Old 04-30-2022, 02:57 PM #1
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
JoeT4R’s 2001 SR5 Build & Maintenance Thread
Date of purchase: February 2nd, 2013
Mileage: 191,586 mi.
Price: $4816
Completely stock, no modifications, 2001 SR5 4WD. I’m going to begin logging everything from date of purchase to present and it may take a while. I will use this thread to keep up with maintenance and to have an online record of everything that has been done to my rig. I have just about every maintenance receipt from the very first oil change until now, with the exception of about a 1.5-2 year lapse in between. All maintenance records prior to my ownership were given to me by the previous owner. This should be fun. Here’s a photo taken shortly after purchase and brought home to my parents house.
Untitled
Old 04-30-2022, 02:58 PM #2
JoeT4R's Avatar
JoeT4R's Avatar
Maintenance & Build Log:
6/19/13 - Parts Master 80W-90 rear diff fluid 194,930 miles
7/17/13 - Champion 3071 Platinum Power spark plugs, Pro Series spark plug wire set (25605) 195,959 miles
8/17/13 - Oil change, Valvoline MaxLife SynBlend 5W-30, K&N HP-1002 filter, 197,466 miles
10/16/13 - OEM fuel filter p/n 23300-62030, 199,451 miles
11/13/13 - OEM air filter p/n 17801-07020, 200,004 miles
11/13/13 - Oil change, AMSOIL Signature Series 5W-30, Wix 51348 filter, 200,014 miles
12/30/13 - Alternator replaced, off-brand VIP 13794 reman unit, 202,623 miles
1/9/14 - Daystar kt09106bk front/rear suspension lift 2.5", Revtek RTDD1-KB diff drop kit, unknown mileage
1/27/14 - Mount & balance used BFG A/T's, 265/75/16, 203,787 miles
3/7/14 - Oil change, AMSOIL Signature Series 5W-30, Wix 51348 filter, replaced drain plug p/n 90341-12012, 205,058 miles
3/13/14 - Wipers replaced, 205,263 miles
4/1/14 - OEM PCV and grommet, PCV p/n 12204-62010, grommet p/n 90480-18001, 205,790 miles
4/26/14 - OEM valve cover gaskets, plenum gasket, spark plug tube seals, p/n's 17176-62040, 11193-70010, 11213-62020, 206,782 miles
5/16/14 - Oil change, AMSOIL Signature Series 5W-30, YZZD1 filter, 207,565 miles
5/29/14 - Akebono brake pads & Best Brake rotors, 208,420 miles
7/18/14 - Oil change, AMSOIL Signature Series 5W-30, YZZD1 filter, 210,003 miles
10/19/14 - Sonoran Steel Classic System 1.2
Front: '04 TRD Tundra Coil p/n 48131-AF090, '04 TRD Tundra Coil p/n 48131-AF100, Bilstein 5100's p/n F4-BE5-6929-H1, Top plates p/n 48609-35030 x2, skid plate bolt package, Rear: '95 FZJ-80 LC coils p/n 48131-6A570, Bilstein 5100's, Sonoran Steel adjustable panhard/Tracbar, Daystar KU09014BK comp. style bump stops, other little goodies, 212,324 miles
10/29/14 - OEM antenna mast p/n 86337-35111, unknown mileage
12/21/14 - Passenger side CV axle replaced with off-brand reman unit, 213,941 miles
12/21/14 - Front diff and transfer case fluid, AMSOIL 75W-90, plug and gaskets replaced p/n's 90341-23014, 90430-24003, 90341-18032, 12157-10010, 213,941 miles
1/20/15 - OEM A/F ratio sensor with OEM gasket, nuts, p/n's 89467-35011, 89466-20020-83, 90179-08059 x2, 214,682 miles
2/2/15 - OEM Air filter p/n 17801-07020, 215,000 miles
