LONG overdue brake pads and rotors job. Removed my OEM pads and rotors. They lasted a little more than 72K miles, which is definitely a lot. The pads had some life left on them but not much. The rotors were toast, had been for a long time now. Like terribly warped and violently shaking when applying the brakes.
I ended up throwing in Hawk LTS pads (p/n HB315 Y.669) and store brand rotors from Advance Auto (Carquest Wearever p/n YH145137). So far the combination of the two is beautiful, as I'm able to gently apply the brakes and come to a smooth and quiet stop. The job itself was easy and I did it in a friend's driveway in about 2 hours total, but it took longer due to having to take breaks and run an errand in between.
Fortunately a friend of mine has a bench grinder, so while I was removing hardware and pins and bolts, he was cleaning them up on this bench grinder. It made everything look literally brand new. I was so impressed that I only remembered to take pictures of the sliding pins that hold the pads in place. Wish I would've snapped some pics of the caliper bolts. They look beautiful when all cleaned up.
I'm super happy I finally got this job done as it was long overdue. I feel like my truck is basically new again.
Date: 3/28/23
Mileage: 324,268
Old pads, super worn down.
OEM rotors with warpage.
Sliding pins before and after cleaning with angle grinder.
New meaty Hawk LTS pads installed!!
Part number for pads in case anyone is interested.
Old pads from other side of truck.
And finally, mileage.
