04-17-2022, 12:28 AM
#46
Not sure if anyone has posted this link but I hope it helps anyone who has been looking. I’ve been running ethanol-free for years. I’m currently getting 20mpg combined highway and road driving and as high as 23 with longer highway trips (30+ miles). The increase Fuel cost is definitely worth the mpg increase as well as how much smoother it runs. Great piece of mind.
Ethanol-free gas stations in the U.S. and Canada
10-03-2022, 02:49 PM
#47
So, despite my previous statement, a gas station opened near me with E15. Never tried it before, and it was substantially cheaper than regular E10. Figured I'd give it a try because of the price point. I plan to run it consistently for a few weeks to see if there's a noticeable decline in mileage and overall performance. I'll be updating my build thread with the information.
10-03-2022, 10:53 PM
#49
Real Name: Jeff
Real Name: Jeff
Well I've been running E15 since I have no alternatives, and I assume many people are in the same boat. The rig hasn't exploded yet.
97 SR5 4runner: 2" OME Lift, rear E-Locker, 231mm Tundra Brakes, 203K, B&M 70264 Tranny Cooler, Duratracs
Build
10-04-2022, 12:09 AM
#50
Originally Posted by gamefreakgc
I think for more modern vehicles that can run on E85 or traditional gasoline, they make the same miles per gallon? Something about able to advance timing to take advantage of the high octane fuel making more power per stroke and increase MPG's. Obviously our antiquating 4Runners don't have anything like that.
I have heard of complete E85 swaps like someone else is doing that did not replace the fuel pump and the fuel lines. There's very few rubber parts along that path so it wouldn't be terribly hard to convert them either to stainless steel or some other flexible line. Those would be the only two components that would not be able to handle the increased fuel needs of having to compensate for E15.
The ECU will read it like this: because E15 has less energy density it'll start to run a little lean. The oxygen sensor (or 2001 later vehicles, Air Fuel Ratio sensor) will immediately increase fuel trims to compensate. I don't see a scenario where it would ever increase the long term fuel trims over 30% and trip a code, I don't think even E85 would do that. Over time, the ethanol could start to cause the rubber to deteriorate to the point of causing fuel delivery options. The pump should continue to operate as it's always on at the same rate, it doesn't scale with throttle. I do not think that fuel pressure will drop as the 4Runner doesn't max out the pump if naturally aspirated.
Overall, I believe based on my work on the 5VZ platform we should be fine other than the obvious MPG drop as it's less energy dense fuel. California has been E10 only for about 5-6 years now and I have not had any problems except for watching my MPG drop. Below is a chart of the drop, you can see the baseline go down in 2017. It'll be less severe with a 5% add instead of 10% add but you get the idea.
Originally Posted by phattyduck
You have the "slower burn" portion correct - but you have to ignite the fuel EARLIER (advance the timing) to get max torque from higher octane/ethanol content.
Of course, E15 fuel with the same octane rating as E15 fuel would likely burn at the same rate. The rest of the fuel could be lower octane to make up for the extra ethanol content.
This is good information. I never thought about it like this before.
I have a piggyback tuner, the Perfect Power SMT-5, that I can use to advance the ignition timing, alter the fuel maps, etc. I will do some testing this month with it to see how much more timing advance I can get away with running E10 fuel. These engines are tuned pretty good from the factory regarding the timing maps with regular 87 Gasoline. The Fuel Maps are also pretty good in Closed Loop mode with the ST and LT functions dealing with live conditions. But, you can tweak the maps a bit here and there depending on said conditions.
I will also take a look at Fuel Trims with my Scan Tool. I'll report back to this thread after I have gathered some data. I'll probably take a few weeks of logging fuel economy and timing advance adjustments.
2000 4Runner SR5 Manual Trans Federal Emissions - Eibach Pro-Truck coilovers, LC 7.5/Tokico Black, JBA UCA, SPC 25945 RLLs, Mevotech Supreme RULs, TrakMotive Xtended Travel CV Axles TO-8043ET, South Bend Rally Clutch, ES & Whiteline Bushings, MagnaFlow Cat-Back, Deck-Plate Mod, 4.56 Yukon Gears, Yukon Grizzly Rear Locker, Bushwacker Flares, 16x8 Wheels w/ 285/75 General Grabber AT2, 229K+ Miles
10-04-2022, 06:38 AM
#51
Have you been consistently running it for a while? How's your mileage? And all other factors associated with it like tire size/type, lift/stock suspension, daily driving conditions etc.
