Old 01-26-2014, 02:01 PM #1
hec983 hec983 is offline
hec983 is on a distinguished road
Humming noise while coasting??
I've been trying to diagnose this issue I've been having since the purchase of my 1999 4Runner 3.4l 2wd. When I'm cruising under 10 mph and on the gas, everything is cool, but when I left off the gas you wait one second and you can hear this humming sound. It sounds like its coming from the engine only when coasting under 10mph, slightest pressure on the gas and it goes away. You can hear it whenever you are coasting or coming to a stop, until you go over 10mph then it goes away. Any ideas??
hec983 is offline   Reply With QuoteReply With Quote
Old 01-26-2014, 02:43 PM #2
Semper_Fi's Avatar
Semper_Fi Semper_Fi is offline
Semper_Fi is on a distinguished road
Semper_Fi's Avatar
my 98 does this as well so I am interested to see where this goes
Semper_Fi is offline   Reply With QuoteReply With Quote
Old 01-26-2014, 03:03 PM #3
Really? I gonna check the power steering.
Old 01-27-2014, 10:33 AM #4
Semper_Fi's Avatar
Semper_Fi's Avatar
just put a new one on mine if that will save you some time
Old 01-27-2014, 11:38 AM #5
awthorn's Avatar
awthorn awthorn is offline
awthorn is on a distinguished road
awthorn's Avatar
How slight are we talking in the sound? It could be happening all the time but then once you push on the gas the fan muffels it out. Have you checked your belts? Tire pressures? Tire grooves? Just my thoughts, good luck!
BUILD THREAD | Flickr
97 2.7 4x4 5spd, OME 881 / 890, Cooper Discoverer A/T 3, blacked out 16" split 3s, Savage Sliders. LCE Street Headers, Marlin HD Clutch.
awthorn is offline   Reply With QuoteReply With Quote
Old 01-27-2014, 05:34 PM #6
Buckaroo's Avatar
Buckaroo Buckaroo is offline
Buckaroo will become famous soon enough
Buckaroo's Avatar
Vacuum leak?
2000 T4R SR5 V6 (Retired) & 2005 T4R Limited V6
2002 & 2017 XLE Camry
2004 Honda Accord
2017 Tundra Limited DC 5.7L TRD 4WD
2024 Honda Pioneer 700-2 Deluxe
Buckaroo is offline   Reply With QuoteReply With Quote
Old 01-27-2014, 06:10 PM #7
Kanger328 Kanger328 is offline
Kanger328 is on a distinguished road
When I hear humming I think wheel bearings. But you say it's coming from the engine. Sure it's not the wheels area?
1996 Limited 4x4 Anthracite Metallic (162,XXX miles)
-OME 881/890 with Tundra Bilstein Struts/Bilstein 5100 rear, 16" 5-Stars with 265/75R16 Duratracs, Savage Sliders and Skids, B&M 70268 Trans Cooler, Amsoil Fluids
Kanger328 is offline   Reply With QuoteReply With Quote
Old 01-27-2014, 08:31 PM #8
wc11's Avatar
wc11 wc11 is offline
wc11 will become famous soon enough
wc11's Avatar
Mine did the same.
At 1st, I thought it didn't know the words.
In the end, right rear wheel bearing was on it's was out.
wc11 is offline   Reply With QuoteReply With Quote
Old 01-27-2014, 09:05 PM #9
It doesn't do it all the time tho.
Old 01-27-2014, 09:12 PM #10
Doc2012's Avatar
Doc2012 Doc2012 is offline
Location: Stationed in Camp LeJeune, home is Conover, NC
Doc2012 has a spectacular aura about Doc2012 has a spectacular aura about
Doc2012's Avatar
Possible it could be the joints on the DS going out.
When you give it gas, the load from the trans forces the shaft to spin, making the sound only come when it's got no load on it.
See if there's any play in the DS. Get under it and try to wiggle it. If it moves, its probably the joints, which can be replaced.
If not, then check the wheel bearings. Jack the truck up, and holding the tires at 6 & 12, shake them. If there's a lot of play in the tire, the bearings are bad.
"We are experts in the application of violence."
-LtCol Christian Cabannis, Camp Letherneck, Afghanistan, 2009. The "Summer of Decision."
Doc2012 is offline   Reply With QuoteReply With Quote
Old 02-26-2017, 07:25 PM #11
Acorn22's Avatar
Acorn22 Acorn22 is offline
Real Name: Brian
Acorn22 is on a distinguished road
Acorn22's Avatar
Real Name: Brian
Thread resurrection! I've looked everywhere and can't find a definite answer to this...
So I have a 98 limited and since I got it in December, I've had this weird whirring noise that only occurs when I take my foot off of the gas, sound goes away even with the slightest depression of the throttle. Since then, I've replaced both front wheel bearings (were beginning to go bad), changed all diff, t-case, and tranny fluids, put new rotors and pads on + bled the system, and greased both driveshafts but still haven't figured out what the sound is.
U-joints appear to be ok, as do the rear wheel bearings because I'm not getting any noise from them. If anyone can shed some light on this I'd appreciate it!
1998 4x4 Limited 3.4 Sunfire Red Pearl
Front: Eibach 600lb 3" lift coils over Tacoma 5100's
Rear: Lexus LX450 coils w/ FJ80 shocks
Firestone Destination AT 265/75's
Acorn22 is offline   Reply With QuoteReply With Quote
Old 02-28-2017, 06:52 PM #12
Acorn22's Avatar
Real Name: Brian
Acorn22's Avatar
Real Name: Brian
Nobody's got any ideas?
Old 02-28-2017, 07:30 PM #13
johnbyebye johnbyebye is offline
Real Name: Scott
johnbyebye is on a distinguished road
Real Name: Scott
Does this noise occur at any speed when you let off the gas?
When I had this issue with my previous vehicle it was the pinion bearing going out.
K82 2000 Limited T4R 4WD V6 auto, factory e-locker, BFG KO2s, Bilstein 5100's all around + 99 talls.
johnbyebye is offline   Reply With QuoteReply With Quote
Old 02-28-2017, 07:48 PM #14
vukos vukos is offline
vukos is on a distinguished road
See this thread for what may be a similar noise that only appears on coasting: What is this noise?!
I had to get the drive shaft lubed to get the noise to go away
vukos is offline   Reply With QuoteReply With Quote
Old 02-28-2017, 08:46 PM #15
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
On face value, it sounds like something in the differential. You can disconnect the rear drive shaft and drive in 4wd, if the noise goes away, then its something in your rear differential, most likely pinion or carrier bearings.
When you drained the diff fluid, how did it look?
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Weird Humming Noise Buckles 4th Gen T4Rs 10 05-01-2019 03:06 PM
grinding noise when coasting srd Engines / Suspension / Wheels / Tires / Audio / Accessories 8 02-28-2014 12:51 PM
Humming sound when coasting-decelerating (05 V8 4x4) BzJeep 4th Gen T4Rs 8 12-05-2013 02:22 PM
Noise when coasting RiverRat37 3rd gen T4Rs 6 12-12-2011 11:46 PM
Humming?? noise when turning? iDRiVaT4R 5th gen T4Rs 6 10-22-2010 02:07 PM
