Old 03-27-2022, 07:45 PM #3
Here it is on mine
Looks like the 89990 is for the sport. Thanks for the info.
Old 11-02-2022, 01:43 PM #4
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
This is an oem bug deflector that comes with new foam plugs and template of where to put them along with new pins.
Toyota part number PT427-89011 on a 1998 with a newer grille and headlights.
brillo_76 is online now   Reply With QuoteReply With Quote
Old 11-02-2022, 09:27 PM #5
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
As @jrm stated, AVS makes it. I'm currently rocking one and absolutely loving it. I opted for the one that doesn't go over the fender, just the length of the hood. It's held up well so far and I think it looks great. So AVS would be the way to go, if I were you.
Sent from my SM-S908U using Tapatalk
Old 11-02-2022, 10:52 PM #6
Originally Posted by jrm View Post
The 3rd gen specific hood deflector was "replaced" by a 4th gen specific hood deflector which uses the same 3rd gen specific PN PT 427-89011(89990).
Gee thanks toyota..
Anyway the same 3rd gen specific hood deflector that covers the hood and fenders is available from AVS:
Auto Ventshade [AVS] Bugflector II / Hood Shield | Dark Smoke | 25116 | Fits 1996 - 2002 Toyota 4Runner
Amazon link (not sure how long it will last) : Amazon.com: Auto Ventshade [AVS] Bugflector II / Hood Shield | Dark Smoke | 25116 | Fits 1996 - 2002 Toyota 4Runner : Automotive
You are correct sir, avs and oem are identical. I actually got a oem and it had some flaws, so I got a avs
Old 11-03-2022, 11:33 AM #7
jrm's Avatar
jrm jrm is offline
jrm will become famous soon enough
jrm jrm is offline
jrm's Avatar
Not sure how long ago that was purchased. On 11/2 i used that PN and the "see if this fits your 4runner" option it came back saying it doesnt: 2000 Toyota 4Runner Hood Protector - PT42789011 - Genuine Toyota Accessory
jrm is offline   Reply With QuoteReply With Quote
Old 11-03-2022, 04:00 PM #8
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
It shows to fit 01/02 4Runners so I don't see why it wouldn't fit 96-02 4Runners
Old 11-03-2022, 05:24 PM #9
jrm's Avatar
jrm jrm is offline
jrm jrm is offline
jrm's Avatar
Not sure why everything states it only fits 01. 02..
Old 11-03-2022, 05:26 PM #10
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I bought mine within the last year or 2. I can look up the date if anyone wants to know. Maybe the AVS is better for some. I like mine and I bought 2. I hope they didn't change them as that would be a bummer..
Old 11-03-2022, 08:58 PM #11
JoeT4R's Avatar
JoeT4R's Avatar
Worse case scenario you could always return it for free! The AVS comes with the needed hardware for install.
bug , deflector , number , oem , part
Part number and source for fender flare part Kyngfish 3rd gen T4Rs 12 12-29-2023 05:25 PM
How can i find the part name/ catalog number for a specific part 9405t4r 5th gen T4Rs 2 07-13-2019 08:53 AM
Does anyone know the name and part number of this part of a 2015 Grill? brian0128 5th gen T4Rs 4 05-15-2017 09:55 AM
Can't find a part number on a bolt, dealer part guy was an idiot yota-runner 3rd gen T4Rs 8 02-02-2016 08:00 AM
Help with part name and part number verification infamousRNR 3rd gen T4Rs 5 05-16-2015 10:08 AM