So far I'm not noticing a huge decrease in performance, and it could totally be placebo, but I feel like my rig is a bit less responsive than usual.
Sent from my SM-S908U using Tapatalk
10-04-2022, 12:21 PM
#52
The 5VZ ECU ignores the knock sensor below 3k RPM, so it will always use the 'default' timing in that area of operation. Since it is tuned for 87 octane, any 'extra' octane will decrease instead of increase performance. 91/93 is needed for the supercharged guys for this exact reason (can't pull timing with knock below 3k rpm - extra cylinder pressure = ping in those situations).
If you still get sufficient performance with E15 and fuel trims are still reasonably good, it might be better for the pocketbook, if not for performance.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
10-04-2022, 01:10 PM
#53
Real Name: Jerod
Real Name: Jerod
Be very careful with timing advance. I at one point had thought about getting a piggyback that could retard and advance timing but then I decided against it. Too many times I've had to fill up with less than 91 octane due to the pump being empty, or my wife forgetting what kind to put in and puts in 87. If I were to have timing advanced on top of that it could get really bad really fast. In order to gain MPG's from running timing advance, it would have to be in cruising RPM's from 1500 to 2500 RPM. That's our engine achilles' heel when it comes to pinging, my worst ping sets in around 2200 RPM. I didn't see anything about your engine being supercharged so that'll give you a little bit of wiggle room but you might encounter it. Please do so in no more than 2 degree increments - that's the general rule for timing. Up it by 2, test, if works ok try 2 more. Also be aware that ambient temperature plays a huge role and if you tune it in a cold day in the 60's and then drive it on a hot day in the 90's the result will be much different.
10-04-2022, 01:47 PM
#54
Thanks. I appreciate the concern but I've had this tuner for decades at this point. I never aggressively tune. I have several setups saved for different scenarios. Around town driving you can be a little more aggressive with your tuning vs on the trail for instance.
Also since I have a manual transmission I can pretty much being whatever RPM range I want by simply shifting. 😜
At any rate, thanks again and I'll post some thoughts when I get around to playing with this some more this week.
Cheers.
10-04-2022, 05:37 PM
#55
So ultimately if I'm not experiencing any adverse effects then I should be good to go to run it full time? So far I haven't noticed any pinging or anything out of the ordinary (knock on wood)
10-04-2022, 07:29 PM
#56
Real Name: Jerod
Real Name: Jerod
Cheers.
Yes I'd love to hear how it works out. It's a real shame our 4Runners cannot benefit from the ethanol that's becoming standard for fuel and this might be a way to do so. Really interested to see if you can boost up the MPG's.
10-04-2022, 11:28 PM
#57
Real Name: Jon
Real Name: Jon
Hmm. Maybe a missed something in this thread. If so, I apologize. How is decreasing the fuels efficiency a good thing?
I mean if you are loosing efficiency at 10% of ethonal added into the fuel. How is loosing more efficiency a good thing?
If you have to buy more fuel, you are not only not going as far on a gallon. You are paying more in taxes on said fuel to go the same distance. :/
10-05-2022, 09:12 AM
#58
There has got to be some stand alone knock retard controller that you can run the crank trigger through and install a GM or whatever sensor on the block to trim the crank signal.
10-05-2022, 02:47 PM
#59
You will always lose MPGs with ethanol compared to 'normal' gasoline, though not necessarily power (if you can tune for it). That part we are all on the same page with.
The question comes if the cost of higher ethanol gas is low enough to make up for the lower fuel economy.
Theoretical example:
E0 = 20mpg and $4.50/gallon ($0.225 / mile)
E10 = 19mpg and $4.00/gallon ($0.211 / mile)
E15 = 18mpg and $3.50/gallon ($0.194 / mile)
Clearly, even with the the lower MPG, total cost per mile can be better. This is why E85 (sometimes) makes sense for the end user. That, and it makes great race fuel for cheap!
PS. I am purposefully ignoring any discussions of whether or not ethanol actually should be in fuel from an environmental perspective...
10-05-2022, 03:18 PM
#60
Real Name: Jon
Real Name: Jon
Fair enough, I know in this state its $.58 per gallon which is bad, then I looked up CA ( Hold my beer ) and its at $.68 per gallon. :/
So the theory is if we can tune these engines to run E85 fuel then it would be better setup. Now, that I can understand. :-)
