Old 04-02-2022, 10:30 PM #1
Family_Wagon Family_Wagon is offline
Family_Wagon is on a distinguished road
Engine swap smog question
I’m at the point in an engine swap where as the saying goes “mistakes were made” to keep it short I have a 2000 engine in my 98. My question is if I keep the 2000 crossover pipe and modify my exhaust so the pre cat flange will mate with the 2000 crossover will I fail smog? I don’t see why I would but I don’t want to “solve” my problem by making a bigger one.
Any help would be greatly appreciated.
Family_Wagon is offline   Reply With QuoteReply With Quote
Old 04-03-2022, 11:33 AM #2
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
I'd like to believe if the system is sealed end to tailpipe along the way, an 02 sensor is present and the odb2 readings are all "Ready", why shouldn't it pass?
But then again this is government, for the people by the people....Luck.
Old 04-03-2022, 12:19 PM #3
That was my thought too but as much as I’ve hit my head already on this engine swap I figured it was worth asking the group before I shot myself in the 🦶🏼
There’s a smog shot across the street from the muffler shop I’m going to try to get the flange from so I’ll stop in there and see if they have any thoughts
Old 04-04-2022, 01:13 AM #4
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
It's better to transfer over both the exhaust manifolds and the crossover pipe from your old 98 engine to the 'new' 2000 engine. Is that no longer an option? Unfortunately you've learned the hard way that Toyota changed the pipes and didn't really tell anyone, I used to sell used parts and this was a hard one to explain to people.
If you can't swap them over you can weld them. My catalytic converter doesn't even have a flange, it's welded straight to the pipe and it passes smog. Technically, my exhaust is CARB illegal as I had the piping coming out of my headers increased to 2.5" instead of the stock Toyota 2.25" but who's ever going to know that unless I tell them?
Big thing is no leaks. If there's a leak it'll start to throw codes and codes never pass.
326WHP 347TQ
Old 04-04-2022, 01:36 PM #5
Yeah, the original motor is gone with manifolds 🤦🏻*♂️ I bought a used crossover that matches the flange on my cat but after 2 struggle sessions, one to remove the one on the motor and one to attempt to install the “correct” one we realized it wasn’t going to fix the problem. I’m taking the one that bolts to the manifolds that are currently attached to the motor and my cat to an exhaust shop today to see if I can get a flange with a chunk of pile on it that I can use to make happiness under there 🤞🏼
Old 04-04-2022, 01:44 PM #6
Technically illegal, but make it look stock and it'll be fine. You know, heat shields in place, etc.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
crossover , don’t , engine , question , swap
Engine Swap Question mtbtim 3rd gen T4Rs 32 01-14-2022 02:45 PM
Engine Swap Question That_One_Guy 3rd gen T4Rs 4 04-07-2017 05:07 PM
engine swap question.... ferretrodeo Classic T4Rs 11 11-16-2014 08:53 PM
Engine swap Question..does L6 engine fit into 1990 Hilux/4runner hjalti_gto Classic T4Rs 29 11-28-2011 09:34 AM
Newbie with Engine Swap question halo32c 3rd gen T4Rs 8 11-18-2010 10:05 PM
