Old 04-28-2022, 12:35 AM #1
Unner's Avatar
Unner Unner is offline
Unner is just really nice Unner is just really nice Unner is just really nice Unner is just really nice
Unner's Avatar
Rear Control Arm Options and Opinions
Hello all,
After nearly 300k miles I'm thinking it's time to refresh the bushings/control arms on the rear of my 3rd gen. I'm very big on longevity and ease of maintenance. I don't want heim joints I have to grease all the time and keep clean. I want bushings on both ends and don't think I need adjustable arms, they've been fine at stock length for over 100k miles of being lifted.
Rear Lower Control Arms:
I'm debating between Rokmen Trail Series arms with the enduromax bushings and the Sonoran Steel arms. Both are beefier than the original arms, but the Rokmen uses their own design of bushing which supposedly allows more movement and is long lasting, and the Sonoran Steel are available with either Strong flex poly bushings or OEM Toyota bushings.
Anyone have any long term opinions/reviews of these control arms? Any squeaks, rattles, issues with them? Any change in vibration or harshness on the road?
Rear Upper Control Arms:
These apparently see no benefit from being upgraded as the stock links twist well, so it's really just a matter of choosing bushings or getting new OEM arms since OEM bushings aren't available.
Any thoughts on bushings for these? Once again trying to avoid any that squeak, need any greasing after install, etc. I'm looking at the whiteline bushings and the strongflex bushings.
Panhard bar:
I have a PCK on the way. I plan to swap the bushings in the bar for fresh ones as well at the time. Same story as above, looking for simple solutions. Any long term reviews of the whiteline or strongflex bushings?
Thanks in advance for any input, really interested in hearing any feedback on the rear lower control arms since those are the main ones to replace in my opinion.
2008 Toyota 4Runner Limited 4x4 - Salsa Red, DD, Mostly Stock, 89k miles
2001 Toyota 4Runner SR5 4x4 - Not Stock, Lifted, Armored, 291k miles
1987 Toyota Supra N/A - Stock, 2nd Owner, 92k miles
Unner is offline   Reply With QuoteReply With Quote
Old 04-28-2022, 01:10 AM #2
theesotericone's Avatar
theesotericone theesotericone is offline
theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice
These apparently see no benefit from being upgraded as the stock links twist well.
I can confirm they do indeed twist well.
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. --Albert Einstein
theesotericone is offline   Reply With QuoteReply With Quote
Old 04-28-2022, 06:14 AM #3
toverturf toverturf is offline
toverturf will become famous soon enough toverturf will become famous soon enough
I know you said you wanted bushings and non adjustable but have you seen these yet? Rear Adjustable Control Arms (96-02 4Runner)
– OPT OFF ROAD
1999 Limited with rear locker.
Sherpa Matterhorn | Sonoran Steel Diff Drop | SPC UCAs | DuroBumps Front and Rear | OME 890 Springs and Black Tokico Shocks | Eimkeith Reinforcements and PCK | King Coilovers | OCD Sway Bar Links | Opt Offroad Rear Arms | Lil Skips Gas Tank Skid Plate | FGP Rock Sliders | 4x Innovations Rear Plate Bumper with tire carrier
toverturf is offline   Reply With QuoteReply With Quote
Old 04-28-2022, 06:44 AM #4
Deimosphob's Avatar
Deimosphob Deimosphob is offline
Real Name: Chance
Deimosphob is on a distinguished road
Deimosphob's Avatar
Real Name: Chance
Holy crap, I want to know what you hit to do that!
Deimosphob is offline   Reply With QuoteReply With Quote
Old 04-28-2022, 07:37 AM #5
– OPT OFF ROAD
Those do look sweet. I’m approaching 300k miles.
Old 04-28-2022, 09:51 AM #6
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I broke 2 of the uppers just driving down the highway. :/ I Blame the PA potholes.
brillo_76 is online now   Reply With QuoteReply With Quote
Old 04-28-2022, 10:25 AM #7
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
– OPT OFF ROAD
Those are on my wish list for when I hit the lottery! I like that they used johnny joints rather than hiems that squeak and need to be cleaned/lubed constantly.
