Old 05-17-2022, 12:11 AM #31
IBallEngineer's Avatar
IBallEngineer IBallEngineer is offline
IBallEngineer will become famous soon enough IBallEngineer will become famous soon enough
Originally Posted by Jakeepoo3 View Post
With the suspected injector pulled out of the rail connect 12 volt power source to one terminal at the connector and ground wire to the other terminal. The injector should click each time the ground wire is connected and disconnected to the terminal.
Making the electromagnet click does not assure you the injector is properly opening the needle valve at the rate required or that the spring is returning it to fully closed. If you have the injector out, replace it! I know it 's pricey, but replace them all, don't buy cheap. And no matter what replace ALL THE INJECTOR SEALS. Be sure to use a lubricant on the seals when reinstalling the fuel rail. Pressurize the fuel system before you re-install the intake plenum and make sure you don't have any leaks. The seals are fragile and easily ruined.
1989 FJ62 5.3 Chevy, FZJ80 Axles, 4.88's with ARB.
2000 2wd runner, 4 cylinders, yes it IS slow.
1999 4WD SR5 Desert Dune 3.4 351K and counting.
2000 4WD sport 3.4 Elocker <--My son's but I still end up paying.
2001 2WD SR5 3.4 <-- My daughter's...see preceding line.
IBallEngineer is offline   Reply With QuoteReply With Quote
Old 05-17-2022, 01:44 PM #32
jhuerta22's Avatar
jhuerta22 jhuerta22 is offline
jhuerta22 is on a distinguished road
jhuerta22's Avatar
Originally Posted by TW44LR View Post
Gotcha I’ll try to test it this weekend. If it tests bad should I go ahead and replace them all or just the one? Any good sources on where to get them?
I bought OEM off of ebay used. I only replaced the bad one a the time since the others were in spec. You could replace all of them and if you buy used, test them before install. I know it sounds like a duh statement, but I had an issue with a new OEM TPS which wasn't working and ended up having to get another to fix my problem.
Huerta
"Black Burro" 2000 4Runner SR5, e-locker, Tundra/906 lift, Tundra brakes, 348K
"Fez Johnson (FJ)" 1997 Land Cruiser 40th Anniversary, Antique Sage, triple locked, 195K SOLD
"4-Lo Silver" 2010 4Runner Trail, bone stock, 178K, Lovin' it
jhuerta22 is offline   Reply With QuoteReply With Quote
Old 08-21-2023, 09:49 PM #33
dvachon dvachon is offline
dvachon is on a distinguished road
thanks
dvachon is offline   Reply With QuoteReply With Quote
changed , cylinder , i’m , plugs , spark
Chasing a misfire that I can't solve. Help! G_Raw 3rd gen T4Rs 55 03-11-2021 04:12 PM
Chasing down a oil leak hallj22 3rd gen T4Rs 5 11-18-2018 10:44 PM
Chasing a misfire shamulater 3rd gen T4Rs 10 01-05-2014 12:20 PM
Chasing my tail here. Misfire on 2/4/6 after t-belt replacement. StopHammertime 3rd gen T4Rs 18 02-20-2013 11:46 PM
Cylinder one misfire error code without the misfire MJW 3rd gen T4Rs 4 05-03-2012 09:07 AM
