Old 03-30-2022, 02:14 PM #1
4flyer's Avatar
4flyer 4flyer is offline
4flyer is on a distinguished road
4flyer's Avatar
Is this noise valve tape? Guessing I need a valve adjustment
Been trying to figure out what this noise is.
valve tick - YouTube
I know that one component is a VSV valve that needs to be replaced but there is in fact tap from the engine block itself. The noise only becomes apparent AFTER the engine has been warmed up to operating temperature for awhile. I talked to a mechanic that is going to do my rear axle seals and he said that valve shimming is very labor intensive.
Btw, been running Mobil 1 in the engine for years with regular changes. 250k miles.
What do y'all think? Is it in need of adjustment? Is this something to worry about? Feels like worrying about a sick kid!
2001 Limited 4x4 Black/Tan
4flyer is offline   Reply With QuoteReply With Quote
Old 03-30-2022, 03:41 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
We see what other think. To me thst sound more like a lower end knock then I injector or valve tick.
At 250 to 300k. The valves do need adjusted though as that's normal time for them.
Old 03-30-2022, 04:03 PM #3
Sounds a little more bottom-end-y to me too, but also sounds nicely regular unlike most bearing issues. Does it always follow the engine RPM? Does it get bad and then less bad on quick blips of the the throttle? (say, rev to 2.5k rpm and let off the throttle)
Get that ground hooked up again while you are in there...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 03-30-2022, 04:17 PM #4
JohnMc JohnMc is offline
JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all
It's kind of an inbetween sound. Not a nice lightweight tappy tappy sound, but not quite the deep heavy sounding clunk clunk of a rod bearing. But certainly tending toward the heavier side of the two.
Piston slap (pistons a bit loose in the bores) is worse when cold, when warmed up the pistons expand a little and quiet down some. So getting worse as it warms up doesn't track with that.
As mentioned, rev the motor up and down some and see if/how the sound changes as the motor revs up and down.
Possibly (hail mary) take all the belts off the front of the motor and start it up, see what it sounds like.
Shimming valves on a setup like this is a bit tedious, and there are 24 valves to deal with. You could try pulling the valve covers and eyeballing the cam and shim condition. if it's gotten loose and tappy, it's probably got visible signs of wear.
JohnMc is offline   Reply With QuoteReply With Quote
Old 03-30-2022, 05:53 PM #5
Why does half way through the video it looks like a hose not connected to anything?
As mentioned the ground is important to the sensors, please hook it up.
As mentioned before at your milage some of the exhaust valves will need adjusting.
Old 03-30-2022, 07:36 PM #6
spartacus's Avatar
spartacus's Avatar
To me the timing seems to be a bit off . Double check the timing marks to be sure.
Old 03-30-2022, 10:19 PM #7
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Sounds almost like a spark plug porcelain has cracked and is arcing/grounding out. You might try checking your spark plugs for carbon tracking. Otherwise, you should consider getting a mechanics stethoscope and trying to locate where it’s the loudest. Doesn’t sound like valve tap to me or Toyota tick (loud fuel injectors).
Old 03-30-2022, 10:19 PM #8
4flyer's Avatar
4flyer's Avatar
Originally Posted by phattyduck View Post
Sounds a little more bottom-end-y to me too, but also sounds nicely regular unlike most bearing issues. Does it always follow the engine RPM? Does itget bad and then less bad on quick blips of the the throttle? (say, rev to 2.5k rpm and let off the throttle)
It basically disappears when I get above 2.5k rpm Does not get louder, just faster. When you say "bottom-end-y", do you mean a deeper sound? The deeper noise is the VSV valve chattering away. I will replace that part and redo the video for everybody.
Old 03-30-2022, 10:44 PM #9
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Mine was higher frequency when I had a spark plug chattering as I had one PO that I don't think ever changed his spark plugs and half the electrode snap off and is stuck in the piston surface at 215k. Very good thought as maybe it sounds different. Mine was more like vavle tapping.
Old 03-30-2022, 10:53 PM #10
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
You really need those grounds bolted back up as those are very important as many users have suggested. The bolt head is 10mm and thread is 6mm x 1.25 or 1.00 ( I don't recall off the top of my head).
P.S. If you know something is bad like the VSV valve you really should fix it before doing a video asking people what they think the sounds are as extra sounds make it extremely difficult to properly diagnose..
As leaving hoses disconnected etc can and will effect other things.
Just thoughts for sound diagnosis.
Old 03-30-2022, 11:05 PM #11
4flyer's Avatar
4flyer's Avatar
Yes, I will run by lowes tomorrow. When I got the valve cover gaskets done a few weeks ago, the mechanic did not get everything back together properly...
Thanks for the help!
Old 03-31-2022, 01:39 PM #12
Jesus... maybe something got dropped into the engine or something. If the mechanic can't put back a very visible ground strap, what else was missed?
Old 03-31-2022, 01:57 PM #13
I swore I seen a hose in the video not connected to anything. I’ll screen shot it if I need too…..
Old 03-31-2022, 08:06 PM #14
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice
Romeo1's Avatar
It’s practically impossible to diagnose noise like this from video. Seems a bit intermittent though.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
Romeo1 is offline   Reply With QuoteReply With Quote
Old 04-02-2022, 05:36 PM #15
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
A have to agree with the others if a mechanic can't put bolts back in and hoses on. Goodness knows what else is messed up. That's a real shame as you are paying them to do the job correctly.
adjustment , axle , engine , noise , valve
V6-Valve adjustment, is it necessary? norcal2 4th Gen T4Rs 20 10-12-2017 09:18 AM
valve adjustment derezzed 3rd gen T4Rs 12 02-22-2011 11:43 PM
Valve adjustment pacesos 4th Gen T4Rs 1 02-14-2009 11:49 AM
Valve adjustment? rdgt4r 3rd gen T4Rs 16 01-11-2009 06:11 PM
Valve Adjustment Gryphon Maintenance/Detailing 1 11-14-2004 02:22 AM
