Old 05-05-2022, 08:51 PM #1
jsnppp jsnppp is offline
jsnppp will become famous soon enough
Coolant hose Identification help request - 2002 SR5 4WD
Hi,
Spent hours trying to track down the part numbers for the hoses for my 2002 SR5. I've listed below. Surprisingly difficult to find, been on toyota parts sites, partsouq, general Internet searches, you name it.
My guess is that 2001/2002 T4Rs are slightly less common and so less documented? Not sure. Anyway, if anyone can steer me to PNs for any of these hoses, please let me know! I'd sincerely appreciate it. Remember this is for a 2002, so slightly different (of course).
Hose 1: Larger (5/8"?) hose on one side right underneath the heater valve.
Hose 2: Smaller (3/8"?) hose right under the throttle cable. It snakes underneath to the back of the engine.
Hose 3: Larger, insulated hose (may just be air) on top of engine
Hose 4: Smaller (3/8"?) hose on the other side of throttle body, connected next to what I believe is the cruise control actuator. Doesn't have a clamp, this may not be coolant.
Hose 5: Smaller (3/8"?) hose in middle of engine, in the back under the heater control valve.
Hoses 6 &7: Transmission cooler hoses
Transmission cooler hoses, these should be pretty much universal, not sure why its so hard to find part numbers!
Thank you in advance!
jsnppp is offline   Reply With QuoteReply With Quote
Old 05-05-2022, 11:54 PM #2
Unner's Avatar
Unner Unner is offline
Unner is just really nice Unner is just really nice Unner is just really nice Unner is just really nice
Unner's Avatar
https://www.toyota-4runner.org/3729452-post33709.html
Check out that post by @Spiker Engineering who just replaced most of the hoses you are looking for. There's some parts websites that are better than others, and even then some of these more specific less common parts do require some digging to find.
The 01-02 shouldn't make much of a difference for the hoses. Only one that may be different would be the throttle body ones since the throttle body is different on the 01-02.
2008 Toyota 4Runner Limited 4x4 - Salsa Red, DD, Mostly Stock, 89k miles
2001 Toyota 4Runner SR5 4x4 - Not Stock, Lifted, Armored, 291k miles
1987 Toyota Supra N/A - Stock, 2nd Owner, 92k miles
Unner is offline   Reply With QuoteReply With Quote
Old 05-06-2022, 12:26 AM #3
Spiker Engineering's Avatar
Spiker Engineering Spiker Engineering is offline
official vendor
Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of
official vendor
Thanks for the mention @Unner . I really do need to write up that whole project. I'm doing the same for air/vacuum hoses right now, so I'll post it all once it's done.
To @jsnppp -
Hose 1 - 87245-35700;
Hose 2 - having trouble following where it fits in, might be 16261-62060;
Hose 3/4 - air/vacuum hoses, not sure of PN
Hose 5 - can't tell from the photo, maybe a vacuum hose
Hose 6 - 32941-35260
Hose 7 - 32942-35110
High Lift Hood Struts | Ultragauge/Scangauge Mounts | Phone Mounts
Custom 3rd Gen 4Runner products | 100% designed, fabricated, and assembled in the USA
https://spikerengineering.com
Spiker Engineering is offline   Reply With QuoteReply With Quote
Old 05-06-2022, 10:51 AM #4
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Must be a bad habit of mine yet I like to just call my local yota parts dept, thow them a VIN and I've got parts....
Old 05-06-2022, 12:01 PM #5
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
My local toyota parts department is incompetent. I've got a 50/50 chance of getting the right part if I let them look it up for me. I prefer to go in with part numbers.
Old 05-06-2022, 12:15 PM #6
official vendor
official vendor
Same here. My local dealer is incompetent, rude "know it all" (even when they order the wrong parts), takes forever to get the parts, and is about 20% above MSRP.
Old 05-06-2022, 03:18 PM #7
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
1.) Looks like it could be either 87245-35730 or 87245-35730?
2.) I'm going to say it's 16261-62060 as that passes under the throttle body
3.) I want to say it's 12262-62060, hard to tell... but it does seem to be the hose from the air intake to the manifold for PCV ventilation.
4.) The closest I found was 90445-12284 but I'm not sure, the diagram isn't matching up to your picture very well.
5.) Maybe this one 90999-92002, the angle you took the picture makes it hard to tell what you're pointing out, but this is the only smaller vacuum line I saw along the back of the manifold that high up.
6.) 32941-35260 and (x2) 90467-16013 for the clamps
7.) 32942-35110 and (x2) 90647-16013 for the clamps
That's the best I could do based off your pictures and descriptions.
You can try figuring it out yourself if you want, I like to use Please Wait... | Cloudflare for when I am not at work or too busy to bug my parts guys. They seem to have the closest parts diagrams/fiche to what we use at work including the highlighting function and VIN filtering, etc.
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 05-07-2022, 10:28 AM #8
Thanks everyone, super helpful, I truly appreciate that you all took the time to look and record your thoughts.
I missed @Spiker Engineering 's post (https://www.toyota-4runner.org/3729452-post33709.html) somehow. Excellent list!
I also forgot to acknowledge @2TH41ST's post #12 (What other hoses should I replace?). I actually used this list in my original order, cross referencing with a 2002 parts catalog. I didn't know what I didn't have at that point.
So.
One thing I learned was that hose #5 isn't coolant at all, it's fuel. I decided yesterday to remove it to see it better. Guess that explains why I couldn't find it in the coolant sections. I replaced it with new fuel hose.
I'm going to run with this list and start cross checking with the other list.
1.) Either 87245-35730 or 87245-35730
2.) 16261-62060
3.) 12262-62060
4.) 90445-12284
5.) Doh! not coolant! but I'll check out 90999-92002
More when I get it!
~Jason
3/8 , engine , hose , hoses , smaller
2002 Door Panel Piece Identification negusm 3rd gen T4Rs 6 07-26-2020 07:40 PM
Coolant hose help LexsCTJill 4th Gen T4Rs 18 06-14-2020 08:45 AM
Coolant Temp Sensor Identification mtbtim Classic T4Rs 6 09-15-2019 01:20 PM
Intake to power steering hose identification Brickyard 4th Gen T4Rs 7 08-04-2015 04:16 AM
Wheel/Rim Identification Request - seen with Nitto Dune Grappler Tires DiggetyDan Engines / Suspension / Wheels / Tires / Audio / Accessories 7 02-09-2015 03:03 PM
