Old 04-21-2022, 09:53 PM #16
Mark_BC's Avatar
Mark_BC Mark_BC is offline
Real Name: Just call me the Grease Monkey
Mark_BC has a spectacular aura about Mark_BC has a spectacular aura about
Mark_BC's Avatar
I have OME 906 / Bilstein 5100's in the rear. It's stiff but I have it for when I load up and go off road so I put up with the stiffness around town.
It gives maybe 2" rear lift empty and 1" loaded, which is more than enough. I'm not sure what to do about the front. I still have stock front which gives it some rake which I'd like to remove. I don't want any more than 1" lift up front and I will soon put a heavy steel bumper on, eventually a winch too.
My Snow and Sand build thread
Mark_BC's 2000 Limited Salvage Build
Determined to keep them from becoming parts trucks. Yes, even the one I just picked up as a parts truck...
Mark_BC is offline   Reply With QuoteReply With Quote
Old 05-09-2022, 02:27 AM #17
crespoh69 crespoh69 is offline
crespoh69 is on a distinguished road
How would one of these old man emu kits compare to the 99 talls?
Complete OME suspension for 96-02 4Runner - OME-96024R
crespoh69 is offline   Reply With QuoteReply With Quote
Old 05-09-2022, 11:05 AM #18
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
880s will get you around 2" up front, 881s a bit more, but those are unweighted estimates.
Depending on the bumper and winch you get I found it a little difficult to predict how those items and suspension components will all combine to net out lift and ride quality
My bumper and winch install are pending on my current suspension setup, so I don't know how much things will change after the install, but my truck is level now
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 05-09-2022, 11:58 AM #19
spartacus's Avatar
spartacus's Avatar
Depends on what you are trying to acheive. I would suggest bilstein 5100 since I have no experience with ome shocks. you will get a higher ride height then 99 using this kit. Depending on the spring you choose. The on road ride will be stiffer then the 99 stock suspension but better off road using ome kit.
You will get 1.5 880 or higher with 881 don't go with 883 if you don't have a heavy bumper with winch in the front and 2 inches. 906 in the rear are probably one of the best springs for stock weight and a 2inch lift which will give you a 1inch higher stance then a 99 spring.
kit , lifted , lowered , overkill , truck
Suggestions for Lift kits Coolman 3rd gen T4Rs 0 07-11-2015 08:34 PM
Shock suggestions hang10 3rd gen T4Rs 2 02-02-2015 05:30 PM
Shock suggestions Buckleturd 3rd gen T4Rs 4 06-19-2013 02:12 PM
Suggestions: HID conversion kits (PURE WHITE) ronnieROCKS Engines / Suspension / Wheels / Tires / Audio / Accessories 21 01-27-2011 02:13 PM
Shock suggestions? runnahmike Off-Roading 8 11-15-2009 11:08 PM
