05-05-2022, 02:37 PM
Rear door speaker size?
I've searched the forum and got mixed answers.
What is the stock speaker size in the rear doors?
Some people say 4" and others says 5.25".
I just want to replace the stock (blown) speaker with something that is a direct fit.
Thanks
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
05-05-2022, 02:50 PM
Real Name: Mark
Real Name: Mark
5.25" doesn't take much to fit 6"
05-05-2022, 03:06 PM
So if I order 5.25" speakers, they will drop right in?
I read on here that people had to use adapter plates to make 5.25" speakers fit because the window hits the magnet.
2011 Camry SE V6
05-05-2022, 03:24 PM
Real Name: Howard J. Turkstra
It depends on the speaker. Some fit, some need adapter plates. Crutchfield has good info re. what speakers are a direct fit.
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
05-05-2022, 06:02 PM
Real Name: Mark
Real Name: Mark
Crutchfield has shallow mount speakers for Runners 5.25" plug n play.
Don't have to buy there their info on what works what you're after.
05-05-2022, 08:44 PM
Real Name: Jerod
Real Name: Jerod
Crutchfield sells a lot of open box items for cheaper than anywhere else though. I bought my subwoofer and my head unit from them since they were open box and cheapest.
Check Ebay though.
05-06-2022, 08:16 AM
When I checked Crutchfield, I didn't see any shallow mount, plug and play options. All of the speakers it listed had an adapter plate as required.
To be honest though, I've never bought from Crutchfield so maybe I'm just missing it.
2011 Camry SE V6
05-06-2022, 08:37 AM
I had to do some modifying of the rear speaker mount to fit the 5 1/4” kicker speakers I installed. Forget exactly what I did and sadly I looked on my thread and only a picture of the front speaker.
05-06-2022, 09:02 AM
Real Name: Mark
Real Name: Mark
As for plug n play, that has to do with depth needed for no window interference.
Adapter plate comes with all speakers anymore may need may not, it mostly for lining up mounting holes different pattern.
Call them they'll tell you what works.
05-06-2022, 10:25 AM
05-06-2022, 01:09 PM
Real Name: Mark KN6TZI
I called Crutchfield and they sold me 6 1/2" Polk Audio (DB 652). A couple different posts here suggested using plastic cutting boards for a mounting plate.
Worked perfect for me. Didn't have to modify the doors, sounds great and the windows roll all the way down.
'96 T4R SR5 | 4WD | Auto | 199 TBU | 262k+
05-06-2022, 09:04 PM
I believe the OEM rear size is a non standard size. The adapter plates posted above help transfer it to a standard 5.25" speaker. If you want totally plug and play you'll need to buy a wiring harness adapter. They're sold at Amazon, best buy, etc.
This is exactly what I did. Has worked great so far. I went with a relatively shallow mount speaker from kicker to make sure I could roll the windows down. The details are in my build thread from the Aug/Sep 2021 timeframe.
2008 Toyota 4Runner Limited 4x4 - Salsa Red, DD, Mostly Stock, 89k miles
2001 Toyota 4Runner SR5 4x4 - Not Stock, Lifted, Armored, 291k miles
1987 Toyota Supra N/A - Stock, 2nd Owner, 92k miles
05-07-2022, 04:12 AM
I was very happy with the Kickers I installed.
05-07-2022, 10:14 AM
Real Name: Mark
Real Name: Mark
For me the 5.25" didn't put out enough sound was easy install, still using them when 96Red got totaled.
In the 01 used 1/4" Luan plywood for adapters like fatherohenry because I had it, for 6.5's in doors.
lil extra work was worth it.
09-07-2022, 09:33 AM
So am replacing all my 4th gen 4runner door speakers to 8' Mid range. Does anyone know of any speaker adapters??
Sent from my LM-V600 using Tapatalk
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