2/3/15 - Oil change, AMSOIL Signature Series 5W-30, YZZD1 filter, 215,024 miles
2/4/15 - Oil pan, gasket replaced, stripped the plug/pan during the above oil change, p/n's 12101-62070, 90341-12012, 90430-12031, 00295-00103, 215,050 miles
4/13/15 - Oil change, AMSOIL Signature Series 5W-30, YZZD1 filter, 217,516 miles
6/12/15 - Oil change, AMSOIL Signature Series 5W-30, YZZD1 filter, 220,037 miles
6/24/15 - NGK (4412) RC-TE66 spark plug wires, NGK 3967 dual electrode plugs, 220,701 miles
6/24/15 - OEM positive battery terminal replaced p/n 90982-05035, 220,704 miles
8/16/15 - Oil change, AMSOIL Signature Series 5W-30, YZZD1 filter, 222,433 miles
9/7/15 - OEM lower ball joints, bolts p/n's 90105-10505, 43330-39585, 43340-39465, 223,351 miles
10/8/15 - Oil change, AMSOIL Signature Series 5W-30, YZZD1 filter, 225,014 miles
10/14/15 - Spidertrax wheel spacers (front) 1.25", front, 225,264 miles
10/30/15 - Moog EV433 tie rod end x2, Moog ES3548, Moog ES3547 (inner/outer tie rods), 225,868 miles
10/30/15 - Mount and balance new Cooper StMaxx 285/75/16's, 225,883 miles
12/12/15 - Transmission fluid, plug w/ gasket p/n's 90341-10011, 35178-30010, no record of fluid brand, 227,998 miles
12/28/15 - OEM thermostat & gasket p/n's 90916-03075, 16325-62010, coolant (zerex brand), 228,095 miles
2/9/16 - Oil change, AMSOIL Signature Series 5W-30, YZZD3 filter, 230,000 miles
3/27/16 - B&M 70268 transmission cooler, 231,519 miles
5/5/16 - Moog 387 rear u-joint, 233,207 miles
6/3/16 - Oil change, AMSOIL Signature Series 5W-30, YZZD1 filter, 234,682 miles
7/1/16 - Fat Pats 1" Body Lift, 237,054 miles
7/16/16 - OEM air filter p/n 17801-07020, 238,084 miles
7/30/16 - Rear diff fluid, fill/drain plugs replaced p/n's 90341-18057, 90341-18006, AMSOIL 80W-90 severe gear oil, 238,989 miles
8/8/16 - Oil change, AMSOIL Signature Series 5W-30, YZZD1 filter, 240,098 miles
8/20/16 - OEM timing belt, water pump, all 3 belts, idler and tensioners, p/n's 16100-69398-83, 13568-YZZ03, 90080-91090-83, 90080-91126-83, 99364-20870-78, 12157-10010, 13503-62040, 13505-62070, 13540-62021, Toyota Coolant p/n 00272-1LLAC-01, 240,671 miles
10/2/16 - Spidertrax wheel spacers (rear) 1.25", 242,248 miles
12/16/16 - Oil change, AMSOIL Signature Series 5W-30, YZZD1 filter, 245,188 miles
3/3/17 - OEM fuel filter p/n 23300-62030, 248,860 miles
4/5/17 - Custom rear sway bar end links w/ Energy Suspension bushings, 249,824 miles
4/10/17 - Oil change, AMSOIL Signature Series 5W-30, YZZD1 filter, 250,026 miles
4/18/17 - Gentex auto-dimming rear view mirror w/ compass, unknown mileage
4/23/17 - OEM thermostat with gasket p/n's 90916-03075, 16325-62010, jiggle valve set to 6 o'clock position, 250,599 miles
4/23/17 - Coolant drain & fill with OEM coolant p/n 00272-1LLAC-01, 250,599 miles
5/13/17 - BG44K fuel system cleaner in gas tank, 251,126 miles
5/21/17 - OEM, used alternator installed, unknown mileage on unit, bench tested and was good, 251,396 miles
5/21/17 - OEM grille, older style installed, 251,396 miles
6/2/17 - OEM brake pads, OEM rotors p/n's 43512-35210, 04465-35240, 251,811 miles
