Old 04-26-2022, 11:58 AM #16
Mark_BC's Avatar
Mark_BC Mark_BC is offline
Real Name: Just call me the Grease Monkey
Mark_BC has a spectacular aura about Mark_BC has a spectacular aura about
Mark_BC's Avatar
Sorry if I came across snarky above, I just didn't want to see you get taken.
P0770 is the shift solenoid. I don't know much about how these transmissions work but it sounds like that is fixable, if that's the only problem.
The oil smell is more concerning. Ideally you could check the transmission temperature when running. The 99 outputs that from the computer but you'll need a Scangauge set up to read that, which sounds like isn't something you have easy access to.
I would suggest pulling up the trans dipstick and looking at the fluid colour. If it's brown and smells bad that isn't good.
My Snow and Sand build thread
Mark_BC's 2000 Limited Salvage Build
Determined to keep them from becoming parts trucks. Yes, even the one I just picked up as a parts truck...
Mark_BC is offline   Reply With QuoteReply With Quote
Old 04-26-2022, 05:51 PM #17
Originally Posted by runi9 View Post
1. slipping
The truck's transmission is slipping and has a hard time going from 2nd to 3rd when it first starts up.
A delayed 2-3 shift when cold is normal. It is there to help heat up the engine and transmission. It should go away fairly quickly (like, only one or two delayed shifts on 'normal' mornings above freezing).
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 04-26-2022, 05:55 PM #18
Mark_BC's Avatar
Mark_BC's Avatar
It's possible you have a pink milkshake where the radiator leaks coolant into the trans fluid. That will destroy your transmission. It will look pink on the dipstick. But if that happened I doubt you'd be able to drive it.
Old 04-27-2022, 11:23 AM #19
runi9 runi9 is offline
runi9 is on a distinguished road
No problem at all, I appreciate all advice here.
I'm going to try and take it to a trans shop to have them assess it since, as I suspected, they should have a procedure to run more tests and use more equipment like the Scanguage you mentioned. (also @mtbtim ) It's just very difficult to find time to take the truck there since they are open when I'm working and close right before I get off.
This is definitely not normal for this truck as it has not been like this for many years. Also, I live in a place where it is above 75 degrees almost every single day, so there is no cold weather here.
runi9 is offline   Reply With QuoteReply With Quote
Old 04-27-2022, 11:34 AM #20
Reinout's Avatar
Reinout Reinout is offline
Real Name: Reinout
Reinout will become famous soon enough Reinout will become famous soon enough
Reinout's Avatar
Real Name: Reinout
@runi9
Some of the first things I would do is the inexpensive things such as making sure oil levels are correct and even using additives (yes I know → "snake oil") but for about $10 you can get, from your local automotive shop, transmission fix additives. Sure, it might not fix it, but then again, it might!
1997 4Runner SR5- ~376k Miles and counting - 5 Speed E-Locker
2007 4Runner Limited V6- 165k Miles - Automatic - Brake Controller
2011 VW JSW TDI- 130k Miles - 6 Speed - Air Lift 1000
2006 Scamp trailer 16'
Reinout is offline   Reply With QuoteReply With Quote
Old 04-27-2022, 11:35 AM #21
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
He meant transmission is cold, as in not at operating temperature yet.
Old 03-22-2023, 12:08 AM #22
Quick update:
I ended up having to get the transmission rebuilt. The car got stuck one day and had to be towed. I got it towed to the trans shop and they fixed it.
Cost: $3200
4runner , car , fix , shop , transmission
1999 4Runner Engine & transmission runnoft General Discussions 1 06-07-2013 11:19 PM
1999 4Runner Transmission Fluid Gusher TRguy 3rd gen T4Rs 10 02-11-2013 07:11 PM
1999 4Runner 4WD Transmission ajonesnv For Sale: T4R Items 10 05-08-2012 11:56 AM
1999 4Runner transmission issue geoff r 3rd gen T4Rs 3 11-21-2011 09:50 PM