Old 04-28-2022, 01:52 PM #8
GhostRing's Avatar
GhostRing GhostRing is online now
GhostRing will become famous soon enough GhostRing will become famous soon enough
GhostRing's Avatar
I purchased the Rokmen arms a few years back after a lower took a decent bend on a rock. The "enduro" bushings seem to be holding up well (890/5100 combo)
and I believe they are replaceable if need be. My choice at the time boiled down to Wheeler's being fairly close, and $100 is $100...
The Sonoran Steel version is very well thought out and I do like the idea of OEM bushings, but I've been happy with my decision so far.
ETA: I also replaced my upper arm and panhard bushings with Whiteline (OEM was tougher to find) and new OEM rubber for all the sway bars.
The ride is considerably better that the ratted-out 250K originals, and has great street/trail manners and no squeaks as of yet.
Build Etc...
If it ain't broke, fix it 'til it is.
GhostRing is online now   Reply With QuoteReply With Quote
Old 05-01-2022, 01:17 PM #9
Unner's Avatar
Unner's Avatar
– OPT OFF ROAD
Those are very nice, but a little more than I'm looking to spend.
Thanks for the input. Seems like most people are happy with the Rokmen, I haven't seen a negative thing about them. How long have you had yours?
Any issues with the whiteline poly in the upper links and panhard? I'm not too worried about harshness from those bushings, I don't think they would transmit too much, but squeaks will drive me absolutely insane!
Old 05-01-2022, 11:38 PM #10
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Christ on a bike
Old 05-01-2022, 11:49 PM #11
Originally Posted by Devbot View Post
Christ on a bike
Think that's bad. Here's the lower.
Old 05-03-2022, 06:08 PM #12
GhostRing's Avatar
GhostRing's Avatar
I have had the Rokmen arms for about 4 years now. They have performed admirably and held up to getting thunked more than a few times. I feel a good complement would be some skids for the arm mounts.
The WL bushings have done their job well, albeit for about 4 months so far.
I haven't found any drawbacks concerning road feedback or articulation.
I followed their recommended greasing procedure and they haven't made
a peep - especially considering the trail conditions right now. I could survive
an annual re-grease, but fingers crossed it takes longer than that!
Build Etc...
Old 05-04-2022, 11:45 AM #13
turbo8's Avatar
turbo8 turbo8 is offline
turbo8 will become famous soon enough turbo8 will become famous soon enough
turbo8's Avatar
For those that have been dinging up\bending their lower control arms, would anyone be interested in a lower control arm brace\skid like I made for my 200 series?
Rear lower control arm brace\skid | IH8MUD Forum
Rear Control Arm Options and Opinions-link-skid-jpg
97 4runner 3.4l, 5spd, 4wd trd s\c, urd 7th injector, tc upper arms, Fox 2.5" extended travel coil overs, Icon 2.5" piggy back rear shocks, ome 2" lift rear springs, fj cruiser wheels,custom front skid, Modified trail gear rock sliders, tundra brakes, 275/70r/17 bfg AT ko2, true track, Corbeau sport seats, trs h1 hid retrofit.
2011 BMW 135I 6spd
2009 Lexus LX570
turbo8 is offline   Reply With QuoteReply With Quote
Old 05-04-2022, 09:55 PM #14
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Genius!
arms , bushings , control , long , rear
Bent Rear Lower Control Arm - Options? ieatfish General Discussions 3 04-27-2022 11:47 PM
Awning Options - I'd Like Your Opinions mtbtim 3rd gen T4Rs 17 12-06-2021 02:54 PM
KING or Bilstein 6112s and any opinions on rear lift options 4runneraddict 3rd gen T4Rs 0 06-07-2017 04:48 PM
Need opinions on suspension options for my 06 ccoop_47 4th Gen T4Rs 1 10-10-2014 04:13 PM
Building rear control arms. Thoughts and opinions Taylor20 3rd gen T4Rs 18 06-03-2013 05:12 PM