6/11/17 - Transmission fluid drain and fill with AMSOIL ATF, 252,161 miles
7/31/17 - Truck was TOTALED by a drunk driver while parked, woke up to find the truck totally destroyed. Front bumper was ripped halfway off, driver side blinker wiring was ripped, front driver fender, flare and door were smoked. Rear driver door and door flare were toasted. Deemed a total loss by insurance, asked for the vehicle back and for a check. Parts were gathered over a period of time, handed over to a family friend, fixed by paying with check from insurance and out of pocket, truck received back on 10/21/17
10/27/17 - Oil change, AMSOIL Signature Series 5W-30, YZZD1 filter, 254,850 miles
12/27/17 - WeatherTech floor mats installed, front
2/5/18 - Oil change, AMSOIL Signature Series 5W-30, YZZD1 filter, 259,993 miles
4/15/18 - Oil change, AMSOIL Signature Series 5W-30, YZZD1 filter, 265,190 miles
5/9/18 - OEM radiator replaced with Denso p/n 16410-AZ011, 266,461 miles
5/10/18 - OEM upper & lower radiator hoses p/n's 16571-62070, 16572-62090, OEM hose clamp p/n 90467-37005, radiator filled with Toyota Coolant p/n 00272-1LLAC-01, 266,461 miles
5/10/18 - OEM air filter p/n 17801-07020, 266,461 miles
8/23/18 - Oil change, AMSOIL Signature Series 5W-30, YZZD1 filter, 269,996 miles
10/11/18 - Oil change, Pennzoil Platinum 5W-30, switched to YZZD3 filters (slightly taller than D1's), 273,287 miles
3/26/19 - Oil change, Pennzoil Platinum 5W-30, YZZD3 filter, 277,992 miles
4/16/19 - OEM spark plugs p/n 90919-01192-DS x6, mileage unknown
4/22/19 - Truck into dealer, weird misfire upon replacement of plugs, new OEM wires installed p/n 19037-62050, 278,564 miles
4/22/19 - Rear u-joint replaced by dealer, OEM u-joint p/n 04371-60070, 278,564 miles
4/23/19 - I BECAME A DAD, got the 4Runner back (last night) just in time I'd say
9/22/19 - Oil change, Pennzoil Ultra Platinum 5W-30, YZZD3 filter, 282,003 miles
2/5/20 - Oil change, Pennzoil Ultra Platinum 5W-30, YZZD3 filter, 286,092 miles
5/26/20 - Depo clear corner front lenses, unknown mileage
5/30/20 - OEM air filter p/n 17801-07020, 288,717 miles
6/8/20 - New Cooper AT3 XLT's 285/75/16 mounted and balanced at a Honda dealership at like 11pm, 289,108 miles
7/22/20 - Oil change, Pennzoil Ultra Platinum 5W-30, YZZD3 filter, 289,996 miles
1/8/21 - Oil change, Pennzoil Ultra Platinum 5W-30, YZZD3 filter, 294,914 miles
1/9/21 - Truck into dealer, transmission fluid pan/drain plug stripped, replaced by dealer, p/n's 35106-35110, 00295-01281, 90341-A0002, 90341-10011, 35178-30010, 294,918 miles
2/24/21 - OEM muffler began to rot, noticed a visible leak coming from the sides, filled the cabin with a horrible smell while on a road trip. Replaced with Borla 40665 TurboXL muffler, 296,374 miles
4/8/21 - Rear diff fluid AMSOIL 80W-90, new fill plug, drain plug, crush washers, 297,855 miles
4/15/21 - OEM rear diff breather p/n 90930-A3001, 298,367 miles
5/5/21 - Oil change, Pennzoil Ultra Platinum 5W-30, Napa Gold 1516 filter, 299,382 miles
5/14/21 - Blackstone Labs Oil Analysis #1
6/2/21 - OEM fan clutch (Aisin FCT-013) SOLVED problem when running A/C on hot days causing engine temps to rise above normal while idling, 300,264 miles
