Old 05-08-2022, 07:35 PM #1
KelOfTheRockies KelOfTheRockies is offline
KelOfTheRockies is on a distinguished road
New eccentric adjusters: Antiseize?
Truck is 2000 Ltd 4WD with V6 in decent shape at 220,000 miles
I started out to replace some old suspension parts and the can-of-worms just kept getting bigger and bigger. LOTS and lots of rusted crap.
As of now, I am replacing
  • Wheel bearings and seals
  • Upper Control Arm bushings
  • Right upper control arm
  • Lower Control Arm bushings
  • Eccentric adjusters
  • Upper ball joints
  • Lower ball joints
  • Tie rod ends
  • Sway bar links
  • Struts
Ready to re-assemble and here is my Question:
Should I put antiseize on the eccentric adjusters? A couple of them were so stuck I had to saw them out.
THX!!!
- k -
KelOfTheRockies is offline   Reply With QuoteReply With Quote
Old 05-08-2022, 08:01 PM #2
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
THX!!!
- k -
Should you? No clue, though I did on my '99 when I was going through it. Put some sort of anti-seize on everything. Probably won't be for my benefit, but someone down the road will thank me.
Brian. is offline   Reply With QuoteReply With Quote
Old 05-08-2022, 08:26 PM #3
Thanks for the input. I also noticed that Gerdo in
This thread
Recommended it too.
You're probably right, won't help me much but the next guy should be grateful.
Much Appreciated!
- k -
Old 05-09-2022, 10:43 PM #4
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
I put some on my 4th gen when I replaced the lower control arms and hardware. It won't really hurt to put something like a very light coat of anti seize or moly sulfide on the surfaces that interact with the bushings and shaft of the bolt and the sleeves. You just want to give it some protection against rusting in the sleeve and bushing, i would be hesitant to put any on the cans themselves though, you don't want to lube it to the point it will slip easily. Just don't get any on the threads as that modifies the torque when you tighten them up.
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 05-11-2022, 09:21 AM #5
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice
Romeo1's Avatar
Antisieze all the things. Anti seize the threads too. The next guy will thank you. Its just the smart thing to do.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
Romeo1 is offline   Reply With QuoteReply With Quote
Old 05-11-2022, 05:44 PM #6
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
For sure on cams then pretty much anything else in the weather and dissimilar metals.
Old 05-11-2022, 10:19 PM #7
nissanh nissanh is offline
I did all the bushings front and rear.. Yes, anti-seize the bolt rod and threads! If you work on your vehicles, life is so easy with anti-seize!
1990 3L Diesel Hilux LN 106; 1973 Ford Cortina XL
1992 4AFE Toyota Sprinter AE 91 (aka Geo Prizm)
1997 5vzfe 4Runner 4x4 (aka Hilux Surf)
2000 2uzfe 100 Series Land Cruiser
2021 Tacoma TRD Off-Road 4x4 6-speed
Old 05-12-2022, 09:45 AM #8
JohnMc JohnMc is offline
JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all
I had to sawzall out the old (original) adjusters on mine. They were JAMMED and I tried for a silly amount of time with leverage, penetrating oils, heat, rattle guns, hammers, nothing made it budge at all. Finally just gave up and sawd on both sides of both bushings and that worked.
I gooped up the new hardware with antiseize.
JohnMc is offline   Reply With QuoteReply With Quote
Old 05-12-2022, 09:55 AM #9
cl4Rk's Avatar
cl4Rk cl4Rk is offline
cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold
cl4Rk's Avatar
I replaced mine with a greasable design. I did get alignment slip on my last wheeling trip though. Not sure if that’s because they were so well-greased or if it would’ve happened either way. Now I’m leaning towards moving to adjustable UCAs and cam eliminator plates.
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
cl4Rk is offline   Reply With QuoteReply With Quote
Old 05-12-2022, 12:03 PM #10
Real Name: Mark
Real Name: Mark
Did the greaseable design only have one flat on thru bolt (Moog) for cam washers? I got them for grease fitting, the alignment guy fugged them up on first alignment bad design soft steel back to OE adjusters.
Grease will not let adjuster move not being torqued to spec will. Are the tabs on your cam plates bent? One of mine was last time I had it apart hammer and punch fixed it.
adjusters , arm , control , eccentric , upper
Fox 2.0 with the CD Adjusters in Rear Phade 5th gen T4Rs 0 05-13-2020 12:14 PM
Control arm lubrication. Antiseize Vs Grease hutchison 4th Gen T4Rs 4 07-31-2019 10:54 PM
Alignment Issues (LCA): Eccentric bolt seized to bushing? nobb 3rd gen T4Rs 2 07-04-2013 12:16 PM
Anyone Replace Eccentric Bolts? Cant Align my truck? mikey2nuts 4th Gen T4Rs 1 10-30-2012 08:13 PM
Fog Light Adjusters ALLEGRO 4th Gen T4Rs 3 01-10-2009 02:07 AM
