Old 05-15-2022, 11:56 PM #1
TW44LR's Avatar
TW44LR TW44LR is offline
TW44LR will become famous soon enough
TW44LR's Avatar
Chasing misfire
I know I know, this topic has already been beaten to death. I have researched this a fair bit but just wanted some expert advice. I’ve been getting an intermittent misfire mostly on cylinder 5, code p0305. One time it gave codes p0300 0304 0305 0306 but most commonly p0305 or just p0300. I changed the spark plugs on Thursday so 3 days ago and it was fine until last night/today it started happening again. When I changed the spark plugs I also cleaned the MAF sensor, throttle body and changed out the PCV valve, I also switched the coil pack on cylinders 3 & 5 to see if it was maybe the coil packs. The code didn’t follow to cylinder 3 and I replaced the spark plug wires when I did the spark plugs last ~ 30k mi ago so I don’t believe it’s those. It seems to only occur after i drive it and then turn the engine off for less than 30 minutes when I start it up again it has a rough idle up to about 2k rpm’s. This along with everything else leads me to believe that it’s the fuel injectors, more specifically the one for cylinder 5. If I’m wrong or there’s anything else I could try to make sure, let me know. If not I’m wondering where the consensus on getting fuel injectors would be and if I should just replace all while I’m at it or just do the one and not worry about the others?
TW44LR is offline   Reply With QuoteReply With Quote
Old 05-16-2022, 12:12 AM #2
TW44LR's Avatar
TW44LR's Avatar
Picture of old spark plugs. #5 doesn’t look overly bad to me but the electrodes seem to be a little more black than the others
Old 05-16-2022, 08:03 AM #3
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
You probably know this, after doing all that maintenance, you performed learning value reset and idle learning I assume.
Jakeepoo3 is offline   Reply With QuoteReply With Quote
Old 05-16-2022, 09:19 AM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
You can verify the plugs wire with a mulitmeter.
https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
When was the last time the fuel filter was changed? Do you ever run some fuel injector cleaner with you gas tanks full.
Do you have good fuel pressure up to the injector rails?
Its possible to be spark or fuel at this point until you rule things out. :-)
Old 05-16-2022, 09:27 AM #5
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
I would swap coil packs and see if the problem moves with the coil
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 05-16-2022, 09:31 AM #6
4Reak Show's Avatar
4Reak Show's Avatar
Just go back to basics:
Fuel +
Air +
Compression +
Spark +
All occuring at the proper time =
Normal running engine.
Sounds like you did spark-nope.
Air is unlikely an issue-nope.
Timing (both valve timing and spark timing) is probably not it since it’s one cylinder mostly and generally one major failure would affect more than one cylinder-nope.
So now you’re down to compression and fuel.
Compression testers are cheap, may even be rentable. I doubt it’s a compression issue since it’s intermittent and generally a compression issue is constant. But you could try.
That leaves fuel. This is further broken down into supply and delivery.
Unlikely a supply problem (pump, filter, bad gas, low pressure etc) since, again, it’s a single cylinder and generally an overall supply issue would affect more than one.
So now it’s down to delivery: injector, computer, wiring in between. You could install a little light bulb (special version is called a noid light) piggy-backed onto the wires of the suspected injector and look for a flashing bulb WHILE THE MISFIRE OCCURS. This would rule out the computer and harness. You want to see a flashing light (which is a command to fire the injector) WHILE MISFIRING. Means the injector is no good. Now, a non flashing light would lean towards a harness or computer issue.
It’s probably the injector. Had a similar issue back in 2020. Went through all the same steps since I already have all the tools. It’s about the same amount of time to do one injector vs all. All injectors are same age, same amount of cycles. So I’d say do them all if you settle on injectors.
I went through 5-0 motorsports. Small deposit to return old injectors. They’re reman’d OEM.
Old 05-16-2022, 01:01 PM #7
TW44LR's Avatar
TW44LR's Avatar
When I changed spark plugs I swapped coil packs in cylinder 3 & 5 and the code didn’t follow to 3 but stayed on 5 so I believe coil packs are ruled out.
Old 05-16-2022, 01:02 PM #8
TW44LR's Avatar
TW44LR's Avatar
I pulled EFI fuse for ~15 mins if that’s what you mean and cleared codes with my ultragauge
Old 05-16-2022, 01:21 PM #9
Jakeepoo3's Avatar
Jakeepoo3's Avatar
Here's part of what I meant. There's a couple more pages describing the procedures. Could be a possible cause of your high idle inconsistentcies..
Chasing misfire-screenshot_20220516-121718~2-jpg
Old 05-16-2022, 01:45 PM #10
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
That does not apply to 3rd Gens
Old 05-16-2022, 02:00 PM #11
spartacus's Avatar
spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of spartacus has much to be proud of
spartacus's Avatar
Most likely injector number 5. Have to take the plenum off to test number 5 but should be 13.8 ohms. at 68 degrees, ohms could be higher due to temp variations.
Old 05-16-2022, 02:31 PM #12
Jakeepoo3's Avatar
Jakeepoo3's Avatar
No learning involved with them period? I've relearned vehicles much older. Thanks for not griping me out this time! My bad
Old 05-16-2022, 02:39 PM #13
Real Name: Patrick
Real Name: Patrick
The procedure itself doesn't exist for 3rd gens (or at least I have not been able to find it on techstream). The learned values reset after either disconnecting the battery or removing the ecu fuse and then will start relearning as you drive it.
Old 05-16-2022, 02:44 PM #14
jhuerta22's Avatar
jhuerta22 jhuerta22 is offline
jhuerta22 is on a distinguished road
jhuerta22's Avatar
I had an issue with intermittent misfires. Same codes and everything. It was an injector that would get stuck after the truck warmed up. Would run fine cold, but as soon as I shut it off it'd throw a code. It's not too bad of a job to do and a good used one is fairly cheap. I have 5 if you can't find one.
Huerta
"Black Burro" 2000 4Runner SR5, e-locker, Tundra/906 lift, Tundra brakes, 348K
"Fez Johnson (FJ)" 1997 Land Cruiser 40th Anniversary, Antique Sage, triple locked, 195K SOLD
"4-Lo Silver" 2010 4Runner Trail, bone stock, 178K, Lovin' it
jhuerta22 is offline   Reply With QuoteReply With Quote
Old 05-16-2022, 02:52 PM #15
TW44LR's Avatar
TW44LR's Avatar
I’ll have to find my multimeter and check wires. Fuel filter was changed ~30k miles ago when I picked this rig up and changed a bunch of stuff up to get it up to snuff. I have been running some Lucas fuel injector cleaner since I changed the spark plugs last Thursday, so far no change but I haven’t ran a full tank of fuel through it yet. How would I go about checking fuel pressure?
changed , cylinder , i’m , plugs , spark
Chasing a misfire that I can't solve. Help! G_Raw 3rd gen T4Rs 55 03-11-2021 04:12 PM
Chasing down a oil leak hallj22 3rd gen T4Rs 5 11-18-2018 10:44 PM
Chasing a misfire shamulater 3rd gen T4Rs 10 01-05-2014 12:20 PM
Chasing my tail here. Misfire on 2/4/6 after t-belt replacement. StopHammertime 3rd gen T4Rs 18 02-20-2013 11:46 PM
Cylinder one misfire error code without the misfire MJW 3rd gen T4Rs 4 05-03-2012 09:07 AM
