Originally Posted by trevlf
So I have a 99 with MCM fab LT kit and I’m having issues with steering and have been since I installed it. Many many alignments and different shops and all new parts. Still won’t drive straight. I’m confused by your “washer stack” philosophy. My bump steer isn’t too horrible but I’ll look into the toe out thing instead of toe in. I have an issue steering. When I turn left and then back straight the wheel is slightly right. Then straightens out within a couple hundred feet. Vice versa while turning right, wheel will be slightly left until a couple hundred feet. Any ideas? Any would be much appreciated.
The only reason for the washers was to set the outer tie rod at the correct position to fix the bump steer, and by using washers it was easy to quickly dial it in. Once the height was determined with the washers a proper spacer could be swapped in. And the reason I had issues was how I setup the lower uniball and spindle which changed the geometry of everything. If you're using a straight bolt on kit with the stock LBJ I'm surprised you'd have issues with alignments. Are the alignments actually out of wack according to the spec sheet or does it change from one shop to another?
If you can rule out that the suspension isn't actually moving and is maintaining alignment (and that that alignment is straight and "normal"), then it might be a bump steer issue. I can't say I remember mine ever doing that (back in the days of doing lots of testing since my truck was nearly undrivable) but that does sound a lot like the suspension settling where one side changes it's ride height and thus it's toe in and after a bit of driving the tires can splay back out to ride height. Again, I'd be surprised if that was an issue, but there's only so many things obviously.
Are you using a stock LBJ or whatever MCM provides?
What is the steering setup like? Heim outer and inner?
What is the interface to the rack like?
The rear suspension is tight and not walking around?
Have you contacted MCM about that behavior?
