Old 03-31-2022, 08:29 AM #1
dta1984 dta1984 is offline
dta1984 is on a distinguished road
Driving with no rear driveshaft
I'm looking at purchasing a 3rd gen that needs some work. Currently, there is an issue with the Ujoint on the rear driveshaft. Instead of having it towed, I would like to just remove the driveshaft and drive it home .... about 30miles. It seems like this is do able, but just wanted to confirm. Any issues with fluid loss?
dta1984 is offline   Reply With QuoteReply With Quote
Old 03-31-2022, 08:37 AM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
I'm assuming it's a 4wd. It's possible with a few caveats. If it's a standard j-shift (96-00 SR5/Base) then put in 4HI. If it's a 99-00 Limited then put it in 4HI Locked (j-shift pattern with a button on the side of the shift handle). If it's a 01-02 you'll need to have it in 4wd WITH the center diff lock engaged.
The transfer case uses a flange for the driveshafts to mount to so you won't lose any fluid.
Make sure you are either already in 4wd or you chock the wheels before removing the rear driveshaft.
Also, in case you have to get a replacement driveshaft there are several different lengths so make sure you get one from your year range/transmission/transfer case.
Old 03-31-2022, 08:58 AM #3
Exactly what I was looking for! Appreciate the help!
drive , driveshaft , home , rear , remove
Will 01 rear driveshaft fit 99? YES!! drallan 3rd gen T4Rs 9 07-28-2018 07:32 PM
WTB: Rear driveshaft for 3rd Gen V6 4x4 Soulman For Sale: T4R Items 0 10-24-2017 09:28 PM
Driving without front driveshaft on V8 4wd t-man 4th Gen T4Rs 25 11-29-2016 08:17 AM
94 and 95 rear driveshaft? Graham567 Classic T4Rs 1 12-25-2008 11:13 PM
