Old 04-15-2022, 02:11 PM #31
Originally Posted by octanejunkie View Post
If the 3rd Gen 4runner is the same, anything over 2" may not be optimal. Can we discuss that?
Similar to the GX in the video, the gen3 4Runner stock droop is limited by the shock when installed, then next by the upper ball joint when the shock is removed. Extended length front coilovers require new upper control arms due to the increased length. With new upper control arms, the limit to droop will be the axles, just like the GX. The actual travel numbers are different, but the order of limitations is the same. This is all with stock arms, of course.
With 100% stock arms, I ended up with at 3/8" (actually, slightly over that - I think they were actually 11mm thick) top plate spacers to maximize the use stock arm travel (the lower arms get lifted just a bit to get the lower shock bolts in place).
By the numbers, on my 4Runner:
full extension (stock arms, pivot bolts loose): 25.25"
full compression (stock arms, pivot bolts loose, bump stops lifting truck): 16.75"
So, absolute max travel with stock arms/bump stops is 8.5"
I then set my front ride height at ~21.25" to give 4" compression travel and 4.5" droop travel, theoretically. I also went with the softest springs I had available to try and maximize front flex (V6 2WD springs) and verified the shocks don't bottom at full compression. It would be reasonable to go up another 1" if I wanted the look, before starting to lose too much droop.
I feel like I should check this on my ramps now...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 04-15-2022, 02:54 PM #32
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Now we're getting somewhere...
I feel like an Excel spreadsheet with the right formulas could be used to generate a lot of this information plugging in things like shock compressed length versus extended length, spacers and custom arms
I too will perform the ramp test and do some math based on my suspension components specs
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 04-15-2022, 03:20 PM #33
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Coil spring rate is also going to be a big factor in how much you flex. A 500 lb/in spring will compress/extend further than a 600 lb/in spring by a theoretical 20% for the same given input.
Old 04-15-2022, 03:42 PM #34
Spiker Engineering's Avatar
Spiker Engineering Spiker Engineering is offline
official vendor
Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of
official vendor
Charlie, just to be sure we're on the same page, is this from shock eye CL to bottom of top hat?
High Lift Hood Struts | Ultragauge/Scangauge Mounts | Phone Mounts
Custom 3rd Gen 4Runner products | 100% designed, fabricated, and assembled in the USA
https://spikerengineering.com
Spiker Engineering is offline   Reply With QuoteReply With Quote
Old 04-15-2022, 04:07 PM #35
No, hub center to fender lip, which allows you to measure with the wheel on or off. I was talking about wheel travel, not shock travel.
Haven't measured the motion ratio, but it should be around 2:1. Bilstein claims 4.61" of shock travel on the 5100's, which would generally confirm that (I had a little less than 1/2" of shock travel left at full bump with no spring when using nearly 8.5" of wheel travel). The OEM shocks are shorter than the 4600s/5100s, which is why those 3" spacer lifts kinda work.
Old 04-15-2022, 05:06 PM #36
official vendor
official vendor
Gotcha, thanks.
Old 04-16-2022, 02:44 PM #37
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice
Romeo1's Avatar
Originally Posted by Bad Luck View Post
Just gonna leave this here for anyone that wants to see a good explanation of the effects of spring perch height: 4 Common Myths About IFS Lifts | Everything About Toyota IFS Part 2 - YouTube
That’s a super cool video. Thank you for posting it. That guy explains everything perfect too.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
Romeo1 is offline   Reply With QuoteReply With Quote
5100s , front , lift , plate , top
Bilstein 5100s with rear spacer and adjusted front B.E. Coyote 4th Gen T4Rs 4 02-21-2021 06:06 AM
Not enough lift from Eibachs. Spacer or higher clip for 5100s? blairracd 3rd gen T4Rs 13 12-18-2020 12:11 AM
Will Bilstein 5100s set to 2.5 up front and 1.5 spacer in rear clear 285s jb24dolphins 5th gen T4Rs 9 06-02-2017 07:57 PM
FS: Toytec 1/4" Front Top Plate Spacer and 10mm Rear Coil Spacer ryhi For Sale: Suspension/Wheels/Tires 7 10-24-2011 02:01 PM
**SOLD** toytec 2.5'' spacer front lift and rear 1.5" spacer lift 4Runner8 Classifieds - buy & sell (no commercial ads please) 1 08-10-2010 06:06 PM
