Old 03-31-2022, 09:06 AM #1
flooredrunner's Avatar
flooredrunner flooredrunner is offline
flooredrunner is on a distinguished road
Intermittent battery light
Hello All,
As the title states, I have been getting an intermittent battery light. 5VZ SR5 with 310k miles.
I have a voltmeter in the car and it will go from 14.2-3 to 12.2 to 11.6 back to 14.2. Starts every morning just fine. I did notice that the wipers get slow when the battery light comes on.
My question is, should I just put a new brush kit in the OEM alternator that's in the truck now? Or should I get a generic parts store alternator? Could it be a bad voltage regulator? at 310k I'm sure the brushes are pretty worn out but dont know if that can cause intermittent light. Has never died.
Intermittent battery light-img_7217-jpg
2000 4Runner SR5, 5 Speed 286k. Bilsteinlifts Eibach/Toytec, RMR Matterhorn, 1552 tarmacHD, 33s, Daily Driver.
flooredrunner is offline   Reply With QuoteReply With Quote
Old 03-31-2022, 09:57 AM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Get a new brush kit.. the generic alts don't seem to last like the oem or densos do. If you don't wish to do the kit get either from rock auto or a Toyota dealer remfg denso alt. Unless you want to be changing it a pile of times and wasting alot of time with an generic parts store one.
Old 03-31-2022, 10:01 AM #3
I have the brush kit (part: 27370-75060) from the Timmy the Toolman video on order and will report back once I have completed the swap.
I agree, if that doesn't work I was looking to get a reman Denso from the dealer or RA.
Just seeing if anyone has had a similar experience that was fixed by the new brush kit.
Old 03-31-2022, 10:34 AM #4
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a name known to all JoeT4R is a name known to all JoeT4R is a name known to all JoeT4R is a name known to all JoeT4R is a name known to all JoeT4R is a name known to all
JoeT4R's Avatar
Deeeeeefinitely want to chime in on this one-- I had the same issue last August. I also second @brillo_76 's suggestions about replacing components/buying reman Denso unit from RockAuto. I had the same exact symptoms as you, and went through the process of replacing the battery first (which needed to happen anyways) and then ended up purchasing a reman Denso from RockAuto. While you're in there, if you do swap alternators, change the belts too since you'll have easy access to them, and they're cheap. But I've had great results (knock on wood) thus far with my reman Denso unit. Also, I purchased the reman alternator on a Tuesday at 11 AM, and it literally arrived the next morning by 0900. Paid for regular shipping, too. Pretty dope IMO. Best of luck!
Old 03-31-2022, 11:17 AM #5
Awesome! I will report once I have the new part installed!
Thank you for chiming in.
Old 03-31-2022, 11:24 AM #6
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Lots of people rebuild their alternators. I plan to rebuild a few here down the road I haven't done any yet.
Old 03-31-2022, 12:59 PM #7
Sparky 97Runner's Avatar
Sparky 97Runner Sparky 97Runner is offline
Sparky 97Runner will become famous soon enough Sparky 97Runner will become famous soon enough
I think you're on the right track by changing out the brushes. Super easy to do. Here's a picture of a set of brushes with 280,000miles next to a new set of brushes. I can hardly believe they were still working fine when I changed them out as a routine maintenance item. I seriously doubt they would have lasted another 30,000miles. So yeah, at 310,000miles you are due.
Intermittent battery light-alt-brush-jpg
1997 Toyota 4Runner
Sparky 97Runner is offline   Reply With QuoteReply With Quote
Old 03-31-2022, 01:54 PM #8
A new brush kit should get you another couple hundred thousand miles... then you can get a reman Denso for the new bearings, etc. since the shaft will likely be pretty worn by then.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 03-31-2022, 02:24 PM #9
JoeT4R's Avatar
JoeT4R's Avatar
Oh yeah, I forgot to mention this, too. And I'll quote @brillo_76 once again, SAVE your old alternator, especially if it's an OEM one. Even if you don't have the tools, parts or otherwise resources to rebuild it right away, I think you should hang onto it for that purpose alone so you can carry as a spare and/or install it back once the newer one goes out. That's what I ended up doing with my old one, although I forfeited the $30~ core fee from RockAuto. Which is fine. But I have every intent to rebuild it in the future, as it would be cool to learn something new
Old 03-31-2022, 06:51 PM #10
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
I picked up new brushes on my last parts order from Conicelli Toyota.
Threw them in the glovebox until I have some time to pull the alternator.
Figured with just over 200K on the odometer it’s just a matter of time before the need to replace them arises…..same goes for the starter.
That rebuild kit keeps the alternator brushes company in the glovebox.
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
Old 03-31-2022, 10:10 PM #11
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
I had the intermittent battery light, too, became chronic
Went to the junkyard, pulled an alternator, had it tested at parts store. Good.
Threw it in. Good
Took old alt to parts store for grins and giggles. Also good.
Scratched my head and put it on the shelf
2 weeks later, battery light again...
Long story short. My alternator plug on the engine harness was gunked up and not clicking into the alt, working itself loose.
Cleaned the plug out real well. Cleaned alt terminals real well.
Installed plug, tapped it home with a wooden dowel and mini ball peen hammer.
Been fine ever since.
Eventually I will need to replace brushes and bearings, no one is immune from that.
Check the plug, too
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 04-01-2022, 06:34 AM #12
19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold 19963.4lsr5 is a splendid one to behold
When I bought the 97 SR5 project it had a reman CarQuest 80a Alt in it. I put it in the 97 Limited Puppy Hauler when it’s 70a Alt’s diode block went bad. 30k later the cheep reman brushed wore out. (Just nubbies sticking out of the brush housing).
Put a set of OEM brushed in it. Remans are still factory Denso Alts. Just went through the reman bench.
Old 04-01-2022, 10:46 AM #13
Holy crap! Yeah the Tim the Toolmans brushes were pretty worn on his video.
Question: If it was the voltage regulator, could it also be intermittent like this or would it just crap out altogether?
I checked the connector on the back and it clicks in well and didnt look to have any corrosion. Will report back once I get the part installed.
Old 04-01-2022, 11:06 AM #14
spartacus's Avatar
spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of
spartacus's Avatar
You can test the voltage out put of the alternator by checking the battery voltage at idle which should be over 12.4 volts and then reving the engine to 1500 rpms, the voltage should jump up by at least 2 volts. A good charging range is between 13.4 to 14.8.
Also another option, is to take the alternator to a big box auto parts store and have them test it.
Old 04-01-2022, 01:08 PM #15
Ive done this, 14.3 consistently, but when the light comes on it will range from 12.2 to 11.6ish then will go away on its own.
310k , alternator , battery , intermittent , light
Battery Light + Whine + Low Idle + New Battery TT4RLtdV8 4th Gen T4Rs 23 06-17-2022 09:51 PM
4th Gen No Codes No Start & Battery Light On, It's not the battery! V8Man 4th Gen T4Rs 18 10-05-2019 10:35 PM
Intermittent INOP key FOB and the BAD cellphone battery pack rwrobs777 5th gen T4Rs 0 08-05-2019 11:23 AM
Please help - Engine shut off + Battery light, A/T Fluid light and OIL light Lamer 3rd gen T4Rs 11 09-03-2018 06:04 PM
intermittent tail light gimme789 Classic T4Rs 3 02-09-2010 02:36 AM