6/12/21 - Airaid intake tubing replaced OEM unit, 300,567 miles
6/16/21 - OEM PCV, grommet and hoses p/n's 12204-62010, 90480-18001, 12261-62041, 300,992 miles
7/1/21 - Transfer case fluid AMSOIL 75W-90, 301,446 miles
8/7/21 - Interstate battery group 24F from Costco, 303,337 miles
8/9/21 - Battery terminals upgraded to WindyNation's brass marine terminals, unknown mileage
8/9/21 - OEM starter relay p/n 28300-10020, unknown mileage
8/12/21 - Denso reman alternator p/n 210-0434 and OEM alternator belt p/n 90080-91090-83, 303,452 miles
9/4/21 - Denso o2 sensor (rear) p/n 234-4261, 304,142 miles
9/13/21 - OEM shifter bushings, p/n 90385-11003, 304,426 miles
9/21/21 - Oil change, Pennzoil Ultra Platinum 5W-30, YZZD3 filter, 305,022 miles
9/27/21 - Denso windshield wipers p/n 160-3117, unknown mileage
9/27/21 - Denso coil packs p/n NP 673-1201, 305,538 miles
10/20/21 - OEM air filter p/n 17801-07020, unknown mileage
11/9/21 - A/F ratio sensor Denso p/n NP 234-9002, 307,278 miles
12/15/21 - OEM rear windshield wiper blade, p/n 85242-35010, unknown mileage
12/27/21 - OEM gas cap p/n 77300-53010, 309,308 miles
1/11/22 - Depo smoked rear LED taillights, unknown mileage
2/1/22 - Oil change, Pennzoil Ultra Platinum 5W-30, Wix XP 51516 filter, 310,186 miles
2/5/22 - Hella +50 H4/9003 headlights, 310,318 miles
3/2/22 - Honda Odyssey windshield washer nozzles (upgraded) installed p/n 76810-TK8-A01, unknown mileage
3/11/22 - AVS 23041 bug deflector installed
3/24/22 - Drain and fill transmission with AMSOIL ATF, 311,753 miles
4/8/22 - Tightened valve cover bolts, they were loose, especially the driver most rear bolt, unknown mileage
4/26/22 - Napa Heavy Duty CV Axles NCV941258, OEM Toyota diff seals replaced at NTB (Do not recommend, good work, bad quote for labor), p/n’s 90311-47013, 90311-47027, 312,822 miles
5/2/22 - Taught my 3 y/o how to hand wash and hand wax the 4Runner. That boy is smarter than you would believe!
5/9/22 - Replaced third brake light with Hella #921 5K LED, 313,195 miles
5/12/22 - Installed Depo clear turn signal housings, 313,291 miles
5/16/22 - OEM bumper fog light plugs installed, p/n 52127-35020, unknown mileage
6/1/22 - Denso air filter p/n 143-3040, 313,924 miles
6/1/22 - Oil change, Kirkland Signature Full Synthetic 5W-30, Napa Gold 1516 filter, Fumoto F-133 with OEM Toyota gasket, 313,926 miles
6/20/22 - Rear diff fluid, SuperTech full synthetic 75W-90, 314,507 miles
6/29/22 - Oil change, SuperTech Full Synthetic High Mileage 5W-30, YZZD3 filter, removed Fumoto F-133 and installed new OEM plug with gasket p/n 90341-12012, 314,863 miles
7/2/22 - A/C drain extension with spare transmission cooler hose, hose clamp, unknown mileage
7/13/22 - Virginia Vehicle Emissions Inspection (PASS), 315,291 miles
7/28/22 - Sylvania Silverstar Ultra 9003 headlights, unknown mileage
8/6/22 - NGK Spark Plugs (3967/BKR5EKB-11) & Plug Wires (4412/TE66), 316,143 miles
8/25/22 - Oil change, SuperTech full synthetic high mileage 5W-30, Fram XG3600 filter, 317,271 miles
9/11/22 - Wiper blade replacement, Rain-X
