11-21-2022, 09:56 PM
#166
@ octanejunkie
No, I haven't done anything to convert my rig to run E15. I just fill it and it goes vroom.
@ brillo_76
Agreed. Not sure what long term use will look like over time, but in the meantime I will run it as long as it doesn't give my rig any issues. So far nothing has happened so I consider that a win.
Sent from my SM-S908U using Tapatalk
11-21-2022, 10:35 PM
#167
Real Name: Jon
Real Name: Jon
Originally Posted by JoeT4R
@ octanejunkie
@ brillo_76
It is.. I just remember that when ethanol first came out in the US. Toyota came out and said that anything up to 10% will not be an issue and said that is all the higher they recommend on vehicles older then 2002 or so.
Do I think 5% more will hurt... Besides loosing another mpg. We will find out. :-)
11-21-2022, 11:02 PM
#168
Yup. I mean I like the idea of having an alternative fuel option that's way more cost friendly, especially during the times we're living in right now. If I had non ethanol stations near me I would certainly be using it exclusively because of the fact that I get better mpg's with it. But, since the E15 stuff is so cheap, it's too good not to use it.
11-27-2022, 04:18 PM
#169
Got this from Amazon during a cyber Monday deal for $17. I don't know why I waited so long to get one of these, but I'm glad I did. Overall a good product and happy with the purchase.
12-10-2022, 11:12 AM
#170
Lucas fuel injector cleaner.
Date: 12/10/22
Mileage: 321,450
12-20-2022, 11:32 AM
#171
New Strongarm 6815 rear hatch struts. These things are indeed no joke. All I have to do is pull the tab on the hatch and it does the rest of the work itself. Hands down worth the money. I also reused my old washers and hardware with no issues. Installed these in 32⁰ weather and they still open super fast!
Date: 12/20/22
Mileage: 321,742
12-20-2022, 05:51 PM
#172
Real Name: Blair
Real Name: Blair
I'd like to get those but my bushings are shot. I have the regular Strong arms I believe, and they have gotten weak over a 2.5 year period.
12-20-2022, 06:35 PM
#173
My bushings are basically non-existent but yet they still work just fine. I don't think it's going to make or break the performance although I could be totally wrong. I got the ones with extra force and they are insane. I definitely would recommend them. I'm excited to see how they hold up in the long run.
12-20-2022, 06:46 PM
#174
Did the stronger struts make the hatch more difficult to close at all? My hatch barely stays open on it's own so I'm due for some new ones, and was debating with going with stronger struts or not
Long travel '97 Limited - build thread
12-20-2022, 09:10 PM
#175
Real Name: Blair
Real Name: Blair
Agreed. When I first installed them, I needed to jump back or get whacked as the hatch opened! I have a screengrab of the Hillman nylon bushings/PN on my computer but have just been too lazy to deal with it. To answer the other gent's question about the hatch being more difficult to close with Strong Arm struts, I would say it most definitely takes more force to close, but not quite 'Difficult'. I may be mistaken as to which version of the SA struts I have and whether or not there are even 2 versions as it was the very first 'mod' I did. With the OEM struts it came with, the hatch would actually hit me in the head if I trusted it to stay up before I swapped them out - it would not stay up AT ALL if the rear glass was down..
12-20-2022, 09:25 PM
#176
The stronger struts give a loooot more resistance than the worn out stock ones when closing the hatch. It's not difficult but you may have to two-hand it. It's worth it though and you will absolutely thank yourself.
I've seen the videos/info on fabbing those Hillman nylon bushings and I just didn't bother or care to. It wasn't critical so I left it alone. There are in fact two versions and I'm pretty sure the YouTube video
@ mtbtim
and
@ infamousRNR
put out on this mod lists the two different part numbers. I opted for the ones with extra force because why not?
Sent from my SM-T220 using Tapatalk
12-20-2022, 10:18 PM
#177
Real Name: C8H18 Mike
@ mtbtim
and
@ infamousRNR
I only installed one extra strength strut and kept one of the factory ones. Seems to be working well for me.
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto -> 2WD 4runner Journal Thread
12-20-2022, 11:43 PM
#178
What made you want to go that route? Just curious.
12-21-2022, 10:46 AM
#179
I'd rather fight one strong strut than two
01-07-2023, 12:35 AM
#180
Well, my original starter has been having a fit lately. Today it really made itself known that it's ready to be replaced. I went ahead and purchased a Denso reman from RockAuto for $159.38 and plan to hang onto my OEM unit to rebuild it in the future. Here's a video of the awful sound my current starter is making. It made it 322K, so I'm happy with that.
20230106_162459 | JoeT4R | Flickr
