Old 04-27-2022, 11:43 PM #1
DenverAirport's Avatar
DenverAirport DenverAirport is offline
DenverAirport will become famous soon enough
PCV Rattle
Hey folks.
Hearing this rattling sound from my PCV. Is this normal? I know the rattle test to be sure the part itself it working, but is it supposed to make this sound when the engine is running?
About 1k miles ago I had my valve covers done (I didn't have access to a garage at the time) and had the shop that did it replace my PCV valve so I don't know if it's an OE part. I also need to replace the hose as the ends are a bit cracked.
99' SR5 "Highlander Edition" - 301k - 4WD, Factory rear locker, 2.5" Dobinsons IMS lift, SPC UCAs, CJV 9168 TR axles, 199mm TBU, Tom Wood's driveshaft, eimkeith PCK, Aluminum Koyorad, Ultragauge
97' Limited - 250k - Stolen & Found (and Sold) - 4WD, 3" Billstein 5100 lift with OME 881, 890 springs, Diff drop, Camburg UCA's, 231mm TBU, Tom Wood's driveshaft, eimkeith PCK, Champion radiator, Ultraguage
DenverAirport is offline   Reply With QuoteReply With Quote
Old 04-28-2022, 12:20 AM #2
toverturf toverturf is offline
toverturf will become famous soon enough toverturf will become famous soon enough
Mine doesn't do that. That doesn't look OEM to me. OEM has a white stem. This is the part # for the OEM one: 12204-62010.
1999 Limited with rear locker.
Sherpa Matterhorn | Sonoran Steel Diff Drop | SPC UCAs | DuroBumps Front and Rear | OME 890 Springs and Black Tokico Shocks | Eimkeith Reinforcements and PCK | King Coilovers | OCD Sway Bar Links | Opt Offroad Rear Arms | Lil Skips Gas Tank Skid Plate | FGP Rock Sliders | 4x Innovations Rear Plate Bumper with tire carrier
toverturf is offline   Reply With QuoteReply With Quote
Old 04-28-2022, 04:53 AM #3
Deimosphob's Avatar
Deimosphob Deimosphob is offline
Real Name: Chance
Deimosphob is on a distinguished road
Deimosphob's Avatar
Real Name: Chance
They're cheap, just replace it! Plus that one looks pretty new, definitely aftermarket, so it doesn't look like a pain to remove. When I removed mine the rubber was so cracked it ended up falling into the valvecover and I had to spend a couple hours melting it out and fiddling with it with the valvecover off, soaking it in brake clean, etc. Point being no excuse lol. Also, I replaced my hoses for silicone, I have a v6 but I believe the 10mm or 3/8 vacuum hose size is the same on the pcv hose.
Last edited by Deimosphob; 04-28-2022 at 04:56 AM. Reason: Wanted to pack more information without creating another post
Deimosphob is offline   Reply With QuoteReply With Quote
Old 04-28-2022, 09:17 AM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
+ 1 on replacing it. As far as I know. None of mine rattle.
Also how is the fit in the grommet? Maybe just replace both with OEM and be done with that project..
Old 04-28-2022, 11:52 AM #5
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice
Romeo1's Avatar
Just replace it and the grommet. It’s not a lifetime part and cheap. Buy OEM on both.
Just be careful not to break it into pieces. If it does don’t panic. Just vacuum them out or use a small needle nose pliers.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2.3”) front 5160 rear shocks, OME 2890 springs, JBA upper arms Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar link rear 2nd gen rear up front, Amp’d hidden winch, warn Vr Evo 10s, ultralink, adventures powered by ON X.
Romeo1 is offline   Reply With QuoteReply With Quote
Old 04-28-2022, 01:20 PM #6
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Nope replace it. It's a very cheap part and will take less than 15 seconds to get it out. The hose on the other hand, is like $20!
326WHP 347TQ
Old 04-28-2022, 02:04 PM #7
Luckily I've got some silicon hose for it. Just need to run out and buy some clamps!
Old 04-28-2022, 10:34 PM #8
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
well if it is rattling then at least its prob not stuck in a closed position..that would not be good.
but agree....replace...cheap if you use aftermarket like 5 bucks, yota is about 12. I used aftermarket about 10 months ago, but this summer I have to do vc gaskets, and i will use yota grommet and pcv at that time
2002 tundra ac v8 4wd
1969 kharmann ghia
Old 05-13-2022, 12:08 AM #9
Wanted to post an update about this:
I got an OE PCV Valve and grommet (was almost $30 total from Toyota...inflation man) and replaced the one I had. Used silicon tubing as I've been doing for all the vacuum hoses that need to be replaced in the engine bay. The rattling has since stopped. No signs that the valve that was installed had any issues, just was a crappy aftermarket part.
Feels like most of the times I need to use aftermarket parts because I'm in a pinch end in me buying the OE part a few months later.
Old 10-31-2024, 12:00 AM #10
Raithed Raithed is offline
Raithed is on a distinguished road
mine does this but way way more aggressive and only when starting up the car before warm
Raithed is offline   Reply With QuoteReply With Quote
part , pcv , replace , sound , valve
Rattle when truck is in Drive (rattle stops in park/reverse/neutral) ETXT4R 4th Gen T4Rs 2 12-19-2017 04:47 PM
V6 Rattle rogers_68 Classic T4Rs 1 06-06-2011 07:39 AM
2000 4Runner Rattle Rattle...help! UrsaAmericanus Problems & Warranty Issues 2 11-17-2004 04:52 AM
Rattle, rattle Larry Problems & Warranty Issues 1 05-17-2004 02:24 PM
