Old 05-07-2022, 10:58 AM #16
psea17 psea17 is offline
psea17 will become famous soon enough
Originally Posted by brillo_76 View Post
If you can wiggle the abs sensor out and look on thr abs gear for gear grease. If it's wet in there. Your deal is definitely leaking
completely forgot about that! good call.
'98 4Run SR5 v6 4x4-Orig Owner
Manual Transmission
Bilstein 5100 (front/rear)
OME 890 Springs (rear)
'99 Tall Springs (front)
psea17 is offline   Reply With QuoteReply With Quote
Old 05-07-2022, 11:23 AM #17
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Originally Posted by Devbot View Post
Good lord, is there anything Marlin doesn't make at this point
They make a pile of accessories and parts for our rigs and Toyota in general.
Old 05-09-2022, 12:03 AM #18
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
Marlin makes seals for the front axle on the FZJ80 and they are known to be trash. Maybe their other seals are different, but this is what I have heard so far.
Definitely pull that sensor out. Are you getting an ABS light time to time? Happens when the sensor is covered in oil. Did you do the rear axle seals yourself?
Old 05-09-2022, 12:29 PM #19
rexassian rexassian is offline
rexassian is on a distinguished road
I used these on the last rebuild, going strong so far:
Trail-Safe Seal, Rear Axle Toyota (Pair)
I also had nics in my axle shaft from when the PO cut off the retaining rings so I added sealant to the axle as well as to the inside of the seal to axle housing mating surface to make sure nothing leaks past.
1999 SR5 V6 manual trans 4x4 - Lifted on 35's - Build thread
rexassian is offline   Reply With QuoteReply With Quote
Old 05-09-2022, 11:20 PM #20
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
When you say you made sure it is riding on the retainer did you measure them? Also, you made sure that everything was pressed together when you measured? I've seen guys have the bearing not fully seated and have a little slop, which skewed their measurement and caused the retainer to be pressed too far down once the axle was installed and torqued (hell, I've done it once or twice myself when I was in a rush).
One other thing I've seen is gouges on the axle from cutting off the old races. I know some guys like to put sealant as they press the parts on the axle, but in this case it still slipped under the retainer and bearing, customer had the previous shop buy him a new axle and bearing job (was only a month old.)
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 05-10-2022, 12:25 AM #21
wow. thanks for all the help guys.
yes i did my own seals twice now
never cut anything off the axles
definitely measured retainer position relative to the seal both using calipers and doing a grease test.
no abs warning lights ever
I'll definitely check out those other seals. THANKS for the recommendations.
as soon as im done getting to the root of the engine oil leak (guessing cam or crank seals), I'll be moving to the rear axle.
thanks again!
Manual Transmission
Old 05-10-2022, 12:44 AM #22
T4R2014's Avatar
T4R2014's Avatar
Forgive me if you specified already. Does it only fail on one side?
Old 05-10-2022, 01:20 AM #23
this latest leak is just on the passenger side
Manual Transmission
Old 05-10-2022, 01:26 AM #24
T4R2014's Avatar
T4R2014's Avatar
What's the order of failures so far? Did you replace the bearings every time? And if you can recall the condition of the bearings? I'm trying to determine if something is bent. A bent axle shaft is very realistic.
Old 05-10-2022, 02:40 PM #25
Hopeless Diamond's Avatar
Hopeless Diamond Hopeless Diamond is offline
Hopeless Diamond has a spectacular aura about Hopeless Diamond has a spectacular aura about Hopeless Diamond has a spectacular aura about
Had a similar problem, used new retainers and put FIPG on the axle shaft before I pressed everything on. Then put a light coating of FIPG in the axle tube before I put the seal in. No problems since.
Hopeless Diamond is offline   Reply With QuoteReply With Quote
axle , beefier , heavy , rear , seals
Heavy Duty Rear Sway Bar Links pearlj10 5th gen T4Rs 106 06-09-2021 05:12 AM
Toytec Heavy Duty Rear Coils DezRoamer 5th gen T4Rs 27 12-10-2020 11:32 PM
Heavy Duty Rear Coils *NEW*; $125; VA Hertz4R For Sale: T4R Items 2 11-07-2018 09:58 PM
Heavy Duty Rear Sway Bar Links pearlj10 4th Gen T4Rs 15 10-28-2015 10:42 AM
