07-08-2014, 10:04 PM
Real Name: Mason
Real Name: Mason
would like to do the 'hitch flip' but don't have the right hitch
I have the solid weld oem hitch. I would remove it but I leave it on as it takes on the rocks instead of my bumper. I would like to gain a few inches clearance via the hitch flip but can't. Can someone give me guidance on what hitch choices I have if I can't use this one? I know there is a (maybe oem) hitch with bolts that people to the flip with. Or is it just better to buy a low profile hitch? Mainly just need it as armor as I don't tow.
Thanks for the advice,
Mason
1998 4x4 5speed E-locked 225k - TRD 2nd Gen Charger w/ URD 7th injector - ICON 2.5 Standard Coilovers, ICON 2.5 Rear w/ Remote Res, ICON FJ Shin Guards, stock UCA, Tundra 199mm, ARB Bumper, Custom Tire Swingout bumper, Custom low profile roof rack, Lotas LC, Stubbs HD-SKO, 265/75/16 Duratrecs on OEM 5 Stars, Shockworks Combo Skids, Lightforce Genesis 210 halogens, 20% front tint, Uniden 520Xpro, 99+ Cup Holders & Headlights, Clarion CX501 deck, UG scanner, rear diff mod
2003 V8 4x4 Limited Black 156k stock for now. ICON ordered
07-08-2014, 10:50 PM
If you are wanting to utilize it as armor then you dont want to do the hitch flip that will leave your bumper exposed. I have never heard of the hitch flip before this but I don't think it is a good Idea for what you want to do. just my .02
07-08-2014, 11:00 PM
Mason
your correct, the welded one will not flip. its got side fins that lay on the bottom of the frame rail then when you try to flip it, it will not align.
the hitch you want has 3 bolts on the side of the arms that attach it to the frame. ill look for a pic.
see the nuts on the ends where the side to side part connects to the forwards and back rails?
Never ask a girl if shes sick, she might not be wearing any make up. - lets just say she went storming off.
Never tell your wife she looks tired, they tend to hit and say that means she looks ugly. (weird logic i know)
07-09-2014, 12:02 AM
I may be wrong, but look for pre-'99 hitches - they will be the bolt together design.
Build Etc...
If it ain't broke, fix it 'til it is.
07-09-2014, 12:39 AM
Just get a rear bumper
07-09-2014, 01:09 AM
I have a 1996 AND a 1998 in my driveway with weld together hitches. And I have parted a 1999 AND a 2000 with bolted hitches.
I am not sure what Toyota's rhyme or reason for the bolt vs welded hitch was (my best educated guess so far is Dealer vs. Factory hitch) so OP, be sure if you find one have them send you pictures or at least verify that it bolts together instead of being one solid welded piece. I would sell you one but I have 6 welded hitches and zero bolted hitches!
Parting Multiple 4Runners HERE
Also parting 1996, 1997, 1998. 1999, 2000, 2001, and 2002 4Runners! PLEASE PM any requests or visit my page PNW 4Runner Connection
03-06-2017, 11:16 PM
From everything I've read only the bolt-together hitch can be flipped - but what is the reason?
I have a metal fabrication shop working on my 4runner. Could they just break the weld, flip the hitch, and reweld?? A bit more work but still doable.
Or is there a geometric reason the hitch flip won't work with the welded bumper?
03-06-2017, 11:26 PM
Or is there a geometric reason the hitch flip won't work with the welded bumper?[/QUOTE]
The bolt together allows the exact same thing your talking about doing. If you want to with this hitch cut it loose, flip it, re-weld it back on. If you put a 1" body lift on it fits perfectly under the bumper without cutting anything out. Just bend the safety chain hoops down nothing else needed to be done. Paint the new to keep rust down and when coating will flake off when you bend the hoops.
Then again for less than the cost and effort you mentioned....get a bolt together from a wrecking yard!
He who Shi% fast does not Shi% for long!!
BILSTEIN CUSTOMER SERVICE SUCKS MUNG COVERED BALLS!!!
03-06-2017, 11:41 PM
Thanks reelamin. I saw you recently flipped your hitch and it turned out nice.
Last summer we dug our hitch several times pulling a teardrop trailer offroad. Those rollers got us everytime. The trailer got the offroad package install this winter - and now we need to raise the 4runner hitch height to match.
I'm confident the shop that is already doing my trailer work will be able to make easy work of this hitch flip -as long as there was not another reason it couldn't be done. From what I've seen though the geometry appears the same.
I'm keeping my eyes open for a junkyard bolt together though too!
03-07-2017, 08:46 AM
03-07-2017, 09:22 AM
A new single piece hitch is like what? 100? And you don't need to hack up your bumper.
03-07-2017, 09:58 AM
It definitely would not be a hack job, but I see your point. The strength would be compromised.
Having that section removed from the bumper though will allow the hitch point to be that much higher - which is one of my goals due to my offroad towing use.
Is there a particular aftermarket option which would effectively raise the hitch height this much (5 inches) without other significant modifications?
Hmm...
03-07-2017, 10:08 AM
Hmm...
Without cutting into the bumper, I'm pretty sure there's a tubular reese hitch that doesn't have that stupid drop. No idea what Toyota was thinking when they designed their hitch.
03-07-2017, 10:56 AM
Real Name: Reinout
Real Name: Reinout
My .02: The hitch holds all your goodies to the back of your 4runner. If you believe that your fab shop will do a good job and make sure that your trailer will stay with your truck. I'd go for it. My skeptisism is that IF the hitch does brake away, there goes your expensive trailer.
I'd stick with an OEM 3 piece hitch at since it's designed to take the load.
However. If I were to go with a fabricated hitch and you want to maintain your factory bumper I would have a crossmember put in behind the bumper with the 2" hitch end come straight out. Completely hidden except for the 2" hitch sticking out.
Kind of what Torklift has done for some Suby and Toyota models with the bumper cutout:
1997 4Runner SR5- ~376k Miles and counting - 5 Speed E-Locker
2007 4Runner Limited V6- 165k Miles - Automatic - Brake Controller
2011 VW JSW TDI- 130k Miles - 6 Speed - Air Lift 1000
2006 Scamp trailer 16'
03-07-2017, 10:58 AM
Real Name: Throws like a girl
The hitch will still protect as the bar still goes straight across, you just don't have the receiver hanging down gouging into everything you come off of. The extra height was nice for the bike rack, too. You do have to cut a square into the bumper though. I was okay with that. Old pic of my second mod:
'96 4Runner SR5, assorted baubles and doodads. Stuff happened to it. Stuff is still happening to it. Okay, now the stuff is just getting ridiculous.
'99 4Runner SR5 Highlander, manual w/locker. Stuff is starting to happen to this one too...too much stuff! Too much stuff!!
http://www.yotatech.com/f200/habaner...thread-201751/
Originally Posted by PWD4R
I know this is a weird ass question but do you shave your legs or something?
