Old 05-09-2022, 03:59 PM #1
svaero svaero is offline
svaero is on a distinguished road
Stuck in park, no brake lights
My 2000 4runner is stuck in park and has no brake lights. I checked the fuses and all are good. I pulled the brake switch and tested both sets of poles for continuity in both positions - all's good. I then check voltage to the brake switch - nothing. I don't have a wiring diagram. Is there a relay or something upstream from the brake switch that could be the issue?
2000 4Runner SR5 3.4 V6
svaero is offline   Reply With QuoteReply With Quote
Old 05-09-2022, 05:17 PM #2
willyd520's Avatar
willyd520 willyd520 is offline
willyd520 will become famous soon enough
willyd520's Avatar
How did you check your fuses? If you didn't use a test light to test them I would buy one just to verify. I've seen fuses that looked good visually but failed when I had a test lamp.
willyd520 is offline   Reply With QuoteReply With Quote
Old 05-09-2022, 08:00 PM #3
phattyduck phattyduck is online now
Don't drive it like this (with no brake lights), but you can use the override button on the shifter (open little cover in front of where the shifter moves).
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
phattyduck is online now   Reply With QuoteReply With Quote
Old 05-09-2022, 09:40 PM #4
spartacus's Avatar
spartacus's Avatar
Check the fuse labeled stop inside the cab fuse panel with a MM.
Old 05-10-2022, 10:42 AM #5
I visually checked all the fuses twice and all appeared to be good. It was suggested that I check the fuses with a meter to verify they were in fact good. That did the trick. I’ve never had a fuse go bad that wasn’t blown. A good lesson. Next time I check a fuse I’ll do it with a meter instead of spending hours chasing ghosts. Thanks for the help.
brake , good , lights , stuck , switch
Stuck in Park. Already changed brake switch. Velonici 4th Gen T4Rs 2 08-29-2020 11:44 PM
2001 4Runner, ABS, Brake!, both VSC lights, locked in Park MoabDesertAdventur 3rd gen T4Rs 15 04-05-2018 02:48 PM
Brake lights stuck on z06vette 4th Gen T4Rs 9 01-18-2012 10:15 PM
3rd brake light on with park lights mustangstephen 3rd gen T4Rs 4 01-02-2012 01:24 AM
Stuck in Park -Brake Switch Faulty? supergooch Classic T4Rs 1 01-09-2009 01:05 PM