9/23/22 - OEM fuel filter, new fuel lines, 318,477 miles
10/20/22 - Techron fuel system cleaner, 319,636 miles
10/28/22 - Oil change, SuperTech full synthetic high mileage 5W-30, YZZD3 filter, 319,957 miles
12/20/22 - Strongarm 6815 rear hatch struts, 321,742 miles
1/17/23 - Rear hatch license plate bezel replaced
1/20/23 - New rear shocks, OEM LC80 Tokicos, p/n 48531-69417, lower shock mount bolts p/n 91619-G1222, 322,581 miles
2/9/23 - Oil change and tire rotation. SuperTech full synthetic high mileage 5W-30, Fram PH3600 filter, 323,105 miles
2/13/23 - Transmission fluid drain and fill, Valvoline MaxLife ATF, new crush gasket, 323,163 miles
3/11/23 - Starter replacement w/ Denso reman p/n 280-0166, 323,664 miles
3/17/23 - Greased front driveshaft, 323,900 miles
3/21/23 - Front differential drain and fill, plug replacement with Lexus bolts, OEM gaskets, Valvoline 75W-90 full syn, 324,002 miles
3/21/23 - MAF Sensor replacement with Denso p/n 197-6020, 324,002 miles
3/22/23 - OME 861 install, new washers for upper shock mount, p/n 90948-02144, 324,052 miles
3/26/23 - Air filter replacement, Denso p/n 143-3040, greased outer tie rod ends, 324,195 miles
3/28/23 - Store brand rotors from Advance Auto Parts (Carquest Wearever p/n YH145137), Hawk LTS pads (p/n HB315 Y.669), 324,268 miles
4/5/23 - Brake fluid bleed, front brakes only, Valvoline Synthetic DOT 3 & 4 fluid, 324,509 miles
5/28/23 - Oil change, SuperTech full synthetic high mileage 5W-30, Fram PH3600 filter, 326,801 miles
8/12/23 - Oil change, SuperTech full synthetic high mileage 5W-30, YZZD3 filter, 330,001 miles
9/6/23 - Replaced driver side headlight bulb with a similar Sylvania bulb
12/28/23 - Replaced passenger side headlight bulb with a Peak 9003 bulb
1/26/24 - Oil change, SuperTech Full Synthetic High Mileage 5W-30, YZZD3 oil filter, 335,000 miles
1/30/24 - Tire rotation, 335,098 miles
Old 05-03-2022, 11:29 AM #3
JoeT4R's Avatar
JoeT4R's Avatar
I want to welcome ANY and ALL questions regarding my build. I hope that this build thread will serve as a platform to interact with people who need information, or who just want to have conversations about their rigs. I will drop a photo below of how it sits as of May 2022.
Old 05-03-2022, 02:25 PM #4
JoeT4R's Avatar
JoeT4R's Avatar
As of yesterday, 5/2/22, post wash and wax.
5/2/22
Old 05-05-2022, 11:20 AM #5
Joshv4runner's Avatar
Joshv4runner Joshv4runner is offline
Joshv4runner is on a distinguished road
5/2/22
Hey Joe- really clean build you have there. Glad you didn't scrap her after being totaled. Hope to see her get to 600k!
00' 4Runner Limited- Auto trans, E-locker, grey-wire mod, custom rock sliders, B&M 70268, TRD exhaust tip, 285/75/16 Duratracs
R.I.P 99' 4runna- auto trans, 4wd, tacoma whip mod,B&M 70768 tranny cooler, 265/75/16 Cooper Discoverer at3
Joshv4runner is offline   Reply With QuoteReply With Quote
Old 05-05-2022, 04:00 PM #6
JoeT4R's Avatar
JoeT4R's Avatar
Thanks dude, I’m glad I didn’t get rid of it either. It’s been good to me and I’ve been good to it. Certainly plan to keep it for as long as possible, too.
