Old 04-17-2022, 09:38 PM #1
5VZ-FE's Avatar
5VZ-FE 5VZ-FE is offline
5VZ-FE will become famous soon enough 5VZ-FE will become famous soon enough
5VZ-FE's Avatar
Stabilizer bar link ball joint
I noticed this while installing my Bilstien's.
The other side is in better condition, the ball joint on the bottom is still intact. Do I have to replace the whole assembly with part #48830-35020, or is there maybe a part number for just the ball joint? I'm gonna have to do the upper bushings too... (#48817-30020 for future reference)
‘98 T100 SR5 4X4 5spd (sold)
‘99 4Runner SR5 4x4 5spd E-Locker Unicorn
5VZ-FE is offline   Reply With QuoteReply With Quote
Old 04-17-2022, 09:56 PM #2
spartacus's Avatar
spartacus's Avatar
Replace the whole link, pretty common. After market links are cheaper and do just fine if you don't want to go the pricey oem route. Rock auto has a good selection. if you have a lift then you might need extended links from the 2nd gen. Sway bar end links compared or mstud sway bar links.
96-02 3rd Gen 4Runner Sway Bar End Links
Old 04-17-2022, 10:05 PM #3
5VZ-FE's Avatar
5VZ-FE's Avatar
Thanks, just what I was looking for
ball , future , joint , part , upper
Upper Ball Joint/Lower ball joint replacement Tigerfan86 4th Gen T4Rs 1 03-03-2020 03:10 PM
Leaking Upper Ball Joint - Replace UCA's or Just the Ball Joint tannerk15 4th Gen T4Rs 4 03-28-2017 08:53 AM
Leaking CV Joint or Ball Joint?? Hard to Tell - Pics Inside 4WDFTW 4th Gen T4Rs 21 11-06-2014 05:46 PM
Front Stabilizer Bar (Weak link) <<<< 4th Gen T4Rs 0 06-09-2012 09:40 PM
stabilizer link? Stromboli Maintenance/Detailing 4 06-02-2011 12:28 AM
