Old 01-29-2024, 04:34 AM #1
SocalRunner15 SocalRunner15 is offline
SocalRunner15 is on a distinguished road
How do you change out the fuel door lock mechanism?
Hey Guys,
It seems like the locking mechanism that keeps my fuel door closed is stuck. The pin is all the way in there and i think i made it worse my pushing on it a bit (hoping to get it unstuck). I sprayed some grease, hoping to get it unstuck but i also ordered another unit.
Does anyone know how to change out the unit? I'm assuming its behind the driver side panels in the trunk? Do you just remove the trim and gain access to it or is there another way?
Thanks!
SocalRunner15 is offline   Reply With QuoteReply With Quote
Old 01-29-2024, 12:25 PM #2
dotinfo's Avatar
dotinfo dotinfo is offline
dotinfo is on a distinguished road
dotinfo's Avatar
Same thing happened a couple nights ago, in for some feedback
dotinfo is offline   Reply With QuoteReply With Quote
Old 01-29-2024, 03:28 PM #3
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Use a debit card to slide in and release the mechanism. Old shady trick to get inside.
Old 01-29-2024, 05:14 PM #4
I have the opposite issue... its actually stuck open...
Old 01-29-2024, 05:59 PM #5
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
LOL well that's a new one then, not sure how to deal with that
Old 01-29-2024, 07:49 PM #6
Yeah i found the part # and ordered it from my local dealership. It's a 20 dollar part. It should be behind the side panel in the back...but i'm not 100% sure. I had gone offroading and i think just enough dust got into it that it jammed it in the retracted position...
Old 02-03-2024, 01:55 PM #7
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
The hinge on the gas door needs lubricated from time to time. Same with the Plunger.. If stuck open. I would very everything is moving properly. Then verify the plunger is catching the latch on the gas door. Sometimes they can bend and not catch anymore.
Old 02-03-2024, 09:52 PM #8
Alright...so you can find the fuel door lock mechanism inside the driver side rear panel in the trunk. You have to remove a few screws and once you pop off the panel, you'll see it right there.
Then you have to remove the bolt from the fuel door side and the mechanism comes right out.
The thing was completely dead....the spring had no return to it even after cleaning it completely. 20 bucks from the dealer.
How do you change out the fuel door lock mechanism?-11-jpg  How do you change out the fuel door lock mechanism?-12-jpg  How do you change out the fuel door lock mechanism?-13-jpg
Old 02-05-2024, 08:59 AM #9
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
Better out than in, as they say... lol
Old 02-05-2024, 09:18 AM #10
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
@SocalRunner15 less of a oh chit moment stuck open lol. Any lube before buttoning it up?
96RedRunner limited 4x4 5VZ auto not stock 374k miles totaled 2018.
2001 limited 4x4 5VZ auto work in progress.
2011 Audi S5 Prestige 4.2 V8 6 spd MT.
Old 02-05-2024, 09:36 AM #11
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Glad its fixed. :-)
door , hoping , mechanism , unit , unstuck
99 4Runner- Rear lock mechanism/ lock rod end connection hawkcharmer 3rd gen T4Rs 8 11-17-2020 01:54 AM
Re-assembled my door lock mechanism wrong, now door won't open xxaarraa 4th Gen T4Rs 2 10-23-2016 03:16 PM
WTB : 3rd gen glove box lock mechanism Lakland5 Want to Buy/Trade 0 10-13-2012 12:09 PM
WTB 07 glovebox lock mechanism Rocket61 Want to Buy/Trade 2 07-10-2012 04:29 PM
Help fuel/gas door lock Aznwolf118 Classic T4Rs 5 05-20-2012 03:09 PM