Old 05-08-2022, 11:22 AM #7
JoeT4R's Avatar
JoeT4R's Avatar
Reached a cool milestone yesterday.
Untitled
Old 05-11-2022, 07:01 AM #8
JoeT4R's Avatar
JoeT4R's Avatar
After 313K miles, I finally realized that my third brake light was out. I saw my reflection in a glass window and noticed it. Who knows how long it was really out for. But I went ahead and purchased some new LED bulbs to install and here are the final results. I'm happy with it.
Date: 5/9/22
Mileage: 313,195
Untitled
Untitled
Old 05-11-2022, 03:05 PM #9
Back4More Back4More is offline
Back4More is on a distinguished road
I love the smoked tails; bought a set as well.
Back4More is offline   Reply With QuoteReply With Quote
Old 05-11-2022, 03:22 PM #10
JoeT4R's Avatar
JoeT4R's Avatar
Thanks. I wanted them for a long time and decided to pull the trigger on them shortly after Christmas last year and glad that I finally did. They were very easy to install, even in very cold temperatures. Definitely a nice touch for the back of the truck.
Old 05-12-2022, 07:50 PM #11
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Nice Build thread Joe. I enjoy the stories of the rigs. Glad you saved it from being totalled
Old 05-12-2022, 10:03 PM #12
JoeT4R's Avatar
JoeT4R's Avatar
@brillo_76 Ah man, thank you for the kind words sir. I’m honored to have you comment on my build thread. Everything I’ve ever read that you’ve posted is always something I either agree with, is really intelligent, or just overall beneficial to the conversation at hand. So I appreciate it. (Not being facetious either)
I’m also glad I didn’t get rid of it when it was totaled. It was a sad, sad day. I was asleep and around 10:45 pm, one of my neighbors ran down to my house and banged on my window to wake me up. Ran outside in boxers and pistol in hand thinking something was going down. It was definitely not a good night when that happened. But I’m really thankful for the money I received and the fact that I had the ability to get it fixed. Big shoutout to my Mom as well, who allowed me to share her car with her during that time.
Old 05-12-2022, 10:17 PM #13
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I just been working on Toyotas since I was around 13 or 14. Saw lots of changes over the years. I just a hobby mechanic though. So don't give me too much credit.
I actually saved all my fleet of 3rd gens from the junk yard except one. And it's frame had a major bad section too. They are my hobby. Rebuilding the frames and chassis.
I am really glad to see the younger folks getting into the fixing and repairing. As these skills come in handy and will save you a pile of money in your lifetime.
Old 05-13-2022, 10:49 AM #14
JoeT4R's Avatar
JoeT4R's Avatar
After a long time of wanting them, I finally decided to order the Depo clear turn signal housings. $34 and some change out the door on eBay. Installed them last night. The original red clips that Toyota had installed on my OEM turn signals were honestly tough to get off from the bumper. My thumb bled a little bit trying to get those dang things off. The new Depo housings came with new clips so it was a straight plug-and-play scenario.
Date: 5/12/22
Mileage: 313,291
Depo turn signals
Depo turn signals
Depo turn signals
Old 05-13-2022, 12:19 PM #15
Coming together nicely! Plans for fogs?
build , joet4r’s , reserved , sr5 , thread
415Yota’s Build T4topher 3rd gen T4Rs 346 08-21-2023 07:17 AM
SURF RUNNER 2.0 Build, Maintenance & Modification: 2001 Stellar Blue Limited 4WD SURF RUNNER 3rd gen T4Rs 41 10-27-2020 10:01 AM
I’m pretty sure it’s dead Jim. Rear drivers lower link mount broke off frame. 19963.4lsr5 3rd gen T4Rs 16 09-12-2020 11:41 AM
Doc's maintenance/build thread Cow_doc.308 3rd gen T4Rs 8 09-17-2016 12:08 AM
v3's maintenance/build thread v3bahumut 3rd gen T4Rs 7 04-27-2014 12:14 PM
